Jonathan1683 29 Posted December 6, 2020 Posted December 6, 2020 Hello with the new update i have a giant list of MP3 playlists that overtake my screen on the left column where manage server is. Is there a way to remove this? I click the collapse button and it hides it but next time i am on the screen it's back again. Thank you, 1
Luke 42256 Posted December 6, 2020 Posted December 6, 2020 Hi, you currently can't but you can expect there will be options to manage this in future updates. thanks for the feedback. 2
SunnyZ 0 Posted December 6, 2020 Posted December 6, 2020 Thankfully I'm not the only one. Figured it would save cookies, so I removed em all, reopened, collapsed the playlist column, reopened browser. Still there. Needs to be removed or a setting to disable, SUPER annoying having to scroll down for miles and miles or click the playlist to collapse it to get to the vital Manage Emby section... Maybe if you have an admin account, move that to the top? Or have options to customise the layout for admin accounts.
Jonathan1683 29 Posted December 6, 2020 Author Posted December 6, 2020 Thank you I will just remove my music for now.
Guest Posted December 24, 2020 Posted December 24, 2020 I agree it is irritating as hell, will just remove music for now.
Luke 42256 Posted December 25, 2020 Posted December 25, 2020 Expect to have more options in future updates. Thanks for the feedback.
rcharbo 2 Posted May 27, 2021 Posted May 27, 2021 (edited) Has this been resolved? No matter how many times I close that it reopens the next time. Please make it go away Edited May 27, 2021 by rcharbo
Happy2Play 9814 Posted May 27, 2021 Posted May 27, 2021 9 minutes ago, rcharbo said: Has this been resolved? No matter how many times I close that it reopens the next time. Please make it go away Sorry no. This is do to the navdrawercontent.js being scripted to data-expanded="true".
Luke 42256 Posted May 28, 2021 Posted May 28, 2021 Adding options to control this is on my to do list, so stay tuned. 1 1
jim3211 1 Posted June 2, 2021 Posted June 2, 2021 (edited) i hate it . it should only have playlist i make.. not automatically create them. if i try to delete them it says it will remove the files from my library. i don't want that. i could do without it altogether if that's how it works Edited June 2, 2021 by jim3211
ebr 16346 Posted June 2, 2021 Posted June 2, 2021 1 hour ago, jim3211 said: it should only have playlist i make.. not automatically create them Hi. We don't automatically create playlists. We do read all the ones you have though.
Carlo 4561 Posted June 2, 2021 Posted June 2, 2021 Hi, If these are music playlists I would try searching your music folders for any m3u files which can create music playlists for you. 1
jim3211 1 Posted June 2, 2021 Posted June 2, 2021 22 minutes ago, cayars said: Hi, If these are music playlists I would try searching your music folders for any m3u files which can create music playlists for you. thanks there were a bunch of those playlist files..i don't know where they came from, but i deleted them and that cleared up everything. thanks again... 1
popliviustefan 1 Posted November 13, 2021 Posted November 13, 2021 Hi! If I can have a question: is there a way to ignore the playlists (m3u, m3u8, pls etc.) that are found in the library? I have the following situation (which I think it may happen very well to a lot of people): I have a fairly large music collection (several hundreds GBs) and a lot of them have playlists inside, due to the fact that the torrents were generated that way, including playlists. So Emby will import all these playlists (which are mostly per album). I end up with around 1k of playlists. Deleting all the playlist files isn't a viable solution because most of them are live torrents, and removing part of a downloaded torrent which is seeding creates another set of complications. So, is there a way to tell Emby to ignore certain file types when scanning a library folder? I ask this because I would still like to use this feature, create my own libraries. But if those are spread between another 1k libraries, it kind of becomes useless. Thank you for the time to read my post! 1
Luke 42256 Posted November 16, 2021 Posted November 16, 2021 On 11/13/2021 at 3:50 PM, popliviustefan said: Hi! If I can have a question: is there a way to ignore the playlists (m3u, m3u8, pls etc.) that are found in the library? I have the following situation (which I think it may happen very well to a lot of people): I have a fairly large music collection (several hundreds GBs) and a lot of them have playlists inside, due to the fact that the torrents were generated that way, including playlists. So Emby will import all these playlists (which are mostly per album). I end up with around 1k of playlists. Deleting all the playlist files isn't a viable solution because most of them are live torrents, and removing part of a downloaded torrent which is seeding creates another set of complications. So, is there a way to tell Emby to ignore certain file types when scanning a library folder? I ask this because I would still like to use this feature, create my own libraries. But if those are spread between another 1k libraries, it kind of becomes useless. Thank you for the time to read my post! Hi, there is currently no way to ignore them, but this question has come up before. We can look at adding a library option into the 4.7 release. Thanks.
Happy2Play 9814 Posted November 16, 2021 Posted November 16, 2021 30 minutes ago, Luke said: Hi, there is currently no way to ignore them, but this question has come up before. We can look at adding a library option into the 4.7 release. Thanks. At a minimum it needs to be default collapsed. 1 2
Luke 42256 Posted January 4, 2022 Posted January 4, 2022 On 1/3/2022 at 10:59 AM, popy said: +1 for this. @LukeAny news on this? Not yet but it is in our plans to make it more controllable in future updates. Thanks.
DonMacaroni 55 Posted March 29, 2022 Posted March 29, 2022 (edited) On 11/16/2021 at 10:37 PM, Happy2Play said: At a minimum it needs to be default collapsed. Yes, I completely agree on that, currently that sidebar can get easily very long. I personally have ~120 playlists, that means lots of sidebar scrolling Edited March 29, 2022 by DonMacaroni 1
thelanranger 11 Posted March 4, 2023 Posted March 4, 2023 I'd also like to bump this for some mechanism to ignore playlist files that are on the system being added. Same as above. Making custom playlists is useful for music but having it import the 5,000 .m3u files of the list of albums is completely pointless but I can't really delete those files if they're part of torrents/collections. There needs to be a way (in general, not just playlists) to ignore specific file types in a given library. The mechanism would also be useful to ignore other types of media from being added to libraries by ignoring *.mov or something that you would like to keep in the movies folder but don't want inside of emby.
Happy2Play 9814 Posted March 4, 2023 Posted March 4, 2023 7 minutes ago, thelanranger said: Making custom playlists is useful for music but having it import the 5,000 .m3u files Did you see the option in library setup? Import playlist files Playlists found in your media directories can be imported into Emby Server. 1
worthmo 12 Posted January 27 Posted January 27 Was this feature added? I created a few playlist for music and now the left hand column has a playlist menu that is expanded with each login.
