PeterKvist 1 Posted December 11, 2020 Posted December 11, 2020 Hi. I can no longer get guidedata to update, and when I try to map channels on my devices, there are no channels to map. The channels is present in Live TV. Could you please telle me how to fix this? Thanks Peter embyserver.txt
Luke 42238 Posted December 11, 2020 Posted December 11, 2020 Hi there, what guide data did you set up?
PeterKvist 1 Posted December 11, 2020 Author Posted December 11, 2020 I use xmltv - quite large fil - sorry b.xml
Solution Carlo 4561 Posted December 12, 2020 Solution Posted December 12, 2020 This is going to almost certainly be bad encoding of the XML file. If you load the xml file in Google Chrome does it display an encoding issue or load the whole file?
PeterKvist 1 Posted December 12, 2020 Author Posted December 12, 2020 Thanks. I did open it in visual code, and found an error Problem solved now - thanks for your help <programme channel="super.rtl.de" start="20201211132500 +0000" stop="20201211140000 +0000"> <title lang="de">Weihnachtsmann & Co. KG</title> <sub-title lang="d <programme channel="superhd.rtl.de" start="20201211043000 +0000" stop="20201211045000 +0000"> <title lang="de">Paw Patrol - Helfer auf vier Pfoten</title> <sub-title lang="de">Die Hunde bergen den Paw Patroller / Das Krähennest</sub-title> <category lang="en">series</category> </programme> <programme channel="superhd.rtl.de" start="20201211045000 +0000" stop="20201211052500 +0000"> <title lang="de">Weihnachtsmann Junior</title> <sub-title lang="de">Das Geheimnis der Rentiergeweihe / Marcos Glücksstern</sub-title> <category lang="en">series</category> </programme>
