horstepipe 422 Posted December 4, 2020 Posted December 4, 2020 Hello just noticing when scraping episodes with themoviedb which contain two episodes in a single file, e.g. S01E01E02, only the first episode name and description is being fetched. That's not intended I hope? Makes searching for specific episode impossible. https://www.themoviedb.org/tv/44396-bob-the-builder-new-to-the-crew/season/1?language=de-DE
GrimReaper 4861 Posted December 4, 2020 Posted December 4, 2020 5 minutes ago, horstepipe said: Hello just noticing when scraping episodes with themoviedb which contain two episodes in a single file, e.g. S01E01E02, only the first episode name and description is being fetched. That's not intended I hope? Makes searching for specific episode impossible. https://www.themoviedb.org/tv/44396-bob-the-builder-new-to-the-crew/season/1?language=de-DE That should be aggregated, at least that is like that for me in format SxxExx-Exy, i get both episode names divided by comma and both episode description summarized into one entry. 1
horstepipe 422 Posted December 4, 2020 Author Posted December 4, 2020 hmm thanks @GrimReaper76, which server version are you running?
GrimReaper 4861 Posted December 4, 2020 Posted December 4, 2020 2 minutes ago, horstepipe said: hmm thanks @GrimReaper76, which server version are you running? 4.5.2. Stable
horstepipe 422 Posted December 4, 2020 Author Posted December 4, 2020 humm okay me too. So are you sure the info you checked is coming from theMOVIEdb and not theTVdb? 1
horstepipe 422 Posted December 4, 2020 Author Posted December 4, 2020 (edited) The show I'm referencing to has no info on thetvdb so Emby fetches it from themoviedb Edited December 4, 2020 by horstepipe
GrimReaper 4861 Posted December 4, 2020 Posted December 4, 2020 Just now, horstepipe said: humm okay me too. So are you sure the info you checked is coming from theMOVIEdb and not theTVdb? Oh, no, TVdb's my default provider. Skipped that. Too bad. 1
GrimReaper 4861 Posted December 4, 2020 Posted December 4, 2020 (edited) 4 minutes ago, horstepipe said: The show I'm referencing has no info on thetvdb so Emby fetches it from themoviedb Bob the Builder? I find that unusual. Wait. Edit: Ain't this the one from your screenshot? 78685? https://www.thetvdb.com/series/bob-the-builder Edited December 4, 2020 by GrimReaper76
horstepipe 422 Posted December 4, 2020 Author Posted December 4, 2020 yes but here in Germany they're seperated, so from season 16 or so it is a rebrand because they changed the animation style. And that's honored by themoviedb.
GrimReaper 4861 Posted December 4, 2020 Posted December 4, 2020 Just now, horstepipe said: yes but here in Germany they're seperated, so from season 16 or so it is a rebrand because they changed the animation style. And that's honored by themoviedb. Oh, I get it now. Cause I remember from wjen junior was hooked on it, it had quite renown internationally.
GrimReaper 4861 Posted December 4, 2020 Posted December 4, 2020 That particular 52-ep season is actually Season 19 on tvdb. Maybe batch rename and pull metadata, as a workaround?
horstepipe 422 Posted December 4, 2020 Author Posted December 4, 2020 yes sure but that won't solve the problem in general 1
horstepipe 422 Posted December 4, 2020 Author Posted December 4, 2020 and as thetvdb currently makes some questionable decisions, lots of people will switch to themoviedb probably soon...
GrimReaper 4861 Posted December 4, 2020 Posted December 4, 2020 Just now, horstepipe said: yes sure but that won't solve the problem in general Yeah, but, I reckon, still faster then waiting for a fix.
Happy2Play 9802 Posted December 4, 2020 Posted December 4, 2020 2 hours ago, horstepipe said: @Happy2Play can you reproduce? Yes only the first episode is queried from TMDB. Pretty sure this has been mentioned before. @LukeIs TVDB the only provider that can do multi-episode fetching?
Luke 42205 Posted December 4, 2020 Posted December 4, 2020 2 minutes ago, Happy2Play said: Yes only the first episode is queried from TMDB. Pretty sure this has been mentioned before. @LukeIs TVDB the only provider that can do multi-episode fetching? I'll have to check but there's a good chance that is true.
horstepipe 422 Posted December 5, 2020 Author Posted December 5, 2020 I don’t get it, why can’t you just fetch each single episode and merge them serverside?
Luke 42205 Posted December 6, 2020 Posted December 6, 2020 That might be possible. It just wasn't really a concern a long time ago when this was built. 1
