zushl 2 Posted December 13, 2020 Posted December 13, 2020 and another question How to use two subtitles at the same time
Luke 42204 Posted December 13, 2020 Posted December 13, 2020 Hi, you can't use two subtitles at the same time.
zushl 2 Posted December 15, 2020 Author Posted December 15, 2020 sometimes,i have cht subtitles in local disk my local settings are chs and intelligent so i need change local file name to .chs , choose cht in setting website, or search in subtitle provider i think Simplified Chinese and Traditional Chinese are both Chinese Why not add a setting to mix chs and cht?
Luke 42204 Posted December 15, 2020 Posted December 15, 2020 Hi, well you can still use the subtitle file, but you'll just have to pick a name based on one of the languages. Does that help?
zushl 2 Posted December 21, 2020 Author Posted December 21, 2020 before i use subtitle,i should add a suffix name,it‘s too troublesome,if i want to use bilingual subtiles,i should change name,eg:chs&eng forced,or just add .chs,have any other simple method? recent time,i ues emby app on ios(iPad os ),I found that subtitle is to small, when use infuse the subtile is normal size. I have tried to change subtitle size In subtile option, it’s not work. How to change subtile size? The subtile is external .
Luke 42204 Posted December 23, 2020 Posted December 23, 2020 We're looking into the small subtitles issue. Thanks for reporting.
