troyhough 61 Posted December 15, 2020 Posted December 15, 2020 All of a sudden all of my devices that use the Emby Connect method (6 or 7 devices in the last 2 days) are asking me to sign back in. When I choose the "Connect" method and confirm the pin it just does a loop. Never actually signs in. I have to manually enter the IP address on all devices to get it to work. This is kind of a pain???
Luke 42204 Posted December 15, 2020 Posted December 15, 2020 Hi, seems to be working OK from here. I would try relinking your local user to Emby Connect. Sounds like you have deleted that.
troyhough 61 Posted December 15, 2020 Author Posted December 15, 2020 2 minutes ago, Luke said: Hi, seems to be working OK from here. I would try relinking your local user to Emby Connect. Sounds like you have deleted that. You were correct! How does this happen? This is not the first time this has happened and I never go in there and make any changes????
Luke 42204 Posted December 15, 2020 Posted December 15, 2020 Either from accidentally removing it or deleting the server from within one of the apps.
troyhough 61 Posted December 15, 2020 Author Posted December 15, 2020 2 hours ago, Luke said: Either from accidentally removing it or deleting the server from within one of the apps. Definitely didn't do either of those and this has happened twice in the last couple months
