Happy2Play 9814 Posted December 20, 2020 Posted December 20, 2020 And if you disable Real time Monitoring on the that library and restart Emby the issue stops correct? If you run a library scan manually it only runs once correct?
thymon 11 Posted December 20, 2020 Author Posted December 20, 2020 4 minutes ago, Happy2Play said: And if you disable Real time Monitoring on the that library and restart Emby the issue stops correct? If you run a library scan manually it only runs once correct? I disable RTM : Nothing. I restart the EMBY Doker : Scan loop is stopped I launch the scan manually : One scan, no loop. I keep the RTM disabled to check if the problem comes back. I'll keep you informed later. thank you for your patience.
Happy2Play 9814 Posted December 20, 2020 Posted December 20, 2020 Basically this shows that something is on your system is causing Emby's RTM process to see filesystem level changes within this library. But the devs would have to explain more.
thymon 11 Posted December 20, 2020 Author Posted December 20, 2020 (edited) And uncheck : Save images to media folders (I think it's my poster problem) Edited December 20, 2020 by thymon
Happy2Play 9814 Posted December 20, 2020 Posted December 20, 2020 4 minutes ago, thymon said: And uncheck : Save images to media folders (I think it's my poster problem) Would have to go over specific example showing folder content.
thymon 11 Posted December 20, 2020 Author Posted December 20, 2020 Ok new example : New movie grabbed : English title : My Father's Glory. French title : La Gloire de Mon Père. Look emby, Principal in English : I select "Modify picture", And I see that the other pictures are in French. I select "search' for Principal, And other French poster are existing : I didn't have this problem there before. And the posters were correctly selected.
Luke 42246 Posted December 20, 2020 Posted December 20, 2020 Can you show a screenshot of the settings for your library?
thymon 11 Posted December 20, 2020 Author Posted December 20, 2020 https://emby.media/community/index.php?/topic/92726-metadata-always-in-english-4530-docker/&do=findComment&comment=961244
Luke 42246 Posted December 20, 2020 Posted December 20, 2020 Sorry. Can you please attach the emby server log from when you added that movie? Thanks.
thymon 11 Posted December 20, 2020 Author Posted December 20, 2020 8 minutes ago, Luke said: Sorry. Can you please attach the emby server log from when you added that movie? Thanks. Sended in PM
Luke 42246 Posted December 20, 2020 Posted December 20, 2020 What are the contents of the movie folder?
thymon 11 Posted December 20, 2020 Author Posted December 20, 2020 (edited) .nfo ?? Why : Edited December 20, 2020 by thymon
Luke 42246 Posted December 20, 2020 Posted December 20, 2020 You also have poster.jpg and Emby is using that. I think that's where your English poster came from.
thymon 11 Posted December 20, 2020 Author Posted December 20, 2020 I Think too. But Why ? Save pictures is not check
Luke 42246 Posted December 20, 2020 Posted December 20, 2020 I don't know. You tell me. Where did that image come from? It's your image file and Emby is using it.
thymon 11 Posted December 20, 2020 Author Posted December 20, 2020 LOL... Sonarr ? Otherwise I don't understand.
Happy2Play 9814 Posted December 20, 2020 Posted December 20, 2020 1 minute ago, thymon said: Sonarr ? Possibly All folder/local images and metadata will override library settings no matter what.
thymon 11 Posted December 20, 2020 Author Posted December 20, 2020 @Happy2Play @Luke Thank you again for all your patience with me. I think I found it, thanks to your leads. "Emby metadata" was enabled in Radarr but it was disabled in Sonarr. My Radarr recently upgraded to version V3. I think it coincides. Sorry again for this waste of time.
