moviefan 187 Posted August 1, 2014 Posted August 1, 2014 Just noticed some of my TV shows werent showing up so I went to scheduled tasks and found that auto Organize is no longer running on schedule... Even though it is configured to run every 15 minutes.... I upgraded to server version 3.0.5326.13255 this morning when I saw it come out so the server has been rebooted within the last 24 hours. Anyone else seeing this behavior? I just ran manual organize and it worked fine. Then 15 minutes later still isn't organizing... i'll upload some logs when I get back but anyone else seeing this? 1
moviefan 187 Posted August 2, 2014 Author Posted August 2, 2014 Log attached after reboot and auto-organize still not working..
Koleckai Silvestri 1154 Posted August 2, 2014 Posted August 2, 2014 Same occurred to me. Last time it ran automatically was July 30th. Don't currently have the logs.
Rominator 7 Posted August 2, 2014 Posted August 2, 2014 (edited) I have never used Auto Organize, but after installing the new server version 3.0.5326.13255 i see the following entrys in my log file every 5 minutes. 2014-08-02 04:57:26.1090 Info - App: IntervalTrigger fired for task: Organize new media files2014-08-02 04:57:26.1090 Info - App: Executing Organize new media files2014-08-02 04:57:26.1170 Info - App: Organize new media files Completed after 0 minute(s) and 0 seconds2014-08-02 05:02:27.1212 Info - App: IntervalTrigger fired for task: Organize new media files2014-08-02 05:02:27.1212 Info - App: Executing Organize new media files2014-08-02 05:02:27.1212 Info - App: Organize new media files Completed after 0 minute(s) and 0 seconds2014-08-02 05:07:28.1414 Info - App: IntervalTrigger fired for task: Organize new media files2014-08-02 05:07:28.1414 Info - App: Executing Organize new media files2014-08-02 05:07:28.1414 Info - App: Organize new media files Completed after 0 minute(s) and 0 seconds2014-08-02 05:12:29.1606 Info - App: IntervalTrigger fired for task: Organize new media files2014-08-02 05:12:29.1606 Info - App: Executing Organize new media files2014-08-02 05:12:29.1606 Info - App: Organize new media files Completed after 0 minute(s) and 0 seconds2014-08-02 05:17:30.1809 Info - App: IntervalTrigger fired for task: Organize new media files2014-08-02 05:17:30.1809 Info - App: Executing Organize new media files2014-08-02 05:17:30.1809 Info - App: Organize new media files Completed after 0 minute(s) and 0 seconds Edited August 2, 2014 by Rominator
swhitmore 781 Posted August 2, 2014 Posted August 2, 2014 (edited) I also just noticed mine has been running when not enabled. That explains why SickBeard wasn't updating. Edited August 2, 2014 by swhitmore
Solution Luke 42183 Posted August 2, 2014 Solution Posted August 2, 2014 Confirmed, it's running opposite of when it should. it will be fixed soon. in the meantime just run manually. 1
tmservo 2 Posted August 4, 2014 Posted August 4, 2014 Since updating to Version 3.0.5326.13255, Auto-Organize isn't automatic. Oh, the task runs just fine if I go to Advanced and tell it to run the task, and it works great then.. but it used to seemingly run every few minutes. I put in another task trigger for it to run every 15 minutes.. but nope, it doesn't respect that either.. I get where it says: "last ru: 8 hours ago" etc. in the morning and so it hasn't pulled in anything.
swhitmore 781 Posted August 4, 2014 Posted August 4, 2014 Since updating to Version 3.0.5326.13255, Auto-Organize isn't automatic. Yes, this is confirmed as a bug. Please see the post above yours.
Koleckai Silvestri 1154 Posted August 4, 2014 Posted August 4, 2014 Seems to be working again with the latest dev version. Will have to keep an eye on it.
Dazik 46 Posted August 5, 2014 Posted August 5, 2014 (edited) Hello, With the latest update to MBS (Version 3.0.5326.13255) it seems the "Organize new media files" task no longer runs without running it manually. Not sure if I'm missing a new configuration item to change this or not? In any case, bit problematic as I have quite a bit of things auto-download using Media Center Master every day and I really have no way to see what's been downloaded (if anything) without it running on it's own when it detects new files. Is there any fix I can do manually for this? Edit: My mistake for not seeing that. Edited August 5, 2014 by akensai
lolento 1 Posted August 6, 2014 Posted August 6, 2014 Is anybody seeing this problem? The auto organize function stopped working on a schedule as of two days ago...I believe there was an MBS update but can't remember. Manual trigger still works fine.
Koleckai Silvestri 1154 Posted August 6, 2014 Posted August 6, 2014 It should be fixed in an upcoming release.
ebr 16306 Posted August 7, 2014 Posted August 7, 2014 Is anybody seeing this problem? The auto organize function stopped working on a schedule as of two days ago...I believe there was an MBS update but can't remember. Manual trigger still works fine. Confirmed, it's running opposite of when it should. it will be fixed soon. in the meantime just run manually.
