byakuya32 24 Posted December 9, 2020 Posted December 9, 2020 Emby 4.5.3 is really slow and take over a minute to load a video it also seems to load an entry in convert for every single actor I have reverted to 4.5.2 because of this
Luke 42246 Posted December 9, 2020 Posted December 9, 2020 Hi there, please go over an example. Thanks.
horstepipe 423 Posted December 9, 2020 Posted December 9, 2020 (edited) @Luke maybe the server lifts some heavier tasks when upgrading from 4.5.2 to 4.5.3 and performing a library scan? The first hour after upgrading my server was very slow and showed quite high cpu usage, although the log kept quite empty. But I didn't took a deeper look... However, now the server performance seems to be normal again. Edited December 9, 2020 by horstepipe
Luke 42246 Posted December 9, 2020 Posted December 9, 2020 We'd have to look at an example. Please see how to report a problem: Thanks.
byakuya32 24 Posted December 9, 2020 Author Posted December 9, 2020 55 minutes ago, horstepipe said: @Luke maybe the server lifts some heavier tasks when upgrading from 4.5.2 to 4.5.3 and performing a library scan? The first hour after upgrading my server was very slow and showed quite high cpu usage, although the log kept quite empty. But I didn't took a deeper look... However, now the server performance seems to be normal again. I gave it 2 days and it was still really slow the library scan was not running. Reverting to the previous build fixed the issue. I have a ryzen 5 2600 and 40gb of ram and an m2000 for a gpu
byakuya32 24 Posted December 9, 2020 Author Posted December 9, 2020 (edited) I'd have to reinstall 4.5.3 to get a log but I'd be slowing it down to unusable speed for everyone. Edited December 9, 2020 by byakuya32
crfloyd0932 5 Posted December 9, 2020 Posted December 9, 2020 I've seen the same behavior. Running Debian 10. 4.5.3 takes well over 45 seconds to a minute to play the next episode. behavior isn't present in 4.5.2. Doesn't matter if there is transcoding or not.
Luke 42246 Posted December 9, 2020 Posted December 9, 2020 5 minutes ago, crfloyd0932 said: I've seen the same behavior. Running Debian 10. 4.5.3 takes well over 45 seconds to a minute to play the next episode. behavior isn't present in 4.5.2. Doesn't matter if there is transcoding or not. We'd have to look at an example. Please see how to report a problem: Thanks.
crfloyd0932 5 Posted December 9, 2020 Posted December 9, 2020 7 minutes ago, Luke said: We'd have to look at an example. Please see how to report a problem: Thanks. embyserver.txt ffmpeg-transcode-13deb402-cbd9-448d-9e3b-dd4c88f971b4_1.txt
crfloyd0932 5 Posted December 9, 2020 Posted December 9, 2020 Server and its database is on an SSD. plenty of ram and its a 12 core Xeon, also and transcoding is offloaded to the nvidia card. not sure what the bottleneck is at this point.
byakuya32 24 Posted December 9, 2020 Author Posted December 9, 2020 I have my database on an samsung 970 plus evo nvme ssd
horstepipe 423 Posted December 10, 2020 Posted December 10, 2020 (edited) @LukeI pm'ed you a log. I performed a library scan (after deleting some episodes) this morning around 9-10 am. Server is unresponsive and log is full of errors since that time. Is v4.6.0.7 worth a try about that? Edited December 10, 2020 by horstepipe
crfloyd0932 5 Posted December 15, 2020 Posted December 15, 2020 Any updates on this? The longer the server runs, the slower it gets. last night I timed a show from the time i hit start till the time it started playing it was 2:43 seconds. the logs don't really indicate what is going on. if you restart embyserver, it speeds up but still takes a long time to start a show. way longer than 4.5.2 ever did.
Luke 42246 Posted December 15, 2020 Posted December 15, 2020 Just now, crfloyd0932 said: Any updates on this? The longer the server runs, the slower it gets. last night I timed a show from the time i hit start till the time it started playing it was 2:43 seconds. the logs don't really indicate what is going on. if you restart embyserver, it speeds up but still takes a long time to start a show. way longer than 4.5.2 ever did. Please try the new 4.5.4 release and see if that helps. Thanks.
byakuya32 24 Posted December 16, 2020 Author Posted December 16, 2020 4.5.4 solved it for me and it runs faster than it ever ran before. I can also leave it pause for a minute and it doesn't take a few seconds for the video to catch up to the audio. Thank you
crfloyd0932 5 Posted December 16, 2020 Posted December 16, 2020 Agreed, whatever changes were made to 4.5.4, it returned back to normal operation.
plittlefield 56 Posted December 16, 2020 Posted December 16, 2020 Ah, that might help with an issue my friends have been experiencing with 4.5.3 on my server. I'll wait until the dust settles on this point release and then install tomorrow morning
