LehighBri 19 Posted August 2, 2014 Posted August 2, 2014 @@krustyreturns and I have been doing some testing on the new transcoding feature as seen here and are having issues where MBS is not updating the Path to a recording, and if the Path isn't correct, transcoding is used instead of Direct Play which is not what is desired since my recordings and clients are all on the same network. In our testing w/ serverwmc and MBS, we double confirmed that ServerWMC has the correct UNC path for my recorded TV, but for some reason MBS is still storing the local recording path in the Json data's "Path" variable. Is MBS caching the Path's and not updating them for some reason each time it "rescans" for recordings? Additionally, I just created a new recording, and when I look at the json data after the recording completes and I reboot MBS completely, it does not have a Path variable at all (and it says LocationType is Remote instead of saying FileSystem) as you can see below! 14:50:10 T:6040 NOTICE: Play jsonData: {"Name":"American Dad","Id":"67f387cc76c172b089bd430750adb99c","DateCreated":"2014-08-01T18:15:24.3459065Z","IsUnidentified":false,"SortName":"american dad","ExternalUrls":[],"MediaSources":[{"Protocol":"Http","Id":"67f387cc76c172b089bd430750adb99c","Type":"Default","Name":"","VideoType":"VideoFile","MediaStreams":[],"PlayableStreamFileNames":[],"Formats":[],"RequiredHttpHeaders":{}}],"Taglines":[],"Genres":[],"PlayAccess":"Full","IsPlaceHolder":false,"RemoteTrailers":[],"ProviderIds":{},"IsHD":false,"IsFolder":false,"Type":"Recording","People":[],"Studios":[],"UserData":{"PlaybackPositionTicks":0,"PlayCount":4,"IsFavorite":false,"LastPlayedDate":"2014-08-01T18:41:17.7177465Z","Played":true,"Key":"Recording-29848314-56576"},"DisplayPreferencesId":"6f93e109f7c77df02733202779c82777","Tags":[],"Keywords":[],"PrimaryImageAspectRatio":1.335,"OriginalPrimaryImageAspectRatio":1.335,"MediaStreams":[],"VideoType":"VideoFile","PartCount":1,"MediaSourceCount":1,"ImageTags":{"Primary":"19766519a73b2cab72726781fb7064b3"},"BackdropImageTags":[],"ScreenshotImageTags":[],"Chapters":[],"LocationType":"Remote","MediaType":"Video","ProductionLocations":[],"LockedFields":[],"LockData":false} So two questions for MBS devs: 1. Where does MBS get its Path attribute from when interacting with live TV plugins like ServerWMC? And does it get updated or not are updates ignored (which I don't think they should be)? 2. Why after a recording completes (example above) does MBS not have a Path variable at all? In both cases, ServerWMC can provide the UNC path, but would like to know how things are working on MBS's side in terms of how it pulls the path info and how it stores and/or updates it. That's the key to solving this issue. And I am running MBS 3.0.5309.26857 on windows (on the same machine as WMC). EDIT: I also just tried this on the new MBS 3.0.5326.13255 server version and I get the same results. EDIT 2: I did a quick look in the MBS server log when it hits transcoding for the situation above where there is no Path attribute returned via json (which is what XBMB3C uses), that MBS does definitely have the correct filename and path info, but for some reason, when json asks for it it doesn't exist or send back the correct path. 2014-08-01 15:06:49.6625 Info - App: C:\Users\ERICA\AppData\Roaming\MediaBrowser-Server\ffmpeg\20140612\ffmpeg.exe -fflags +genpts -async 1 -vsync -1 -i file:"\\ERICA-PC\Recorded TV\American Dad_TBSHD_2014_08_01_14_14_41.wtv" -map_metadata -1 -threads 2 -sn -codec:v:0 libx264 -preset superfast -crf 23 -maxrate 40000000 -bufsize 80000000 -vsync vfr -force_key_frames expr:gte(t,n_forced*7) -sc_threshold 0 -codec:a:0 aac -strict experimental -af "adelay=1,aresample=async=1000" -hls_time 7 -start_number 0 -hls_list_size 1440 -hls_base_url "hls/8734131142c2cae36d569213bec4b75b/" -y "C:\Users\ERICA\AppData\Roaming\MediaBrowser-Server\transcoding-temp\8734131142c2cae36d569213bec4b75b.m3u8"
LehighBri 19 Posted August 5, 2014 Author Posted August 5, 2014 it's the path that is given to us by the live tv provider. Right. In my case I use serverwmc, and there's two scenarios we are seeing where MBS is not behaving as we expect: 1. Let's say MBS pulls in my list of recordings, then I change my WMC recording path to be a different path; when I restart MBS, while serverwmc does indeed send the updated/new recording path to MBS, MBS does NOT update it's path information and still uses the old path when I would think the path should be updated 2. In my example above, for some reason my path variable doesn't exist. Same story... serverwmc definitely is providing the right path info to MBS, but MBS isn't taking it for some reason. Thoughts?
LehighBri 19 Posted August 5, 2014 Author Posted August 5, 2014 Thought I'd bump this. Any thoughts from MBS devs?
Luke 42241 Posted August 5, 2014 Posted August 5, 2014 it's the path that is given to us by the live tv provider.
krustyreturns 191 Posted August 7, 2014 Posted August 7, 2014 @@Luke, just to recap my experience: Initially when @@LehighBri and other users use the 'play to' xbmc feature, the xbmc MBS addon complained that the paths were local paths. So I fixed this in serverwmc, so that the user can configure it to send only UNC paths. However MBS still uses the old local paths that were sent previously for the recordings, even though serverwmc is now sending UNC paths. Even restarting MBS didn't make a difference. The only way I could get MBS to start using the new UNC paths was to remove the recordings, refresh MBS so that it no longer saw the recordings, then put the recordings back. It does seem like once MBS gets a path for a recording, then is no way to update that path later with a new value.
Solution LehighBri 19 Posted August 12, 2014 Author Solution Posted August 12, 2014 (edited) I just saw the blog the Media Browser Server 3.0.5336 Beta Released blog post and noticed that it includes the following fix "Live TV recording paths not updating". Sounds like this will fix the issue in this thread? Great news if so! I'm using stable releases so won't test this yet, but look forward to trying it out once the stable version is released. Edited August 12, 2014 by LehighBri
mini__me 28 Posted August 14, 2014 Posted August 14, 2014 I should be able to test this out on Saturday morning or if I'm lucky Friday night
mini__me 28 Posted August 16, 2014 Posted August 16, 2014 Recordings now direct play Live TV still transcodes, is this something that can be also played directly without transcoding as well?
LehighBri 19 Posted September 3, 2014 Author Posted September 3, 2014 Recordings now direct play Live TV still transcodes, is this something that can be also played directly without transcoding as well? I would think so. Ultimately Live TV is still playing back from a file so I don't think transcoding should be used. Can you maybe start another post about this with some logs? Seems like a potential bug in the transcoding logic. 1
mini__me 28 Posted September 5, 2014 Posted September 5, 2014 Will play with this again tonight / tomorrow and create new topic and provide logs as required.
