cristianb1087 1 Posted December 19, 2020 Posted December 19, 2020 Ciao, ho già letto vari topic in questo forum, ma non risolvo il problema, mi sembra di aver capito da quanto letto che la versione 0.85 funzionerebbe e le successive no. Avevo una versione funzionante (non so la varsione esatta) ed aggiornando un paio di mesi fa è morto tutto. L'errore è il solito invalid package ecc... Questi sono i dati della mia tv: Modello QE55Q7FAM Versione software T-KTMDEUC-1280.5 . BT - S Come risolvo? Grazie.
FrostByte 5453 Posted December 19, 2020 Posted December 19, 2020 Have you tried .87 from GitHub which was just released 6 days ago?
cristianb1087 1 Posted December 20, 2020 Author Posted December 20, 2020 Thanks, I tried to install the last version, but i read this error: [User App] emby.tmg, invalid app package for security check failed! What can I do?
cristianb1087 1 Posted December 20, 2020 Author Posted December 20, 2020 i downloaded the file here: [...] Installation instructions Download this zip file: https://github.com/MediaBrowser/Emby.Releases/raw/master/tizen/tizen.zip Format a USB 2.0 stick using FAT16 (some larger USB 3.0 hard drives have been found to not work) Copy the tizen.zip file to the root of your USB stick [...]
cristianb1087 1 Posted December 21, 2020 Author Posted December 21, 2020 Yes, i have tried. I followed topics for this problem and i tried all version attached
Luke 42242 Posted December 22, 2020 Posted December 22, 2020 What exactly did you do on your USB stick?
cristianb1087 1 Posted December 24, 2020 Author Posted December 24, 2020 Now, it's ok. I tried to change usb with verbatim and it is installed.. Thanks 1
