PrincessClevage 175 Posted December 23, 2020 Posted December 23, 2020 I have my preferred refresh rates set too: 23;24;25;29;30 and when I play live tv with enable refresh rate change it changes to 50 or 60hz and my tv goes black as it does not support this frequency though raw RGB GPU 10 bit. The previous version of ET honoured set refresh rates but the newly updated version has lost this ability
Luke 42240 Posted December 23, 2020 Posted December 23, 2020 Hi, you set it to 25, that is a multiple of 25, right?
PrincessClevage 175 Posted December 23, 2020 Author Posted December 23, 2020 1 hour ago, Luke said: Hi, you set it to 25, that is a multiple of 25, right? In the previous version if I set preferred refresh rate to 23;24;25;30it would only use those refresh eg if live tv is broadcast at 50hz or 60hz it would choose 25 or 30hz and not go over what my tv can support
Luke 42240 Posted August 3, 2021 Posted August 3, 2021 I believe that's happening because it's a multiple. Anyway we are currently revamping the windows app and will review this as part of that. Thanks.
