crusher11 1143 Posted December 8, 2020 Posted December 8, 2020 I assume it needs to be transcoded and remuxed due to the high bitrate, but Emby isn't catching it so all I get is silence.
crusher11 1143 Posted December 9, 2020 Author Posted December 9, 2020 General Format : Matroska Format version : Version 2 File size : 21.3 GiB Duration : 1 h 46 min Overall bit rate mode : Variable Overall bit rate : 28.6 Mb/s Encoded date : UTC 2020-10-08 19:46:36 Writing application : MakeMKV v1.15.2 win(x64-release) Writing library : libmakemkv v1.15.2 (1.3.10/1.5.2) win(x64-release) Video ID : 1 ID in the original source medium : 4113 (0x1011) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 3 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 3 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1 h 46 min Bit rate mode : Variable Bit rate : 24.0 Mb/s Maximum bit rate : 40.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.482 Stream size : 17.9 GiB (84%) Language : English Default : No Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Original source medium : Blu-ray Audio ID : 2 ID in the original source medium : 4352 (0x1100) Format : PCM Format settings : Little / Signed Codec ID : A_MS/ACM / 00000001-0000-0010-8000-00AA00389B71 Duration : 1 h 46 min Bit rate mode : Constant Bit rate : 4 608 kb/s / 4 608 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 30.000 FPS (1600 SPF) Bit depth : 16 bits Stream size : 3.43 GiB (16%) Title : PCM 5.1 Language : English Default : Yes Forced : No Original source medium : Blu-ray Text #1 ID : 3 ID in the original source medium : 4608 (0x1200) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 42 min Bit rate : 16.3 kb/s Count of elements : 1876 Stream size : 11.9 MiB (0%) Language : English Default : No Forced : No Original source medium : Blu-ray Text #2 ID : 5 ID in the original source medium : 4609 (0x1201) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 42 min Bit rate : 17.7 kb/s Count of elements : 2068 Stream size : 12.9 MiB (0%) Title : SDH (PGSSUB) Language : English Default : No Forced : No Original source medium : Blu-ray Menu 00:00:00.000 : en:Chapter 01 00:08:43.981 : en:Chapter 02 00:09:50.673 : en:Chapter 03 00:14:56.979 : en:Chapter 04 00:16:30.948 : en:Chapter 05 00:20:57.339 : en:Chapter 06 00:25:04.586 : en:Chapter 07 00:32:26.069 : en:Chapter 08 00:34:37.158 : en:Chapter 09 00:36:28.394 : en:Chapter 10 00:40:55.703 : en:Chapter 11 00:43:22.933 : en:Chapter 12 00:49:59.037 : en:Chapter 13 00:54:53.039 : en:Chapter 14 00:56:57.414 : en:Chapter 15 00:59:59.804 : en:Chapter 16 01:02:51.392 : en:Chapter 17 01:04:35.037 : en:Chapter 18 01:07:37.261 : en:Chapter 19 01:12:16.832 : en:Chapter 20 01:13:28.445 : en:Chapter 21 01:17:33.315 : en:Chapter 22 01:22:19.684 : en:Chapter 23 01:31:38.409 : en:Chapter 24 01:33:13.588 : en:Chapter 25 01:35:52.788 : en:Chapter 26 01:37:49.947 : en:Chapter 27 01:42:15.462 : en:Chapter 28 01:46:37.015 : en:Chapter 29
SamES 1084 Posted December 9, 2020 Posted December 9, 2020 I think this should be remuxing. Can you check the user settings on the server and confirm that all transcode/remux options are enabled. Can you attach the server log when you try and play this (ideally with debug logging turned on)
crusher11 1143 Posted December 9, 2020 Author Posted December 9, 2020 They are, it remuxes Die Hard as discussed in the other thread. It also remuxes Shoah, which is 24 bit 2.0 PCM.
SamES 1084 Posted December 9, 2020 Posted December 9, 2020 OK, from an audio perspective, remux is equivalent to an audio steam transcode. So same comments as your other thread, this should be remuxing so it is doing the right thing, but the remux is not producing any audio. So am I now correct? You have two samples, DTS-MA and PCM5.1, both which are remuxing (as they should) but neither are producing any audio. Correct? That is the problem we need to resolve
crusher11 1143 Posted December 9, 2020 Author Posted December 9, 2020 No, that's not correct. Die Hard 4K has a DTS-HD MA 2.0 soundtrack. This should simply extract the DTS core and Direct Play. Instead, it converts the audio to AAC and remuxes. There is audio. Unbreakable has a PCM 5.1 soundtrack. This should convert the audio and remux, but it doesn't. It plays silently. embyserver.txt ffmpeg-remux-4d77a3e0-e35a-4d27-99f1-db2e51a8e564_1.txt
SamES 1084 Posted December 9, 2020 Posted December 9, 2020 We're getting the threads mixed up now. I don't know why this isn't trying to DirectPlay. It may have been something that's already resolved for the next version. If you turn on debug logging temporarily and try playback again, that might tell us a bit more
crusher11 1143 Posted December 10, 2020 Author Posted December 10, 2020 The log I posted is good for both threads; I played both movies before uploading it. Here's another, with debug logging this time. Again, both movies. embyserver.txt ffmpeg-remux-abb72e57-b087-4333-93e7-54c521976634_1.txt
SamES 1084 Posted December 10, 2020 Posted December 10, 2020 From the log with debugging it looks like Die Hard tried to DirectPlay, then failed, so it requested Transcoding. However, because the original video codec (HEVC) is requested in the Transcode request only the audio has been converted so it has DirectStreamed instead. I suspect that if you try this original file from a USB drive with the TV's built in player that it may fail to play there as well. Not sure why, maybe the container is corrupt? For this file https://emby.media/community/index.php?/topic/92745-no-audio-from-51-pcm-track/&do=findComment&comment=957703 I expect that we need a channel limit on PCM files to force remuxing if there are more than 2 channels. @Luke, what are your thoughts on this? It's really an ARC bandwidth issue, but until we see support eARC support, I can't see people playing PCM5.1 any other way, and I think this is rare as it's never come up before. Having said that, @crusher11, I would suggest it would be better to add your own compressed 5.1 track to this file, then let it DirectPlay
rbjtech 5341 Posted December 10, 2020 Posted December 10, 2020 Re : Diehard 4K DTS Core issue - If you are familiar with ffmpeg on the command line, then you can extract the DTS core yourself to confirm if it's not corrupt. ffmpeg -i input.mkv -map 0 -c:v copy -bsf:a dca_core -c:a copy -c:s copy output.mkv
crusher11 1143 Posted December 10, 2020 Author Posted December 10, 2020 6 hours ago, SamES said: From the log with debugging it looks like Die Hard tried to DirectPlay, then failed, so it requested Transcoding. However, because the original video codec (HEVC) is requested in the Transcode request only the audio has been converted so it has DirectStreamed instead. I suspect that if you try this original file from a USB drive with the TV's built in player that it may fail to play there as well. Not sure why, maybe the container is corrupt? For this file https://emby.media/community/index.php?/topic/92745-no-audio-from-51-pcm-track/&do=findComment&comment=957703 I expect that we need a channel limit on PCM files to force remuxing if there are more than 2 channels. @Luke, what are your thoughts on this? It's really an ARC bandwidth issue, but until we see support eARC support, I can't see people playing PCM5.1 any other way, and I think this is rare as it's never come up before. Having said that, @crusher11, I would suggest it would be better to add your own compressed 5.1 track to this file, then let it DirectPlay It's forcing a remux on Shoah and its bonus films, which are two-channel PCM. Is that because 24-bit and 16-bit are treated differently? I assume I'm going to have to go through my movies and look for other potentially problematic files. 4 hours ago, rbjtech said: Re : Diehard 4K DTS Core issue - If you are familiar with ffmpeg on the command line, then you can extract the DTS core yourself to confirm if it's not corrupt. ffmpeg -i input.mkv -map 0 -c:v copy -bsf:a dca_core -c:a copy -c:s copy output.mkv How would that confirm corruption or lack thereof?
crusher11 1143 Posted December 10, 2020 Author Posted December 10, 2020 I muxed the DTS-HD MA track onto the Blu-ray, and it Direct Plays. So it's not an issue with the audio track itself.
rbjtech 5341 Posted December 10, 2020 Posted December 10, 2020 45 minutes ago, crusher11 said: How would that confirm corruption or lack thereof? If it exports the entire core without issue, then no corruption ... if it errors, then there is - and this is possibly why emby resorted to transcoding.. Without the files it's difficult to investigate - but there are plenty of excellent free tools on the web to help you identify the issue yourself. eac3to, tsMuxer to name a few ..
crusher11 1143 Posted December 10, 2020 Author Posted December 10, 2020 ffmpeg extracted it just fine. And as I said, if I mux that DTS-HD MA track onto the Blu-ray, it Direct Plays.
SamES 1084 Posted December 11, 2020 Posted December 11, 2020 17 hours ago, crusher11 said: ffmpeg extracted it just fine. And as I said, if I mux that DTS-HD MA track onto the Blu-ray, it Direct Plays. Sounds like the original mkv container is corrupt? 18 hours ago, crusher11 said: It's forcing a remux on Shoah and its bonus films, which are two-channel PCM. Is that because 24-bit and 16-bit are treated differently? I assume I'm going to have to go through my movies and look for other potentially problematic files. Yes, it's possible that they are treated differently. It depends on the codec tag
crusher11 1143 Posted December 11, 2020 Author Posted December 11, 2020 I remuxed the 4K and it still transcodes the audio.
crusher11 1143 Posted December 11, 2020 Author Posted December 11, 2020 The Revenant also transcodes the audio for playback. Something about 4K and DTS-HD MA is throwing the TV off.
