kferrone 0 Posted December 14, 2020 Posted December 14, 2020 So I have an actual server which is public on wan, the other is just my windows desktop. When logging in to Emby I can only add the public one, obviously. Then going back into Emby it magically adds the server from my desktop as an option, even at my brother's place, and then defaults to it. Obviously I can't log into it. Why is my private desktop which isn't even public the default option???? Seems the public Emby sees the other one on the network and auto adds it as a server option. How to disable this???
Luke 42204 Posted December 14, 2020 Posted December 14, 2020 Hi, it was either linked to emby connect or the app discovered it on the local network. You can simply remove it using the controls on the server selection screen.
