jlficken 3 Posted December 14, 2020 Posted December 14, 2020 I have the Recording library set up with a Conversion task to make them all MP4's but they seem to be failing. I have attached a log but I'm not sure what the actual problem is. ffmpeg-transcode-23984485-5319-433d-b25f-3d3040f08bef_1.txt
Luke 42243 Posted December 14, 2020 Posted December 14, 2020 Hi, you customized some server transcoding settings. Try setting these back to default and see if that helps: Warning EncoderParametersH264LibX.ConstantRateFactor: Original: 23 Actual: 18 Warning EncoderParametersH264LibX.Preset: Original: veryfast Actual: veryslow
jlficken 3 Posted December 14, 2020 Author Posted December 14, 2020 Didn't seem to make a difference. ffmpeg-transcode-ee65e265-b9d2-4a00-8195-8cb058746dc0_1.txt
jlficken 3 Posted December 14, 2020 Author Posted December 14, 2020 I can get you a copy of one of the videos of you want it? They are coming from a SiliconDust HDHomerun Quadro.
Carlo 4561 Posted December 15, 2020 Posted December 15, 2020 Hi, can you take a screen shot or two of your TRANSCODING setup screen?
Carlo 4561 Posted December 15, 2020 Posted December 15, 2020 Can't actually read it as the things are to small. Can you try something. Turn off Hardware transcoding so it's using CPU and try a test conversion on a file and let's see what happens.
jlficken 3 Posted December 15, 2020 Author Posted December 15, 2020 1 hour ago, cayars said: Can't actually read it as the things are to small. Can you try something. Turn off Hardware transcoding so it's using CPU and try a test conversion on a file and let's see what happens. Did you click on the image as it seems plenty big enough to read to me? Also, I tried it with Hardware Transcoding disabled and it still failed. Log attached... Also, could you request that the Convert screen close once you click on the "Convert" button as right now it just stays open and doesn't give any confirmation that the conversion job has been set up. I've had people create 10 of the same conversion jobs because there's no confirmation. ffmpeg-transcode-350951ab-7fb2-41d9-a12e-62d7ac20af07_1.txt
Luke 42243 Posted December 15, 2020 Posted December 15, 2020 19 hours ago, jlficken said: Didn't seem to make a difference. ffmpeg-transcode-ee65e265-b9d2-4a00-8195-8cb058746dc0_1.txt 21.9 kB · 2 downloads As a test, you could try turning off hardware transcoding and see if that helps.
jlficken 3 Posted December 15, 2020 Author Posted December 15, 2020 8 minutes ago, Luke said: As a test, you could try turning off hardware transcoding and see if that helps. Tried that. The log is in the post above yours.
jlficken 3 Posted December 15, 2020 Author Posted December 15, 2020 Here's the latest attempt with hardware transcoding off and transcoding settings restored to defaults. ffmpeg-transcode-6a11036b-6ac7-48f8-9550-4f5b7170af01_1.txt
jlficken 3 Posted December 15, 2020 Author Posted December 15, 2020 Could this line have anything to do with it? 13:16:56.269 [mpeg2video @ 0x693140] Invalid frame dimensions 0x0.
Carlo 4561 Posted December 15, 2020 Posted December 15, 2020 4 minutes ago, jlficken said: 13:16:56.269 [mpeg2video @ 0x693140] Invalid frame dimensions 0x0. or 13:17:14.415 Too many packets buffered for output stream 0:1. @softworkz do you have any insight on this?
jlficken 3 Posted December 15, 2020 Author Posted December 15, 2020 Just now, cayars said: or 13:17:14.415 Too many packets buffered for output stream 0:1. @softworkz do you have any insight on this? Yeah that's the one that I initially suspected but I saw the other error as well.
jlficken 3 Posted December 15, 2020 Author Posted December 15, 2020 (edited) Here are the 2 files that I've been testing with. The links will work until 12/17/2020. https://nextcloud.firestarter.info/s/ebfHQPCgHcfKX2D https://nextcloud.firestarter.info/s/SNgxj4Pint3rYXq Edited December 15, 2020 by jlficken
Luke 42243 Posted December 21, 2020 Posted December 21, 2020 Hi, sorry, I missed this. Would you mind providing one of them again? Thanks.
jlficken 3 Posted December 21, 2020 Author Posted December 21, 2020 (edited) Here you go: It's good for a week. https://nextcloud.firestarter.info/s/ZK3HkzZDWsZ4Cz5 https://nextcloud.firestarter.info/s/TfnsrqZbZ9ZpmeP Edited December 21, 2020 by jlficken
jlficken 3 Posted December 30, 2020 Author Posted December 30, 2020 (edited) @Luke Just wanted to make sure you got the files downloaded? Edited December 30, 2020 by jlficken
Luke 42243 Posted February 23, 2021 Posted February 23, 2021 I'm sorry I missed them again. Are you still running into this with Emby Server 4.5.4?
Luke 42243 Posted June 18, 2021 Posted June 18, 2021 @jlficken can you please try this with Emby Server 4.6.3? Please let us know if this resolves the issue. Thanks !
softworkz 5133 Posted August 8, 2021 Posted August 8, 2021 @jlficken - The latest Emby Server Beta includes a new and updated ffmpeg where the error you were experiencing should finally be fixed. If you don't mind trying a beta version, you could download Beta 4.7.0.6 (or later) and check whether it works for you. Thanks, sw 1
