dovedescent7 3 Posted December 17, 2020 Posted December 17, 2020 (edited) love new hardware just one problem! Been using Intel since 2004.Switched to Ryzen 3700x this week plus gtx 1050 2gb. Everything works AMAZING except the one BIG glitch today and I think I'm close to figuring it out. So my wife was watching SWAT on CBS tonight, using "watching from beginning" while it was being recorded via hdhomerun. She was 4 minutes into the show, playing from beginning, and there was about 10 min left until the show was supposed to stop recording, and the show started to barf, skip, then freeze and couldnt playback after trying on multiple devices. So I checked the actual 5gb or so .TS file, but it had ZERO Mediainfo and also wouldn't play on windows nor vlc. ALSO, the whole time she was having this issue,I was logged in via rdp to emby server windows and tested the CBS channel in Chrome. I went here and changed suggested settings later. https://support.emby.media/support/solutions/articles/44001894172-hardware-acceleration-fails-with-remote-desktop-rdp-on-windows Then I find out that I forgot to change transcoding settings from my emby backup when installing to new amd hardware. Under transcoding was selected to ADVANCED with NOTHING checked! Also, being new to AMD, I really don't know what Hardware settings to choose, if any. I rarely if ever transcode H 265 i ONLY transcode h.264. -So what logs do I post for help? -And which hardware do I select or use for transcoding? (what would most people use 3700x or 1050 2gb?) -P.s. I have MCEbuddy also running could selecting "Delete original file" setting in MCE have caused this all? thanks EDIT i'm attaching logs. Does it matter that these logs are from 2 hours after when the problem happened? Do you need a log closer to when the event happened? ffmpeg-directstream-d44f81a8-7f90-4027-979c-9777b3ef2456_1 (1).txt ffmpeg-transcode-716d5f4e-c76d-468f-bc1e-0d46b4e385d7_1 (1).txt embyserver.txt Edited December 17, 2020 by dovedescent7
dovedescent7 3 Posted December 17, 2020 Author Posted December 17, 2020 Ok, i'm not sure what is going on. Very confused... As i just looked again AND FOUND the Converted ts to mp4 of the show in question and it works perfectly.... Whereas i previously found only the 5gb .ts file from emby, the file that didnt work. All i can think of is: I recently (today) changed setting in MCEbuddy to Delete the .ts file after/while converting and i am thinking that somehow MCE tried to delete the .ts file while we were watching it in Emby? btw i deselected that option now Hoping the logs will tell you guys something.
Luke 42204 Posted December 18, 2020 Posted December 18, 2020 Hi, what exactly were you trying to play?
