netzgauner 0 Posted December 15, 2020 Posted December 15, 2020 Hallo, habe an meinem Server einen Benutzer erstellt und Ihn mit einem emby connect Konto verbunden. (Email bestätigt) Mein Server erscheint auch auf der Seite https://app.emby.media Wenn ich mich aber Verbinden möchte erschein Verbindungsfehler. Ports 8096 und 8920 sind geöffnet im OS (ubuntu 20.04) und Router. Die möglichkeit für HTTPS also Port 8920 wird seltsamerweise auf der Übersicht nicht angezeigt??? Kann mir jemand weiterhelfen was noch fehlt oder falsch ist? embyserver_log.txt
Luke 42241 Posted December 15, 2020 Posted December 15, 2020 Hi there, in order to use https, you need to setup an SSL certificate in Emby Server network settings, or setup a reverse proxy. Have you done that?
netzgauner 0 Posted December 15, 2020 Author Posted December 15, 2020 Hi thanks for the answer. No. but I'm also more concerned with the connection problem with emby connect.
Solution Luke 42241 Posted December 15, 2020 Solution Posted December 15, 2020 If you don't have https setup on your emby server, then you need to use the http version at http://app.emby.media
netzgauner 0 Posted December 15, 2020 Author Posted December 15, 2020 I see. ok then it's clear. but an unsecured transmission is out of the question. Can the certificate be self-signed?
Luke 42241 Posted December 15, 2020 Posted December 15, 2020 42 minutes ago, netzgauner said: I see. ok then it's clear. but an unsecured transmission is out of the question. Can the certificate be self-signed? The login requests to our Emby Connect servers are still done over https either way. You can use a self-signed certificate, but you may need to override the browser to force it to accept. And then with Emby apps on other devices, you may see connection failures if the devices don't accept your certificate. On some platforms we can force it to accept your self-signed certificate, but on many others we can't. That ends up leaving you with the choice of either using a trusted certificate, or not using one at all.
