JKChan 0 Posted December 9, 2020 Posted December 9, 2020 When I update the version to 4.5.3 on NAS, the default fonts(chinese) of subtitle was changed to another and seems little small on iPhone, here attached images were screenshot on emby and normal player app, please help to check, thanks.
Abobader 3485 Posted December 9, 2020 Posted December 9, 2020 Hello JKChan, Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: How to Report a Problem Thank you. Emby Team
JKChan 0 Posted December 9, 2020 Author Posted December 9, 2020 add more info: previous version was 4.4.3.0 that installed directly from Synology, and that version is ok for me.
Luke 42204 Posted December 9, 2020 Posted December 9, 2020 Hi there, thanks for reporting. We'll take a look.
JKChan 0 Posted December 10, 2020 Author Posted December 10, 2020 On 12/9/2020 at 10:28 PM, Luke said: Hi there, thanks for reporting. We'll take a look. hi bro, any update?
JKChan 0 Posted December 16, 2020 Author Posted December 16, 2020 On 12/11/2020 at 12:06 AM, Luke said: Hi, not yet, sorry. It's on our list for review. hi bro, still no progress?
Luke 42204 Posted December 16, 2020 Posted December 16, 2020 Hi, not yet, sorry. It's on our list for review.
JKChan 0 Posted December 17, 2020 Author Posted December 17, 2020 On 12/16/2020 at 12:14 PM, Luke said: Hi, not yet, sorry. It's on our list for review. so how long you maybe need to give some feedback?
JKChan 0 Posted December 17, 2020 Author Posted December 17, 2020 On 12/16/2020 at 12:14 PM, Luke said: Hi, not yet, sorry. It's on our list for review. is that possible I rollback to old version and fix it?
Carlo 4561 Posted December 18, 2020 Posted December 18, 2020 Hi, If you have a complete matching set of files such as database, config, dlls, executables, you could. Basically you need a backup from an earlier point in time. What is not supported is downgrading in place to an older version as the database & config files likely changed.
JKChan 0 Posted December 19, 2020 Author Posted December 19, 2020 12 hours ago, cayars said: Hi, If you have a complete matching set of files such as database, config, dlls, executables, you could. Basically you need a backup from an earlier point in time. What is not supported is downgrading in place to an older version as the database & config files likely changed. so...what I can do now...
Carlo 4561 Posted December 19, 2020 Posted December 19, 2020 Do you have a complete backup of a previous version of Emby?
Happy2Play 9802 Posted December 19, 2020 Posted December 19, 2020 (edited) The only way you can rollback without starting over is if you have a system backup of Emby before the update. Edited December 19, 2020 by Happy2Play 1
JKChan 0 Posted December 19, 2020 Author Posted December 19, 2020 7 hours ago, cayars said: Do you have a complete backup of a previous version of Emby? no... I just reinstall by using the latest version
Carlo 4561 Posted December 19, 2020 Posted December 19, 2020 In that case as Happy2Play pointed out there is no way to rollback as you don't have a previous state of backup to roll back to.
Luke 42204 Posted December 23, 2020 Posted December 23, 2020 We're looking into the small subtitles. Thanks.
JKChan 0 Posted January 1, 2021 Author Posted January 1, 2021 On 12/24/2020 at 12:09 AM, Luke said: We're looking into the small subtitles. Thanks. hi bro, seems this problem already been fixed on iOS, but still very small on android phone, pls help to check thx
Luke 42204 Posted January 1, 2021 Posted January 1, 2021 It's resolved for the next app update. Thanks.
JKChan 0 Posted January 2, 2021 Author Posted January 2, 2021 13 hours ago, Luke said: It's resolved for the next app update. Thanks. OK got it. Happy new year : )
JKChan 0 Posted February 4, 2021 Author Posted February 4, 2021 On 1/2/2021 at 12:28 AM, Luke said: It's resolved for the next app update. Thanks. hi luke just wanna check if u already release the fixed app for Android?
