Solution Alfsvag 2 Posted December 8, 2020 Solution Posted December 8, 2020 (edited) I've run out of things to try, hopefully I can get some assistance here. I run OMV5. I have created a dns SSL certificate for my domain and it's subdomains using Swag and Cloudflare. [cont-init.d] 10-adduser: exited 0., [cont-init.d] 20-config: executing... , [cont-init.d] 20-config: exited 0., [cont-init.d] 30-keygen: executing... , using keys found in /config/keys, [cont-init.d] 30-keygen: exited 0., [cont-init.d] 50-config: executing... , Variables set:, PUID=998, PGID=100, TZ=Europe/Stockholm, URL=******.se, SUBDOMAINS=emby,plex,www, EXTRA_DOMAINS=, ONLY_SUBDOMAINS=false, VALIDATION=dns, DNSPLUGIN=cloudflare, EMAIL=******@gmail.com, STAGING=false, SUBDOMAINS entered, processing, SUBDOMAINS entered, processing, Sub-domains processed are: -d emby.******.se -d plex.******.se -d www.******.se, E-mail address entered: ******@gmail.com, dns validation via cloudflare plugin is selected, Certificate exists; parameters unchanged; starting nginx, Starting 2019/12/30, GeoIP2 databases require personal license key to download. Please retrieve a free license key from MaxMind,, and add a new env variable "MAXMINDDB_LICENSE_KEY", set to your license key., [cont-init.d] 50-config: exited 0., [cont-init.d] 60-renew: executing... , The cert does not expire within the next day. Letting the cron script handle the renewal attempts overnight (2:08am)., [cont-init.d] 60-renew: exited 0., [cont-init.d] 99-custom-files: executing... , [custom-init] no custom files found exiting..., [cont-init.d] 99-custom-files: exited 0., [cont-init.d] done., [services.d] starting services, [services.d] done., nginx: [alert] detected a LuaJIT version which is not OpenResty's; many optimizations will be disabled and performance will be compromised (see https://github.com/openresty/luajit2 for OpenResty's LuaJIT or, even better, consider using the OpenResty releases from https://openresty.org/en/download.html), Server ready, I've setup Nginx with the following configuration: (emby.subdomain.conf) server { listen 443 ssl; listen [::]:443 ssl; server_name emby.*; add_header X-Robots-Tag "noindex, nofollow, nosnippet, noarchive"; include /config/nginx/ssl.conf; client_max_body_size 0; location / { include /config/nginx/proxy.conf; resolver 127.0.0.11 valid=30s; proxy_pass http://192.168.0.2:8096; proxy_set_header Range $http_range; proxy_set_header If-Range $http_if_range; proxy_set_header X-Real-IP $remote_addr; proxy_set_header Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; } } Within Emby I have the public https port set to 443. I also have my full external domain listed as well as my certificate. Yet it doesn't work. I get error 522 when I attempt to connect. What am I missing? No port on the router is open besides 80 and 443. Edit: I had forgotten to turn of the proxy on cloudflare when I generated the certificates. Edited December 9, 2020 by Alfsvag
Luke 42205 Posted December 10, 2020 Posted December 10, 2020 Hi, glad to see you figured it out. Thanks for following up. 1
