raven-au 17 Posted December 28, 2020 Posted December 28, 2020 On 12/6/2020 at 4:45 AM, ebr said: No, you would not be. I think there are actually three cases. 1. Shield connected to receiver/soundbar. Works fine if supported by receiver/soundbar, not relevant. 2. Shield connected to TV, TV supports ARC only. Probably doesn't work for other than 2 channel audio, DTS passthrough hadn't worked for me in the past on the TV so I haven't really tested passing it through ARC. It may have worked and may have stopped working. Basically, passing audio through the TV with ARC just wasn't versatile enough so I connect everything that needs to play DTS or better audio directly to the reciever/soundbar. 3. Shield connected to TV, TV supports eARC. Works for all audio formats I have tried (Sony Andriod TV) including TrueHD Atmos and DTS:X even though apps on the TV itself still can't pass-through anything except Dolby Digital @ 448k. Actually, I haven't tried sending DTS from apps over eARC for ages because it hadn't worked in the past so I add an extra Dolby Digital track @ 448k so I can also play then on the TV.
HanzoX7 11 Posted December 28, 2020 Posted December 28, 2020 14 hours ago, raven-au said: I think there are actually three cases. 1. Shield connected to receiver/soundbar. Works fine if supported by receiver/soundbar, not relevant. 2. Shield connected to TV, TV supports ARC only. Probably doesn't work for other than 2 channel audio, DTS passthrough hadn't worked for me in the past on the TV so I haven't really tested passing it through ARC. It may have worked and may have stopped working. Basically, passing audio through the TV with ARC just wasn't versatile enough so I connect everything that needs to play DTS or better audio directly to the reciever/soundbar. 3. Shield connected to TV, TV supports eARC. Works for all audio formats I have tried (Sony Andriod TV) including TrueHD Atmos and DTS:X even though apps on the TV itself still can't pass-through anything except Dolby Digital @ 448k. Actually, I haven't tried sending DTS from apps over eARC for ages because it hadn't worked in the past so I add an extra Dolby Digital track @ 448k so I can also play then on the TV. Absolutely right. I'm about to get a new TV with eARC... side-stepping the issue altogether. Sony or Google broke DTS passthrough over ARC as I can confirm it was working before. Emby can transcode DTS (and other formats) to AC3, so it can passthrough. The quality is quite good, I couldn't hear a difference.
raven-au 17 Posted December 31, 2020 Posted December 31, 2020 On 12/28/2020 at 9:46 AM, raven-au said: 3. Shield connected to TV, TV supports eARC. Works for all audio formats I have tried (Sony Andriod TV) including TrueHD Atmos and DTS:X even though apps on the TV itself still can't pass-through anything except Dolby Digital @ 448k. Actually, I haven't tried sending DTS from apps over eARC for ages because it hadn't worked in the past so I add an extra Dolby Digital track @ 448k so I can also play then on the TV. Nit to myself. That "can't pass-through anything except Dolby Digital @ 448k" should be "can't pass-through anything greater than Dolby Digital @ 448k". It took me a while to realize this was why I was having trouble (long time ago now). As far as I understand this is quite normal and some TVs only support up to 384k (rare I think).
HanzoX7 11 Posted January 2, 2021 Posted January 2, 2021 (edited) I'm really happy with the new TV (Sony XBR-55X905H), image quality blows away my previous XBR-55X805E. However, there's a big gotcha. Both my TV and amp support EARC, but TV internal apps can't passthrough any of the more advanced codecs. At least in my new TV, not even the "default" app can do it. I tested hooking my PS4 to the TV directly and playing a few blu-rays with DTS-MA and Dolby TrueHD and it was able to passthrough to my amp with 0 issues. Several posts on Plex and Kodi forums seem to indicate a general issue, not isolated to a specific brand. There are some exceptions, like tracks encoded as Dolby Digital Plus with Atmos, (not the same as pure Atmos) work fairly good... Likely due streaming apps (Netflix, Amazon Video, Disney+) use this format. The best way to handle passthrough audio is with an Nvidia Shield... or wait and see if EARC will ever open up for TV apps to passthrough and live up to its full potential. Edited January 2, 2021 by HanzoX7
raven-au 17 Posted January 9, 2021 Posted January 9, 2021 On 1/3/2021 at 2:20 AM, HanzoX7 said: There are some exceptions, like tracks encoded as Dolby Digital Plus with Atmos, (not the same as pure Atmos) work fairly good... Likely due streaming apps (Netflix, Amazon Video, Disney+) use this format. The best way to handle passthrough audio is with an Nvidia Shield... or wait and see if EARC will ever open up for TV apps to passthrough and live up to its full potential. I suspect this is deliberate on the part of the TV manufactures. I also suspect that if it wasn't for such things as Blu-Ray players that people expect to connect to the TV and work we wouldn't see this passthru working at all.
SuperCurro 4 Posted August 6, 2022 Posted August 6, 2022 Nowdays the only way to do passthrough with Emby in a Sony TV is with VLC that finally works well. The only problem is that doesnt syncronize where you stop the movie.
Luke 42245 Posted August 6, 2022 Posted August 6, 2022 10 hours ago, SuperCurro said: Nowdays the only way to do passthrough with Emby in a Sony TV is with VLC that finally works well. The only problem is that doesnt syncronize where you stop the movie. HI, why do you think that? The Emby android app supports passthrough without having to use VLC.
SuperCurro 4 Posted August 7, 2022 Posted August 7, 2022 Sorry boss, I know it is in the feature list of the emby andoid app, but it doesnt work. Only the sony native player and the VLC woks. I spent quite a lot of time about this topic of the passthrough, perhaps I didnt find the right option in the emby APP but if it is somewhere I didnt ready anywhere (few hours looking in forums) how to configure emby to do the passthrough, cero messages about passthrough working in android tv or google tv and lot of messages about the passthrough doesnt work in emby. VLC didnt work a few month ago but now works perfectly, smooth in any scenario (like the emby app), works also with directplay (when you send the video through the mobile phone) etc. I really wish emby app to do the passthrough!. I am doing something wrong?
ebr 16337 Posted August 7, 2022 Posted August 7, 2022 The Android system in the TV probably does not report support for DTS but that fact that your receiver is receiving Dolby is curious. The TV must be converting it. What are the audio settings on the TV Android system itself? Have you tried playing with those?
SuperCurro 4 Posted August 7, 2022 Posted August 7, 2022 Of course, in fact is working well with Sony player and VLC. Of course passthrough when the source is an HDMI is not a problem. But other app like emby, MX player, etc doesn't work. I tested all posible combinations and modes. You mean that the people confirmed that is working well with Sony and Android TV?
ebr 16337 Posted August 7, 2022 Posted August 7, 2022 22 minutes ago, SuperCurro said: You mean that the people confirmed that is working well with Sony and Android TV? No, I'm not aware of any Android TVs that report support for DTS through the normal Android system. This may be a licensing issue but that is just conjecture.
SuperCurro 4 Posted August 7, 2022 Posted August 7, 2022 I mean, does someone is doing DTS passthrough in a Sony TV with Android TV or Google TV using "EMBY". All the forums I read the people report only using the sony app player, but emby can not select this one for mkv, only mp4. One solution was just rename extensions. In my test emby app doesnt make passthrough but the video is perfect for any type of file. VLC also perfect but with DTS, DTS-MA, Dolby etc passthrough, and sony app player ok with passthrough but some files with stops of 3-4 seconds... The only one running perfect is VLC (at least in my TV).
Luke 42245 Posted August 7, 2022 Posted August 7, 2022 Can you try side loading our standard Android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks !
SuperCurro 4 Posted August 7, 2022 Posted August 7, 2022 I installed without problem. There is not an option to do passhthrough so, I just play... video no problem, audio only 2.0. I dont see any difference between one and the other, both can be used in the same way, both have autoframe but the normal version not sure why has the black levels in the movie wrong, instead of black was near black. So better use the emby for TV. Can someone confirm that passthrough works in Emby app for Android or Google TV? Regards.
ebr 16337 Posted August 8, 2022 Posted August 8, 2022 16 hours ago, SuperCurro said: Can someone confirm that passthrough works in Emby app for Android or Google TV? 22 hours ago, ebr said: No, I'm not aware of any Android TVs that report support for DTS through the normal Android system Our app is asking the Android system what is supported and I'm not aware of any TVs that report support for DTS. The internal player on the TV is probably not running in Android and VLC is probably using some sort of technique to "force" the stream that will have a bad outcome if hooked up to something that doesn't support it.
SuperCurro 4 Posted August 8, 2022 Posted August 8, 2022 (edited) Well, the TV has support to do passthrough, no problem with HDMI and with sony player and VLC player, but it doesnt have DTS itself, (although it converts the DTS signal in stereo Dolby.) As far as I know there is not TV that support DTS by itself but just passthrough. How many TVs are DTS certified with DTS speakers??? it doesnt make sense. The internal player is running in android, it is in the android APP list and you can tell to emby to use it for mp4 files as an external player. If you prefeer the sony player to the VLC you just have to rename the files from mkv to mp4. Regards Edited August 13, 2022 by SuperCurro
Luke 42245 Posted September 3, 2022 Posted September 3, 2022 On 8/7/2022 at 2:14 PM, Luke said: Can you try side loading our standard Android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks ! @SuperCurro can you try downloading the latest version and trying again? There are some DTS related fixes. Thanks !
SuperCurro 4 Posted September 3, 2022 Posted September 3, 2022 I am not able to download de apk, this didnt use to be a problem before.
SuperCurro 4 Posted September 7, 2022 Posted September 7, 2022 I am not able to download de apk, this didnt use to be a problem before.
FrostByte 5454 Posted September 7, 2022 Posted September 7, 2022 Try going to GitHub first and then download it Emby.Releases/android at master · MediaBrowser/Emby.Releases (github.com)
ebr 16337 Posted September 7, 2022 Posted September 7, 2022 Hi. It looks like something in your network environment is blocking access to that Github url. 1
SuperCurro 4 Posted September 7, 2022 Posted September 7, 2022 You were right, something wrong with my computer (it was not the browser). I installed, it runs smooth (good player) but sound still stereo. No option to do passthrough so I could not test anything. I check the diferent audio options in the TV and just always stereo. Any idea? Regards
Luke 42245 Posted September 7, 2022 Posted September 7, 2022 2 minutes ago, SuperCurro said: You were right, something wrong with my computer (it was not the browser). I installed, it runs smooth (good player) but sound still stereo. No option to do passthrough so I could not test anything. I check the diferent audio options in the TV and just always stereo. Any idea? Regards HI, passthrough is automatic. You don't need to enable anything.
SuperCurro 4 Posted September 7, 2022 Posted September 7, 2022 Then it doesnt work. But the video player works very well with any content, much better than sony player and even better than VLC player. The VLC player has problem with the subtitles. If passthrough would work then the emby player would be the best by far.
