tomnjerry74 97 Posted December 17, 2020 Posted December 17, 2020 It would be useful to have a "scroll-to-top" button present universally for any given page of the web ui. If you need an example of what this means, scroll down on any page of these forums. After a certain point, you will see the button fade-in on the bottom-right of your screen. I can see this request being countered with "this can already be achieved by using the alphabet selector on the side". However, this is not present in many places where a scroll-to-top button would still prove to be incredibly useful. For instance, when viewing a full library with sorting options set to anything other than 'Title'. 4 1
Luke 42246 Posted December 17, 2020 Posted December 17, 2020 Hi, I suppose it's possible. Perhaps a floating button that only appears once you've scrolled down a certain amount. 3
tomnjerry74 97 Posted December 17, 2020 Author Posted December 17, 2020 Just now, Luke said: Hi, I suppose it's possible. Perhaps a floating button that only appears once you've scrolled down a certain amount. Yes, precisely. I believe it would be a useful feature, especially when scrolling down a large library with the new infinite-scrolling.
GrimReaper 4906 Posted December 18, 2020 Posted December 18, 2020 19 hours ago, tomnjerry74 said: Yes, precisely. I believe it would be a useful feature, especially when scrolling down a large library with the new infinite-scrolling. Or use Extension/Add-in for your browser of choice, I'm using one for Edge Chromium for exactly that purpose. 1
gillmacca01 220 Posted August 9, 2021 Posted August 9, 2021 Using an extension would be no good on a TV. Whatever option may come along, it needs to be compatible with all devices
GrimReaper 4906 Posted August 9, 2021 Posted August 9, 2021 18 minutes ago, gillmacca01 said: Using an extension would be no good on a TV. Whatever option may come along, it needs to be compatible with all devices I agree, but the OP was about Emby Web. Don't know which TV app you refer to, but in Android TV app single 'back' takes you to top inside any library.
gillmacca01 220 Posted August 9, 2021 Posted August 9, 2021 I have nvidia shield for one tv, and the other is a Samsung tv
GrimReaper 4906 Posted August 9, 2021 Posted August 9, 2021 Don't know does the same apply to Samsung TV app, quite easy to test, though?
FrostByte 5455 Posted August 9, 2021 Posted August 9, 2021 ATV on first click of Back takes you to the first poster in any library, then returns to the previous screen on the second click of Back Emby for Android, Samsung, and other ET apps just immediately take you to the previous screen. 1
