Luke 42245 Posted September 7, 2022 Posted September 7, 2022 @FrostByte do you get passthrough with the standard app?
FrostByte 5454 Posted September 7, 2022 Posted September 7, 2022 49 minutes ago, Luke said: @FrostByte do you get passthrough with the standard app? I don't have any issue with the standard app passing through any audio format on my Shield. Everything lights up on the AVR that its coming through correctly. 1
SuperCurro 4 Posted September 8, 2022 Posted September 8, 2022 Any feedback from Amazon FireTV stick?
Luke 42245 Posted September 8, 2022 Posted September 8, 2022 6 hours ago, SuperCurro said: Any feedback from Amazon FireTV stick? I'm sure @ebrhas tested passthrough with it.
ebr 16337 Posted September 8, 2022 Posted September 8, 2022 7 hours ago, SuperCurro said: Any feedback from Amazon FireTV stick? The stick has limited audio format support (especially depending on exactly which stick). Can we please look at a specific example?
SuperCurro 4 Posted September 10, 2022 Posted September 10, 2022 Hi. I am talking about the Fire TV Stick 4K Max. I thought you dont need support, just passthrough. Sony doesnt have any problem to do passthrough from HDMI, all the problem is the passthrough with andoid app, only VLC do it well. So a walk around is to buy a Fire TV Stick 4k Max and play emby from there, doing passthrough over FireTV to HDMI to the Sony TV and then to the Home cinema. Or if you have a HDMI Homecinema plug the Fire TV to it. Thanks in advance.
ebr 16337 Posted September 10, 2022 Posted September 10, 2022 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
