jsmith124 1 Posted December 16, 2020 Posted December 16, 2020 (edited) I have been playing aroudn with Emby the last couple weeks and love it, Works great in my home for live tv/dvr. But im not able to access it outside my network, I have added the Port to forward. Not using SSL, But still no luck. My server is hardwired from my switch panel that's plugged into my cogeco ARRIS router. The network also has a unfi access point working out in my garage as just a wifi repeater if that helps. Edited December 17, 2020 by Happy2Play Removed images with external address
Abobader 3485 Posted December 16, 2020 Posted December 16, 2020 Hello jsmith124, Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: How to Report a Problem Thank you. Emby Team
Carlo 4561 Posted December 16, 2020 Posted December 16, 2020 Hi, If you go to https://www.canyouseeme.org/ does this give you the same IP address as what Emby Shows? If you run that test with 8096 for the port does it show it not open?
jsmith124 1 Posted December 16, 2020 Author Posted December 16, 2020 (edited) @cayars It gives me the IP address but the port says its not open Edited December 17, 2020 by Abobader Remove ip image
Carlo 4561 Posted December 16, 2020 Posted December 16, 2020 If you like I can do a remote session with you and take a look at your settings/setup and see if I see anything. If you want to do this download and install Teamviewer from www.teamviewer.com then send me via PM the ID and one-time use passcode you get on startup. Carlo
jsmith124 1 Posted December 16, 2020 Author Posted December 16, 2020 @cayars Thank you I inboxed you my teamviewer info!
jsmith124 1 Posted December 16, 2020 Author Posted December 16, 2020 @cayars has resolved the issue and I can now access it outside the network. Thank you for your help! 1
Solution Carlo 4561 Posted December 16, 2020 Solution Posted December 16, 2020 Stupid Arris modem that didn't allow port forwarding to work even though it was setup correctly because of other firewall blocking settings the took priority over port forwarding. Kind of have the wrong order of processing for those options. But regardless, we got it fixed, open and working for remote use. 2
Abobader 3485 Posted December 16, 2020 Posted December 16, 2020 Well, firewall always have the highest priority in any OS I make this as resolved.
Carlo 4561 Posted December 16, 2020 Posted December 16, 2020 Problem is you want things like IDS protection, DOS protection but want exceptions to allow specific ports through the router not bound by other settings. This modem applies things backwards from other modems.
pwhodges 2028 Posted December 16, 2020 Posted December 16, 2020 The OP might like to remove his external IP from the images. Paul 1
Abobader 3485 Posted December 17, 2020 Posted December 17, 2020 1 hour ago, pwhodges said: The OP might like to remove his external IP from the images. Paul Done.
