BMStroh 3 Posted December 4, 2020 Posted December 4, 2020 Are these settings available on the Apple TV app? I spent a bit playing with the remote earlier trying to find anything in the few menus available - no luck. Just curious.
corey 317 Posted December 4, 2020 Posted December 4, 2020 You should be able to find them under Settings > Playback.
BMStroh 3 Posted December 4, 2020 Author Posted December 4, 2020 Thanks! I was looking in the player where it usually lives on the web and iOS clients. I found the quality settings, but not playback speed - guessing that hasn't made it yet. I should probably do some homework and see what the pros and cons of the MPV are while I'm nearby.
corey 317 Posted December 4, 2020 Posted December 4, 2020 55 minutes ago, BMStroh said: Thanks! I was looking in the player where it usually lives on the web and iOS clients. I found the quality settings, but not playback speed - guessing that hasn't made it yet. Correct the native player doesn't have a UI for playback speed and we haven't introduced the option into the MPV player yet.
MortigiTempo 6 Posted July 13, 2022 Posted July 13, 2022 On 12/4/2020 at 7:43 AM, corey said: Correct the native player doesn't have a UI for playback speed and we haven't introduced the option into the MPV player yet. Is adding playback speed options to Apple TV still in the works?
Luke 42241 Posted July 13, 2022 Posted July 13, 2022 6 hours ago, MortigiTempo said: Is adding playback speed options to Apple TV still in the works? Hi, yes it is. 1
