Luke 42239 Posted October 5, 2021 Posted October 5, 2021 On 10/1/2021 at 3:20 PM, elpoolet said: Sure it's sufficient, but I guessed if it's possible to deal with some priority eg : - If I'm on LAN on WebBrowser, VP9 with high bitrate, then H264 with high bitrate, then VP9 low BR... etc - If I'm on WAN on WebBrowser, VP9 low bitrate, h264 low birate, VP9 high bitrate.... then transcode - If I'm on TV , 4k AV1, then 4k vp9, then 4k hevc, then 1080p vp9.... Yes I'm trying to avoid transcoding "on the fly". When I got a media wich requires transcoding, I re-encode it with VP9 codec wich is the most compatible and efficient (quality/bitrate ratio) but requires LOOOOOT of time ! Are you saying there is a case now where it transcodes when it could otherwise direct play a different version?
elpoolet 26 Posted October 5, 2021 Posted October 5, 2021 (edited) 2 hours ago, Luke said: Are you saying there is a case now where it transcodes when it could otherwise direct play a different version? Yes. Sometimes especially when I'm on WAN, If I have 2 versions : h264 8Mbps and vp9 2Mbps, the selected version is h264 and if the auto-quality determined a bandwith aroud 3 Mbps, there's a transcoding of the h264 version even if the vp9 one would play without transcoding. I hope I'm clear. Edited October 5, 2021 by elpoolet
Luke 42239 Posted October 6, 2021 Posted October 6, 2021 On 10/5/2021 at 2:44 PM, elpoolet said: Yes. Sometimes especially when I'm on WAN, If I have 2 versions : h264 8Mbps and vp9 2Mbps, the selected version is h264 and if the auto-quality determined a bandwith aroud 3 Mbps, there's a transcoding of the h264 version even if the vp9 one would play without transcoding. I hope I'm clear. Can you zip up the vp9 file and attach it here? That should not happen. Is this in the web app?
elpoolet 26 Posted October 6, 2021 Posted October 6, 2021 Yes it's in the WebApp. The VP9 file is 1.6GB large, h264 4.5GB So I uploaded it to SwissTransfer. Here are the links : VP9 : https://www.swisstransfer.com/d/028fab7c-64d6-463a-8307-23060da19cae h264 : https://www.transfernow.net/dl/20211006beU5GAj2
elpoolet 26 Posted October 7, 2021 Posted October 7, 2021 @luke And as a plus, I use Chrome 94 as a browser.
Luke 42239 Posted October 7, 2021 Posted October 7, 2021 3 hours ago, elpoolet said: @luke And as a plus, I use Chrome 94 as a browser. OK we'd have to look at the ffmpeg log because I tested and it worked as expected. I set the quality setting to 3 mbps, and it picked the vp9 file.
elpoolet 26 Posted October 7, 2021 Posted October 7, 2021 Hi @Luke Here's the ffmpeg log. Many thanks again for your time ffmpeg-transcode-981ecdfe-8b91-4d5d-b6f7-57e8be34a379_1.txt
Luke 42239 Posted October 7, 2021 Posted October 7, 2021 2 hours ago, elpoolet said: Hi @Luke Here's the ffmpeg log. Many thanks again for your time ffmpeg-transcode-981ecdfe-8b91-4d5d-b6f7-57e8be34a379_1.txt 88.18 kB · 0 downloads You set the quality setting to 2 mbps, but the bitrate of the vp9 version is slightly higher than that.
elpoolet 26 Posted October 8, 2021 Posted October 8, 2021 Hi @Luke Thanks for you answer. I encoded the video with VP9 at 1Mbps, and then it picked the vp9 file when playing and the bandwidth is at 2Mbps. Thanks
Luke 42239 Posted January 8, 2025 Posted January 8, 2025 Hi, can you please try the latest sideload build and let us know if this is resolved? It has an updated build of exoplayer. https://emby.media/emby-for-android.html Thanks.
