sc4nd4l 0 Posted December 15, 2020 Posted December 15, 2020 Hi, Some of my libraries are added but not viewable as regular viewing. The content is under "Folders" instead (se attachement) Any idea why and how to fix it?
Luke 42246 Posted December 15, 2020 Posted December 15, 2020 Hi there, how many emby libraries have you setup and what folders did you add to each one?
sc4nd4l 0 Posted December 15, 2020 Author Posted December 15, 2020 (edited) Hi, I have 6 libraries total. The folder is directly to the folder containing the content. Other libraries that has the same structure works without any issues like this. Paths are: /mnt/sc4/Movies/Movies-4K , /mnt/sc4/Movies/Movies , /mnt/sc4/TV/TV etc Edited December 15, 2020 by sc4nd4l
Luke 42246 Posted December 15, 2020 Posted December 15, 2020 Can you please list all of the paths? Thanks.
sc4nd4l 0 Posted December 16, 2020 Author Posted December 16, 2020 Hi again, /mnt/sc4/Movies/Movies /mnt/sc4/Movies/Movies-4K /mnt/sc4/Movies/Movies-Kids /mnt/sc4/TV/TV /mnt/sc4/TV/TV-4K /mnt/sc4/TV/TV-Kids
Luke 42246 Posted December 17, 2020 Posted December 17, 2020 So those are six different libraries, each with one folder?
sc4nd4l 0 Posted December 17, 2020 Author Posted December 17, 2020 6 minutes ago, Luke said: So those are six different libraries, each with one folder? Correct
sc4nd4l 0 Posted December 17, 2020 Author Posted December 17, 2020 7 minutes ago, Luke said: Which libraries are coming up empty? Movies-4K & Movies-Kids - Content is there but only when I select "folders" as the screen in the first post shows
Happy2Play 9814 Posted December 17, 2020 Posted December 17, 2020 4 minutes ago, sc4nd4l said: Movies-4K & Movies-Kids - Content is there but only when I select "folders" as the screen in the first post shows Do those library items appear in the library that displays properly? It does sound like a parent folder library issue.
sc4nd4l 0 Posted December 17, 2020 Author Posted December 17, 2020 15 minutes ago, Happy2Play said: Do those library items appear in the library that displays properly? It does sound like a parent folder library issue. Its displays properly if I press "Folders". But the setup in my gdrive is:
Happy2Play 9814 Posted December 17, 2020 Posted December 17, 2020 2 minutes ago, sc4nd4l said: Its displays properly if I press "Folders". But the setup in my gdrive is: Right but you are saying Movies\Movies appear properly, so my question is do those movies from say Movies-4K appear there also?
sc4nd4l 0 Posted December 17, 2020 Author Posted December 17, 2020 3 minutes ago, Happy2Play said: Right but you are saying Movies\Movies appear properly, so my question is do those movies from say Movies-4K appear there also? This is how the Movies-4K looks in my server after I pressed "Folders":
Happy2Play 9814 Posted December 17, 2020 Posted December 17, 2020 But that is not the question. Do you see these library items that only show in folder view in your Movies\Movies library?
sc4nd4l 0 Posted December 17, 2020 Author Posted December 17, 2020 (edited) 1 minute ago, Happy2Play said: But that is not the question. Do you see these library items that only show in folder view in your Movies\Movies library? Yes! Movies from the Movies/Movies library is viewed with no issues EDIT: In the Movies/Movies library under "Folders" i see all folders Edited December 17, 2020 by sc4nd4l
Happy2Play 9814 Posted December 17, 2020 Posted December 17, 2020 (edited) That means the paths you have provided can not be correct as Movies\Movies has to be a parent folder with the other two being children\subfolders. Can you show exactly the folder path provided for exact library. Edited December 17, 2020 by Happy2Play
Happy2Play 9814 Posted December 17, 2020 Posted December 17, 2020 3 minutes ago, sc4nd4l said: Yes! Movies from the Movies/Movies library is viewed with no issues Misread, but that still is not the question I asked.
sc4nd4l 0 Posted December 17, 2020 Author Posted December 17, 2020 (edited) 3 minutes ago, Happy2Play said: That means the paths you have provided can not be correct as Movies\Movies has to be a parent folder with the other two being children\subfolders. Can you show exactly the folder path provided for exact library. I understand that, but TV is not having the same issue. Quote Can you show exactly the folder path provided for exact library. Paths: /mnt/sc4/Movies/Movies /mnt/sc4/Movies/Movies-4K /mnt/sc4/Movies/Movies-Kids Edited December 17, 2020 by sc4nd4l
sc4nd4l 0 Posted December 17, 2020 Author Posted December 17, 2020 Just now, Happy2Play said: Misread, but that still is not the question I asked. Not quite sure on what you mean in the question you're asking
Happy2Play 9814 Posted December 17, 2020 Posted December 17, 2020 (edited) 9 minutes ago, sc4nd4l said: Yes! Movies from the Movies/Movies library is viewed with no issues EDIT: In the Movies/Movies library under "Folders" i see all folders Okay so this image shows you can not create libraries that are subfolder of any other library. Emby will not allow it. The exact same will apply to TV assuming you are building libraries the same. You would have to add all these folder specificly to Movies for it to work. Edited December 17, 2020 by Happy2Play
sc4nd4l 0 Posted December 17, 2020 Author Posted December 17, 2020 1 minute ago, Happy2Play said: Okay so this image shows you can not create libraries that are subfolder of any other library. Emby will not allow it. The exact same will apply to TV assuming you are building libraries the same. You would have to add all these folder specificly to Movies for it to work. TV has the same structure as you can see above in the paths list. But this does not happen with the TV libraries which is why i'm confused.
Happy2Play 9814 Posted December 17, 2020 Posted December 17, 2020 Just now, sc4nd4l said: TV has the same structure as you can see above in the paths list. But this does not happen with the TV libraries which is why i'm confused. It is probably easier for you to provide a screenshot of Dashboard-Library. But Emby will not allow a subfolder library of any parent library.
Solution Happy2Play 9814 Posted December 17, 2020 Solution Posted December 17, 2020 14 minutes ago, sc4nd4l said: This image proves the library path is /mnt/sc4/Movies not /mnt/sc4/Movies/Movies as it lists all subfolder libraries.
sc4nd4l 0 Posted December 17, 2020 Author Posted December 17, 2020 29 minutes ago, Happy2Play said: This image proves the library path is /mnt/sc4/Movies not /mnt/sc4/Movies/Movies as it lists all subfolder libraries. Damn, i'm stupid! That of course fixed the issue. Sorry for all the un-needed help here due to my lack of viewing that mistake! Thanks!
Happy2Play 9814 Posted December 17, 2020 Posted December 17, 2020 No worries, glad we got the issue resolved.
