trott90 20 Posted December 7, 2020 Posted December 7, 2020 @Luke, I'd like raise this request as title, currently the sort and alpha picker is useless for chinese title, some discussion in below
Luke 42246 Posted December 10, 2020 Posted December 10, 2020 Hi there, yes we are looking into improving it. Thanks for the feedback.
trott90 20 Posted March 12, 2021 Author Posted March 12, 2021 @luke, how about this request, one simple solution is that check the name when update the metadata, if it is in Chinese, then update the SortName field with the Pinyin of Chinese Name
Luke 42246 Posted March 16, 2021 Posted March 16, 2021 On 3/12/2021 at 12:19 AM, trott90 said: then update the SortName field with the Pinyin of Chinese Name Hi, where would we get this from?
trott90 20 Posted March 17, 2021 Author Posted March 17, 2021 9 hours ago, Luke said: Hi, where would we get this from? I have tested using API to update the sort title, basically first pull the item full meta using /Items/{itemid} service, then modify the "ForcedSortName" field, and post the updates data to /Items/{ItemId}
ClearSeve 0 Posted November 29, 2021 Posted November 29, 2021 Have you considered doing this function
MikolajNi 3 Posted December 18, 2021 Posted December 18, 2021 Still wating for this update, as the amount of the movies goes up to more than 150, this sort-by-pinyin function is definitely going to be needed. However, still trying to figure out what rules does the current chinese title sorting method follow? If there is a certain pattern, it should also be helpful for finding movies quickly.
Luke 42246 Posted December 19, 2021 Posted December 19, 2021 Hi, improvements to this are planned for future updates. Thanks. 1
hisune 3 Posted April 21, 2022 Posted April 21, 2022 On 12/20/2021 at 12:37 AM, Luke said: Hi, improvements to this are planned for future updates. Thanks. @Luke I really need this feature very much. Plex can set the sort title, so that you can set the Pinyin of the Chinese title in the sort title, Pinyin sorting and searching can be done well.
ebr 16338 Posted April 21, 2022 Posted April 21, 2022 2 hours ago, hisune said: @Luke I really need this feature very much. Plex can set the sort title, so that you can set the Pinyin of the Chinese title in the sort title, Pinyin sorting and searching can be done well. Hi. We have a sort title field as well.
hisune 3 Posted May 23, 2022 Posted May 23, 2022 On 4/21/2022 at 8:33 PM, ebr said: Hi. We have a sort title field as well. but sort title not work in search
vic4728 5 Posted February 13, 2023 Posted February 13, 2023 12 年 20 月 2021 日凌晨 12:37,卢克说: 嗨,计划在将来的更新中对此进行改进。谢谢。 第三方库:拼音4j.jar可用于汉语拼音排序
Luke 42246 Posted February 21, 2023 Posted February 21, 2023 On 2/13/2023 at 3:11 AM, vic4728 said: 第三方库:拼音4j.jar可用于汉语拼音排序 We'll take a look at what we can learn from it. Thanks.
