Nisten 15 Posted December 9, 2020 Posted December 9, 2020 There's no pop-up for the next episode and after the current episode finishes, it shows just a black screen with an empty loading bar. I have to manually click the next button in order for it to play the next episode. ffmpeg-transcode-4336594d-36a2-4fbe-adbd-19a92071e523_1.txt ffmpeg-transcode-a7e142e3-daa6-4ebd-9657-426d8930a93a_1.txt ffmpeg-transcode-c0cca301-d891-491b-847b-25f0fb52dff0_1.txt ffmpeg-transcode-c2492313-1fa4-4f6e-a1d9-fccedfcc99ba_1.txt embyserver-63742896000.txt ffmpeg-transcode-4b2c17c4-97e9-48d0-b830-8267febf24b4_1.txt ffmpeg-transcode-7ac24ffa-1b7d-44f9-885e-12f1c3e4a90e_1.txt ffmpeg-transcode-42deb3bc-497f-41d2-a49b-715827aa11ce_1.txt
speechles 2062 Posted December 9, 2020 Posted December 9, 2020 Are you using the Emby Beta for Roku when playing? The Beta has special fixes to keep playback going when it hangs at the end of an episode. Let us know if this doesn't solve the problem.
Nisten 15 Posted December 10, 2020 Author Posted December 10, 2020 No, i'm using the regular version. Are these fixes automatic in the beta version or do i have toggle a setting?
ebr 16335 Posted December 10, 2020 Posted December 10, 2020 Hi. You don't have to toggle anything. Please let us know if the beta works better for you.
Nisten 15 Posted December 27, 2020 Author Posted December 27, 2020 Wasn't able to reproduce the issue using beta, will these fixes be applied to the regular roku app?
speechles 2062 Posted December 27, 2020 Posted December 27, 2020 9 hours ago, Nisten said: Wasn't able to reproduce the issue using beta, will these fixes be applied to the regular roku app? Yes. https://blog.roku.com/developer/channel-store-blackouts-2020 Presently Roku is on Holiday Blackout. Once they exit this blackout on January 4th they will start to approve and publish submissions. Until then it does not help to continue to submit packages for approval. That will only slow down the process. It is better to wait until January 4th to submit a new package to the Roku store for the approval process. This is what the hold up is. We will have a new Store version hopefully on January 4th or 5th. Please be patient. These are Roku rules we must live with.
