zebo51 22 Posted December 15, 2020 Posted December 15, 2020 For some reason some collections are getting the green Box Set image and others are getting the blue with discs on the sides. I prefer the blue case with discs, but not sure how to make them all like that. The collections contain bluray movies, IE The Grudge consists of 720 bluray movies. Here is my configuration. Any ideas on how to fix and make all the same, at least for BluRay?
Happy2Play 9814 Posted December 15, 2020 Posted December 15, 2020 3 hours ago, Luke said: @Happy2Play have you seen this before? I would guess there are image processing errors in the log or issues in the cache folder. All Boxset treatment are Green with Boxset label. Please post a server log @zebo51
zebo51 22 Posted December 15, 2020 Author Posted December 15, 2020 1 hour ago, Happy2Play said: I would guess there are image processing errors in the log or issues in the cache folder. All Boxset treatment are Green with Boxset label. Please post a server log @zebo51 Sent a link in PM for server log. Thanks
Happy2Play 9814 Posted December 15, 2020 Posted December 15, 2020 Not seeing anything in the log that stands out or Coverart related. added devs to the pm. If you changed the Boxset treatment to something else does it change?
ebr 16346 Posted December 15, 2020 Posted December 15, 2020 Hi. Did you setup multiple profiles in CoverArt?
zebo51 22 Posted December 15, 2020 Author Posted December 15, 2020 59 minutes ago, Happy2Play said: Not seeing anything in the log that stands out or Coverart related. added devs to the pm. If you changed the Boxset treatment to something else does it change? Yes, tried about 5 other treatments and they all change to be the same. When I go back to my original, it shows as the screen shot I provided. 59 minutes ago, ebr said: Hi. Did you setup multiple profiles in CoverArt? I only have the default profile.
Solution Happy2Play 9814 Posted December 15, 2020 Solution Posted December 15, 2020 (edited) Sounds like a issue with the cache images. I would delete the \cache\images\enhanced-images and let then rebuild to see if it resolves your issue. You can see your cache location on the Dashboard. Edited December 15, 2020 by Happy2Play
zebo51 22 Posted December 15, 2020 Author Posted December 15, 2020 1 hour ago, Happy2Play said: Sounds like a issue with the cache images. I would delete the \cache\images\enhanced-images and let then rebuild to see if it resolves your issue. You can see your cache location on the Dashboard. Delete the folder itself, or the folders in that location? Folder 0-9 and a-f. Is the rebuild automatic or something I need to do?
Happy2Play 9814 Posted December 15, 2020 Posted December 15, 2020 18 minutes ago, zebo51 said: Delete the folder itself, or the folders in that location? Folder 0-9 and a-f. Is the rebuild automatic or something I need to do? Doesn't matter. All you have to do is navigate pages to regenerate.
zebo51 22 Posted December 16, 2020 Author Posted December 16, 2020 56 minutes ago, Happy2Play said: Doesn't matter. All you have to do is navigate pages to regenerate. That worked. All the ones that contain bluray's are blue and older ones with DVDs are gray. Thanks
