ebr 16337 Posted February 26, 2021 Posted February 26, 2021 10 minutes ago, SilentAssassin said: Just installed the app you supplied and initial testing it plays back the 10bit files without tranacoding now. Excellent. Thanks. 1
SilentAssassin 96 Posted February 27, 2021 Posted February 27, 2021 21 hours ago, ebr said: Excellent. Thanks. Played some more 10bit files and they all direct stream.
judgey 13 Posted March 22, 2021 Posted March 22, 2021 Sorry to bump this, im having same probs was there a fix? Firestick 4k 10bit hevc
ebr 16337 Posted March 22, 2021 Posted March 22, 2021 56 minutes ago, judgey said: Sorry to bump this, im having same probs was there a fix? Firestick 4k 10bit hevc Hi. It should be fixed with the next release of the app. Thanks. 1
alphanet 0 Posted April 24, 2021 Posted April 24, 2021 On 2/24/2021 at 10:52 AM, ebr said: I'll stick the change I was contemplating in the next public beta. Thanks. Actually, that change is irrelevant now in the current beta. Have you tested with it? Please let me test the beta version, I have the same problem with the Fire Stick lite, my region is Amazon.com. Thanks
alphanet 0 Posted April 24, 2021 Posted April 24, 2021 4 minutes ago, cayars said: Ifollow the procedure for the fire tv stick this morning but I still haven't received a reply
alphanet 0 Posted April 24, 2021 Posted April 24, 2021 2 minutes ago, cayars said: Someone will get you added. Not read yet
Carlo 4561 Posted April 24, 2021 Posted April 24, 2021 He could be doing something with the family as it's a weekend. He will get you added.
Napsterbater 26 Posted September 19, 2021 Posted September 19, 2021 (edited) Seems this issue may be back? My firestick is having to transcode some HVEC which I think should play direct. Firestick 3rd Gen (2020), Model code: AFTSSS Edxit: Debug Log sent from device as well. 14:23:08.994 Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv, progressive), 1920x1080 [SAR 1:1 DAR 16:9], Level 120, 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc (default) ffmpeg-transcode-48d19b97-a2eb-455e-825c-c11ec43b84db_1.txt Edited September 19, 2021 by Napsterbater
ebr 16337 Posted September 20, 2021 Posted September 20, 2021 Hi. The device does not support hevc 10. 09-19 14:53:23.689 13737 13737 I System.out: *** Does NOT support HEVC 10 bit
Napsterbater 26 Posted September 20, 2021 Posted September 20, 2021 3 minutes ago, ebr said: Hi. The device does not support hevc 10. 09-19 14:53:23.689 13737 13737 I System.out: *** Does NOT support HEVC 10 bit Which is odd considering it is a Firestick 3rd Gen (2020), Model code: AFTSSS Ad per https://developer.amazon.com/docs/fire-tv/device-specifications-fire-tv-streaming-media-player.html?v=ftvstickgen3 Video codecs H.265 (HEVC). Hardware accelerated up to 1080p @ 60fps, 20 Mbps, Main 10 Profile Level 4.1, Color space 8-bit and 10-bit input with HDR10, HDR10+, and HLG. So is this a Amazon issue or Emby app issue?
Happy2Play 9812 Posted September 20, 2021 Posted September 20, 2021 It is the profile that is getting flagged Quote &VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,ac3,eac3,aac,mp3&VideoBitrate=79744000&AudioBitrate=256000&MaxHeight=1088&AudioStreamIndex=1&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&hevc-profile=Main&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&ac3-audiochannels=8&eac3-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=VideoProfileNotSupported So it would appear this device is not returning updated profile support or capabilities need updating for device.
Napsterbater 26 Posted September 20, 2021 Posted September 20, 2021 One thing I have noticed for a while that seems odd is "Level 120" Seems most if not all of my HEVC videos are reported as "Level 120" i.e. Level 12 which does not exist. Mediainfo reports "Format profile: Main 10@L4@Main", Level 4 From Emby videocam Video Title 1080p HEVC Codec HEVC Profile Main 10 Level 120 Resolution 1920x1080 Aspect Ratio 16:9 Interlaced No Framerate 23.976 Bitrate 938 kbps Bit Depth 10 bit Pixel Format yuv420p10le Reference Frames 1 audiotrack Audio Title English EAC3 5.1 (Default) Language English Codec EAC3 Layout 5.1 Channels 6 ch Bitrate 256 kbps Sample Rate 48,000 Hz Default Yes closed_caption Subtitle Title English (Default ASS) Embedded Title English Language English Codec ASS Default Yes Forced No External No And Mediainfo General Unique ID : 128216705637548137871353964714855626970 (0x6075A3A7943E4E32C6DA73EF38D9F8DA) Complete name : \\fileserver.napshome.local\MovieTVvideo\TV Shows\What We Do in the Shadows\S3\What.We.Do.in.the.Shadows.S03E01.HDTV-1080p-MeGusta.mkv Format : Matroska Format version : Version 4 File size : 163 MiB Duration : 24 min 19 s Overall bit rate : 939 kb/s Writing application : Lavf58.76.100 Writing library : Lavf58.76.100 ErrorDetectionType : Per level 1 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L4@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 24 min 19 s Bit rate : 664 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.013 Stream size : 116 MiB (71%) Writing library : x265 3.5+9-bf91444e0:[Windows][GCC 10.2.0][64 bit] 10bit Encoding settings : cpuid=1111039 / frame-threads=3 / numa-pools=12 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=1 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-eob / no-eos / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=3 / b-adapt=0 / b-pyramid / bframe-bias=0 / rc-lookahead=5 / lookahead-slices=6 / scenecut=0 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=32 / min-cu-size=16 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / no-signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=0 / no-limit-modes / me=0 / subme=0 / merange=57 / temporal-mvp / no-frame-dup / no-hme / no-weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / no-sao / no-sao-non-deblock / rd=2 / selective-sao=0 / early-skip / rskip / fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=23.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=0.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass Default : Yes Forced : No Color range : Limited Audio ID : 2 Format : E-AC-3 Format/Info : Enhanced AC-3 Commercial name : Dolby Digital Plus Codec ID : A_EAC3 Duration : 24 min 19 s Bit rate mode : Constant Bit rate : 256 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 32 bits Compression mode : Lossy Delay relative to video : 6 ms Stream size : 44.5 MiB (27%) Language : English Service kind : Complete Main Default : Yes Forced : No Text ID : 3 Format : ASS Codec ID : S_TEXT/ASS Codec ID/Info : Advanced Sub Station Alpha Duration : 24 min 18 s Compression mode : Lossless Title : English Writing library : Lavc58.134.100 ssa Language : English Default : Yes Forced : No Report created by : MediaInfoLib - v21.03 Report created on : UTC 2021-09-20 22:36:48
Happy2Play 9812 Posted September 20, 2021 Posted September 20, 2021 20 minutes ago, Napsterbater said: One thing I have noticed for a while that seems odd is "Level 120" Seems most if not all of my HEVC videos are reported as "Level 120" i.e. Level 12 which does not exist. Mediainfo reports "Format profile: Main 10@L4@Main", Level 4 From Emby videocam Video Title 1080p HEVC Codec HEVC Profile Main 10 Level 120 Resolution 1920x1080 Aspect Ratio 16:9 Interlaced No Framerate 23.976 Bitrate 938 kbps Bit Depth 10 bit Pixel Format yuv420p10le Reference Frames 1 audiotrack Audio Title English EAC3 5.1 (Default) Language English Codec EAC3 Layout 5.1 Channels 6 ch Bitrate 256 kbps Sample Rate 48,000 Hz Default Yes closed_caption Subtitle Title English (Default ASS) Embedded Title English Language English Codec ASS Default Yes Forced No External No And Mediainfo General Unique ID : 128216705637548137871353964714855626970 (0x6075A3A7943E4E32C6DA73EF38D9F8DA) Complete name : \\fileserver.napshome.local\MovieTVvideo\TV Shows\What We Do in the Shadows\S3\What.We.Do.in.the.Shadows.S03E01.HDTV-1080p-MeGusta.mkv Format : Matroska Format version : Version 4 File size : 163 MiB Duration : 24 min 19 s Overall bit rate : 939 kb/s Writing application : Lavf58.76.100 Writing library : Lavf58.76.100 ErrorDetectionType : Per level 1 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L4@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 24 min 19 s Bit rate : 664 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.013 Stream size : 116 MiB (71%) Writing library : x265 3.5+9-bf91444e0:[Windows][GCC 10.2.0][64 bit] 10bit Encoding settings : cpuid=1111039 / frame-threads=3 / numa-pools=12 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=1 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-eob / no-eos / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=3 / b-adapt=0 / b-pyramid / bframe-bias=0 / rc-lookahead=5 / lookahead-slices=6 / scenecut=0 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=32 / min-cu-size=16 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / no-signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=0 / no-limit-modes / me=0 / subme=0 / merange=57 / temporal-mvp / no-frame-dup / no-hme / no-weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / no-sao / no-sao-non-deblock / rd=2 / selective-sao=0 / early-skip / rskip / fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=23.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=0.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass Default : Yes Forced : No Color range : Limited Audio ID : 2 Format : E-AC-3 Format/Info : Enhanced AC-3 Commercial name : Dolby Digital Plus Codec ID : A_EAC3 Duration : 24 min 19 s Bit rate mode : Constant Bit rate : 256 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 32 bits Compression mode : Lossy Delay relative to video : 6 ms Stream size : 44.5 MiB (27%) Language : English Service kind : Complete Main Default : Yes Forced : No Text ID : 3 Format : ASS Codec ID : S_TEXT/ASS Codec ID/Info : Advanced Sub Station Alpha Duration : 24 min 18 s Compression mode : Lossless Title : English Writing library : Lavc58.134.100 ssa Language : English Default : Yes Forced : No Report created by : MediaInfoLib - v21.03 Report created on : UTC 2021-09-20 22:36:48 Emby does not use MediaInfo, it uses ffmpeg/ffprobe to get media information. So there are these slight differences. Spoiler Y:\Emby-Server\system>ffprobe -i "\\HOMESERVER\Videos\Movies - 4K\F9 (2021)\F9 (2021) - 4K.mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data ffprobe version 4.4.0-emby_2021_08_23-g8f222573e9+4998 Copyright (c) 2007-2021 the FFmpeg developers and softworkz for Emby LLC built with gcc 10.3.0 (Rev5, Built by MSYS2 project) { Input #0, matroska,webm, from '\\HOMESERVER\Videos\Movies - 4K\F9 (2021)\F9 (2021) - 4K.mkv': Metadata: encoder : libebml v1.3.5 + libmatroska v1.4.8 creation_time : 2021-07-29T04:06:51.000000Z Duration: 02:22:51.62, start: 0.000000, bitrate: 15101 kb/s Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3836x1600 [SAR 1:1 DAR 959:400], Level 150, 23.98 fps, 23.98 tbr, 1k tbn, 1k tbc (default) Metadata: BPS : 14331510 BPS-eng : 14331510 DURATION : 02:22:51.605000000 DURATION-eng : 02:22:51.605000000 NUMBER_OF_FRAMES: 205513 NUMBER_OF_FRAMES-eng: 205513 NUMBER_OF_BYTES : 15355506155 NUMBER_OF_BYTES-eng: 15355506155 Stream #0:1(eng): Audio: eac3, 48000 Hz, 5.1(side), fltp, 768 kb/s Metadata: title : English BPS : 768000 BPS-eng : 768000 DURATION : 02:22:51.616000000 DURATION-eng : 02:22:51.616000000 NUMBER_OF_FRAMES: 267863 NUMBER_OF_FRAMES-eng: 267863 NUMBER_OF_BYTES : 822875136 NUMBER_OF_BYTES-eng: 822875136 "streams": [ { "index": 0, "codec_name": "hevc", "codec_long_name": "H.265 / HEVC (High Efficiency Video Coding)", "profile": "Main 10", "codec_type": "video", "codec_tag_string": "[0][0][0][0]", "codec_tag": "0x0000", "width": 3836, "height": 1600, "coded_width": 3840, "coded_height": 1600, "closed_captions": 0, "has_b_frames": 4, "sample_aspect_ratio": "1:1", "display_aspect_ratio": "959:400", "pix_fmt": "yuv420p10le", "level": 150, "color_range": "tv", "color_space": "bt2020nc", "color_transfer": "smpte2084", "color_primaries": "bt2020", "chroma_location": "topleft", "refs": 1, "r_frame_rate": "24000/1001", "avg_frame_rate": "24000/1001", "time_base": "1/1000", "start_pts": 0, "start_time": "0.000000", "extradata": "\n00000000: 0122 2000 0000 b000 0000 0000 96f0 00fc .\" .............\n00000010: fdfa fa00 000f 04a0 0001 0018 4001 0c01 ............@...\n00000020: ffff 2220 0000 0300 b000 0003 0000 0300 ..\" ............\n00000030: 9618 b024 a100 0100 3e42 0101 2220 0000 ...$....>B..\" ..\n00000040: 0300 b000 0003 0000 0300 96a0 01e0 2006 .............. .\n00000050: 41de d9c6 2e49 1201 4e22 224b 3c92 9a49 A....I..N\"\"K<..I\n00000060: cb24 4924 8b72 46a9 23f2 888f fc00 0400 .$I$.rF.#.......\n00000070: 05a8 4880 4db0 10a2 0001 0008 4401 c025 ..H.M.......D..%\n00000080: 2f85 b240 a700 0200 1e4e 0189 1833 c286 /..@.....N...3..\n00000090: c41d 4c0b b884 d03e 803d 1340 4202 625a ..L....>.=.@B.bZ\n000000a0: 0000 0300 0032 8000 094e 0190 0403 ea02 .....2...N......\n000000b0: bd80 ..\n", "disposition": { "default": 1, "dub": 0, "original": 0, "comment": 0, "lyrics": 0, "karaoke": 0, "forced": 0, "hearing_impaired": 0, "visual_impaired": 0, "clean_effects": 0, "attached_pic": 0, "timed_thumbnails": 0 }, "tags": { "BPS": "14331510", "BPS-eng": "14331510", "DURATION": "02:22:51.605000000", "DURATION-eng": "02:22:51.605000000", "NUMBER_OF_FRAMES": "205513", "NUMBER_OF_FRAMES-eng": "205513", "NUMBER_OF_BYTES": "15355506155", "NUMBER_OF_BYTES-eng": "15355506155", "_STATISTICS_WRITING_APP": "mkvmerge v19.0.0 ('Brave Captain') 64-bit", "_STATISTICS_WRITING_APP-eng": "mkvmerge v19.0.0 ('Brave Captain') 64-bit", "_STATISTICS_WRITING_DATE_UTC": "2021-07-29 04:06:51", "_STATISTICS_WRITING_DATE_UTC-eng": "2021-07-29 04:06:51", "_STATISTICS_TAGS": "BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES", "_STATISTICS_TAGS-eng": "BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES" } }, { "index": 1, "codec_name": "eac3", "codec_long_name": "ATSC A/52B (AC-3, E-AC-3)", "codec_type": "audio", "codec_tag_string": "[0][0][0][0]", "codec_tag": "0x0000", "sample_fmt": "fltp", "sample_rate": "48000", "channels": 6, "channel_layout": "5.1(side)", "bits_per_sample": 0, "dmix_mode": "-1", "ltrt_cmixlev": "-1.000000", "ltrt_surmixlev": "-1.000000", "loro_cmixlev": "-1.000000", "loro_surmixlev": "-1.000000", "r_frame_rate": "0/0", "avg_frame_rate": "0/0", "time_base": "1/1000", "start_pts": 0, "start_time": "0.000000", "bit_rate": "768000", "extradata": "\n", "disposition": { "default": 0, "dub": 0, "original": 0, "comment": 0, "lyrics": 0, "karaoke": 0, "forced": 0, "hearing_impaired": 0, "visual_impaired": 0, "clean_effects": 0, "attached_pic": 0, "timed_thumbnails": 0 }, "tags": { "language": "eng", "title": "English", "BPS": "768000", "BPS-eng": "768000", "DURATION": "02:22:51.616000000", "DURATION-eng": "02:22:51.616000000", "NUMBER_OF_FRAMES": "267863", "NUMBER_OF_FRAMES-eng": "267863", "NUMBER_OF_BYTES": "822875136", "NUMBER_OF_BYTES-eng": "822875136", "_STATISTICS_WRITING_APP": "mkvmerge v19.0.0 ('Brave Captain') 64-bit", "_STATISTICS_WRITING_APP-eng": "mkvmerge v19.0.0 ('Brave Captain') 64-bit", "_STATISTICS_WRITING_DATE_UTC": "2021-07-29 04:06:51", "_STATISTICS_WRITING_DATE_UTC-eng": "2021-07-29 04:06:51", "_STATISTICS_TAGS": "BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES", "_STATISTICS_TAGS-eng": "BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES" } } ], "chapters": [ ], "format": { "filename": "\\\\HOMESERVER\\Videos\\Movies - 4K\\F9 (2021)\\F9 (2021) - 4K.mkv", "nb_streams": 2, "nb_programs": 0, "format_name": "matroska,webm", "format_long_name": "Matroska / WebM", "start_time": "0.000000", "duration": "8571.616000", "size": "16180577383", "bit_rate": "15101542", "probe_score": 100, "tags": { "encoder": "libebml v1.3.5 + libmatroska v1.4.8", "creation_time": "2021-07-29T04:06:51.000000Z" } } } But level 120 is level 4.0 The definition: H265_LevelIdc_10 = 30, H265_LevelIdc_20 = 60, H265_LevelIdc_21 = 63, H265_LevelIdc_30 = 90, H265_LevelIdc_31 = 93, H265_LevelIdc_40 = 120, H265_LevelIdc_41 = 123, H265_LevelIdc_50 = 150, H265_LevelIdc_51 = 153, H265_LevelIdc_52 = 156, H265_LevelIdc_60 = 180, H265_LevelIdc_61 = 183, H265_LevelIdc_62 = 186 1
Napsterbater 26 Posted September 20, 2021 Posted September 20, 2021 Oh, well that is confusing, I compared to a 264 video and 31 was 3.1, so seemed like a simple conversion, but apparently not. Well, hopefully someone can figure out what is going on, because I see no other reason the videos should not be direct playable.
Happy2Play 9812 Posted September 20, 2021 Posted September 20, 2021 12 minutes ago, Napsterbater said: Oh, well that is confusing, I compared to a 264 video and 31 was 3.1, so seemed like a simple conversion, but apparently not. Well, hopefully someone can figure out what is going on, because I see no other reason the videos should not be direct playable. Devs will have to comment more as the log above is showing a profile issue limited to "Main" not "Main 10". So it is a matter of if this information is coming from the device or a dev built playback capability.
Luke 42244 Posted September 23, 2021 Posted September 23, 2021 Can you try side loading our standard Android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks.
Napsterbater 26 Posted September 24, 2021 Posted September 24, 2021 (edited) On 9/22/2021 at 9:40 PM, Luke said: Can you try side loading our standard Android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks. Sideloaded 3.2.14, it direct played fine. Though unrelated, the UI was laggy. Edited September 24, 2021 by Napsterbater
Napsterbater 26 Posted September 25, 2021 Posted September 25, 2021 2 minutes ago, Luke said: Where was it laggy? The video itself played fine at correct frame rate nothing wrong with a video playback itself. But the actual scrolling through the menu getting to the show and basically everything before playback was noticeably slower and just had not a smooth feeling and just like a bit wacky is all I can describe, But pretty much all interactions with the menu were that way. But again the video itself which is the main purpose of this post of course played perfectly fine smooth and direct played. Basically the Amazon beta has a smooth menu and UI, But is not direct playing these main 10 HEVC videos. The Android side load has a laggy menu but plays the videos perfectly and direct plays them.
ebr 16337 Posted September 25, 2021 Posted September 25, 2021 The TV app probably needs to be more specific in its interrogation of the device capabilities. Right now it is just asking about main 10 and not a specific profile of main 10.
Napsterbater 26 Posted September 27, 2021 Posted September 27, 2021 Anything else needed from me right now to help with this? Are we just waiting for devs to correct this? This doesn't really hurt me all that much, just a minor PQ hit otherwise my Emby server's 3950x can transcode with ease, but I know many don't have that luxury.
