sjlcjl 5 Posted December 16, 2020 Posted December 16, 2020 I'm having issues with reliability of using the gear icon mainly when doing Live TV.. I can get over to it, but when I select it, it locks up the app and in about 10-15 seconds I'm sent back to the main Emby screen... Also have issues when pulling it up on some full sized blue rays and it causing audio to stutter... I'm bitstreaming by the way... Is this a known issue?
Luke 42246 Posted December 16, 2020 Posted December 16, 2020 Hi there, what version of the app are you running?
sjlcjl 5 Posted December 16, 2020 Author Posted December 16, 2020 (edited) Hi Luke, thanks for the response.. From the app info on my Shield it appears I am running 1.8.54g.. Does that seem correct? Edited December 16, 2020 by sjlcjl
FrostByte 5454 Posted December 16, 2020 Posted December 16, 2020 I don't recall seeing any reports of a problem with that button in .54, but there is a hotkey for the stats. Doing a long press of the Enter button will toggle the stats screen. ebr might need you to send him logs. 1
sjlcjl 5 Posted December 16, 2020 Author Posted December 16, 2020 (edited) Great bit of info on the long press.. Worked great.. Then tried by using the gear and it froze again.. And then of course that means when the app breaks the stream stays open for the tuner and my drive just starts filling up again till I restart the server app.. Edited December 16, 2020 by sjlcjl
CBers 7554 Posted December 16, 2020 Posted December 16, 2020 45 minutes ago, sjlcjl said: I'm having issues with reliability of using the gear icon mainly when doing Live TV.. I can get over to it, but when I select it, it locks up the app and in about 10-15 seconds I'm sent back to the main Emby screen... Also have issues when pulling it up on some full sized blue rays and it causing audio to stutter... I'm bitstreaming by the way... Is this a known issue? Yes, but is fixed in the latest beta releases since 54 was released. 1
sjlcjl 5 Posted December 16, 2020 Author Posted December 16, 2020 1 minute ago, CBers said: Yes, but is fixed in the latest beta releases since 54 was released. Thank you... 54 is the latest stable release, correct? I mean, I am running the latest that is not beta, correct?
FrostByte 5454 Posted December 16, 2020 Posted December 16, 2020 Yes, .55 was the first beta version this round. You could load the latest beta apk without joining the beta if you want the fix 1
CBers 7554 Posted December 16, 2020 Posted December 16, 2020 Just now, sjlcjl said: Thank you... 54 is the latest stable release, correct? I mean, I am running the latest that is not beta, correct? Yes, 54 is the latest Stable. You can sideload the latest beta if you know how to. 1
sjlcjl 5 Posted December 16, 2020 Author Posted December 16, 2020 Thanks for the prompt responses everyone.. 2
