SpaceCowboy1968 3 Posted December 21, 2023 Posted December 21, 2023 (edited) Howdy all, i activatedthe holiday theme the first time and get no suggestions. I read about the solution mentioned here, but for me it doesn't work. I use Emby on a 2019 NVidia Shield with Android 9 (no newer OS available) and Windows Server (with Emby service of course). The media meta data has been scraped with tinyMM v3 with NFO format Kodi (which i used before). There are a few media tagged with "christmas" and/or "holiday", all lower case. The Halloween Theme worked correctly. I added an nfo file. It's no problem for me but this here is not my solution. Happy holidays all! And do Santa a favor, don't close your chimney when converting to heat pump Bad Santa Extended Edition.nfo Edited December 21, 2023 by SpaceCowboy1968
ebr 16337 Posted December 21, 2023 Posted December 21, 2023 Hi. If you enable the theme manually, it does not show suggestions. It will only show those right around the 25th.
C.S. 95 Posted December 21, 2023 Author Posted December 21, 2023 And that's a bummer because a lot of us like to watch holiday movies all month. 1 2
FrostByte 5454 Posted December 21, 2023 Posted December 21, 2023 1 hour ago, C.S. said: And that's a bummer because a lot of us like to watch holiday movies all month. Agree, whether it starts manually or automatically, it would be nice to see the suggestions once the theme is active. 3
Spaceboy 2573 Posted December 22, 2023 Posted December 22, 2023 this feedback has been given and ignored ad infinitum. you'd be better finding your nearest wall and applying your head to it liberally
markpud 3 Posted December 22, 2023 Posted December 22, 2023 (edited) Guess we are all here for the same reason! My emby is set to show holiday themes auto magically and the Christmas one kicked in today. But no actual suggestions. If I hit search and ask for Christmas then I get a bunch of episodes with Christmas in the title.. Would seem logical that if there are no suggestions then just hide the prompt.. it worked ok at Halloween but I guess I don't have any movies tagged with holiday..I don't mind the red theme and even the jingle sound but a popup about recommendations should have some recommendations, or not be there At least I can uncheck the theme suggestions box Edited December 22, 2023 by markpud 1
vdatanet 1619 Posted December 22, 2023 Posted December 22, 2023 I have selected the theme manually and the Christmas suggestions appear. Show suggestions must be enabled and the genre must contain Holiday, at least it works for me. I don't use tags.
Almighty 11 Posted December 23, 2023 Posted December 23, 2023 (edited) +1 to wanting to see suggestions all of December as my family traditionally watches Christmas movies all throughout the month. It'd be nice to have a way to configure the holidays. I have lots of movies with christmas/holiday tags, populated from my NFO files, but nothing is appearing right now, even after enabling all the options in Display Settings. Server 4.8.0.63, Android TV 2.0.99g Edited December 23, 2023 by Almighty
ebr 16337 Posted December 23, 2023 Posted December 23, 2023 14 hours ago, Almighty said: with christmas/holiday tags Hi. The search is done on genre, not tag.
Almighty 11 Posted December 23, 2023 Posted December 23, 2023 7 minutes ago, ebr said: Hi. The search is done on genre, not tag. Holiday isn't a genre... According to IMDb, the movie db, etc. Tags would make this feature way better...
Killface69 96 Posted January 2, 2024 Posted January 2, 2024 On 12/23/2023 at 5:41 PM, ebr said: Hi. The search is done on genre, not tag. I suggest a change for future holidays, as 'christmas/holiday' can be found within my tags scraped from TMDB or IMDB, but none of those sites has "Holidays" or "Christmas" as genre, it's solely used as tag. No one is adding manually "Christmas" as genre, thus the question : "Is it a bug or a feature?" 1
LCrane001 1 Posted October 28, 2024 Posted October 28, 2024 I do not add the word "Holiday" as a Genre and do make sure tags are added (if not automatically) for "Christmas", "New Years", "Halloween" and so on. I think it would be a great feature if we could set seasonal spotlight films based on tags as an admin feature. Or slightly retool the holiday spotlight already in Emby to allow the admin to set the films based on tags or spotlight checkbox per film options, and a background image to for spotlight section, be it for general or holiday. I would love this ability. 1
