charlyp 1 Posted December 16, 2020 Posted December 16, 2020 (edited) Hi, I've just installed Emby on my F4-210 (TOS 4.1.32) and added all my movies yesterday. I started adding the TV shows last night and went to bed. This morning, most shows are okay, but some need to be manually identified. So I started doing that and found out something was wrong. The Web interface is really slow when identifying TV shows: the show posters don't show up on the choosing screen, they remain grey squares. When choosing one, the validation takes very long, sometimes ages. I tried for a few TV shows and it was still very slow each time, sometimes so slow it looks like it's stuck. The TerraMaster resource monitor shows EmbyServer using ~100% CPU and ~20% memory. The main CPU usage is about ~30% (it's usually 1-2%) and ~40% total memory. Up to now, the NAS was used for Time Machine backups only so except for Emby, it's mainly idle. I've attached the latest EmbyServer log. EDIT: I've been monitoring for a while and the EmbyServer process is now back to normal CPU usage, so I guess it was finishing indexing or something. However, the selection screen when identifying a TV show still doesn't show up any posters, which is a problem to correctly identifying shows —this doesn't happen when identifying movies. I've attached a screenshot. Thanks in advance for your help! Ch. embyserver.txt Edited December 16, 2020 by charlyp Additional information
Luke 42237 Posted December 17, 2020 Posted December 17, 2020 Hi, yes the initial scan can consume some resources temporarily. What version of emby server do you have now?
charlyp 1 Posted December 17, 2020 Author Posted December 17, 2020 Hi Luke, I have version 4.5.2.0 running. I just tried identification again: posters are still missing for TV shows, no problem with movies. Ch.
Luke 42237 Posted December 17, 2020 Posted December 17, 2020 What metadata and image fetchers are enabled on the library, and in what order?
charlyp 1 Posted December 17, 2020 Author Posted December 17, 2020 Ahhh, I see what you mean. Here's what I have, in this order: Metadata Downloaders Series Season Episode TheTVDB TheMovieDb TheTVDB TheMovieDb AniDB AniDB AniDB Image Fetchers Series Season Episode TheTVDB TheTVDB TheTVDB FanArt Screen Grabber Should I try to set the same sources for both metadata and images? Ch.
Luke 42237 Posted December 18, 2020 Posted December 18, 2020 Try removing the anime plugin, then restart the server and see if that helps with your cpu usage.
charlyp 1 Posted December 18, 2020 Author Posted December 18, 2020 As I wrote in my second message, the CPU usage wasn't a problem anymore. I removed the Anime plugin anyway. I changed the image fetchers selection to reflect the metadata's, but there's still no poster when identifying TV shows —and only TV shows. Ch.
Luke 42237 Posted December 18, 2020 Posted December 18, 2020 Please try it again and then attach the emby server log. thanks.
charlyp 1 Posted December 18, 2020 Author Posted December 18, 2020 Okay, just tried again: same thing. Screenshot + log attached. Ch. embyserver.txt
Luke 42237 Posted December 18, 2020 Posted December 18, 2020 There's nothing obvious there, no errors, so it appears the downloads for those posters might just be happening very slowly. In the meantime you could still try completing the identify process and see what happens after that.
charlyp 1 Posted December 18, 2020 Author Posted December 18, 2020 I already did. I completed the TV shows yesterday, without seeing the posters. Sometimes, the poster shows up immediately on the TV shows list, sometimes it doesn't so I have to edit it manually. So it's all okay, my library is now complete. But still, there's something wrong that I hoped could get fixed for the futur imports. And posters really help identifying the right show Ch.
Solution charlyp 1 Posted December 18, 2020 Author Solution Posted December 18, 2020 Okay, clearly inspired by one of your previous messages, I changed the image fetchers (and metadata) order to put TheMovieDb first and now the posters show up when identifying TV shows. Cool. Thanks for your help! Ch.
