lja 51 Posted August 19, 2016 Posted August 19, 2016 (edited) But aren't the themes in extras/skin themes color themes? At least they appear there in kodi Gesendet von meinem HTC One M8 mit Tapatalk @ shorty1483 Yes. OK. It looks like this is not a problem. By the way, I would like to try your theme. What is the process to install? How to get this screen image? Thanks. https://dl.dropboxusercontent.com/u/19298307/Titan_Avalon.jpg Edited August 19, 2016 by lja
sh0rty 727 Posted August 19, 2016 Posted August 19, 2016 See my post above. Install color theme an set up like in the post. gesendet von meinem Galaxy Tab S2 LTE
lja 51 Posted August 19, 2016 Posted August 19, 2016 See my post above. Install color theme an set up like in the post. gesendet von meinem Galaxy Tab S2 LTE Thanks.
e123enitan 276 Posted August 20, 2016 Posted August 20, 2016 Hi Marcel, I just installed the latest Beta, see log, bunch of errors looks like Skin related, the smarch short still have issue. Does anyone else see experienced these issues, or it's just me. Thanks Kodi Log.txt
marcelveldt 736 Posted August 24, 2016 Author Posted August 24, 2016 Hi Marcel, I just installed the latest Beta, see log, bunch of errors looks like Skin related, the smarch short still have issue. Sorry but you keep sending archived logfiles. I need the actual logfile from Kodi, located in /storage/.kodi/temp/kodi.log Best way to retrieve is to by using SSH to your box or use the xbmc log uploader addon.
e123enitan 276 Posted August 24, 2016 Posted August 24, 2016 Sorry but you keep sending archived logfiles. I need the actual logfile from Kodi, located in /storage/.kodi/temp/kodi.log Best way to retrieve is to by using SSH to your box or use the xbmc log uploader addon. Thanks for your response, sorry for some reason Kodi Log uploader is not working, I will try SSH and get back to you.
Angelblue05 4132 Posted August 24, 2016 Posted August 24, 2016 Apparently, xbmclogs is dead. http://forum.kodi.tv/showthread.php?tid=287652 Sent from my iPhone using Tapatalk
e123enitan 276 Posted August 24, 2016 Posted August 24, 2016 Nice are there any other tool for generating /posting log? Thanks
sea3pea0 5 Posted August 30, 2016 Posted August 30, 2016 (edited) Ever since I switched from an sql server setup to Media Browser integration the feature "Disable Kodi screensaver on fullscreen music playback" stopped working. Anyone else experiencing this? I love this feature, would really like to get it working again.. Update: Here are my logs from Kodi Update: I figured out that using display scaling on my fire tv was causing this. When I turned off display scaling all was back to normal. Edited September 9, 2016 by sea3pea0
Delphi 83 Posted August 31, 2016 Posted August 31, 2016 Kodi Logfile Uploader http://forum.kodi.tv/showthread.php?tid=288153
e123enitan 276 Posted September 4, 2016 Posted September 4, 2016 Sorry but you keep sending archived logfiles. I need the actual logfile from Kodi, located in /storage/.kodi/temp/kodi.log Best way to retrieve is to by using SSH to your box or use the xbmc log uploader addon. HI Marcel, here are series of logs that I generated, hope it helps https://paste.ubuntu.com/23129527/ https://paste.ubuntu.com/23129539/ https://paste.ubuntu.com/23129558/ https://paste.ubuntu.com/23129560/
marcelveldt 736 Posted September 7, 2016 Author Posted September 7, 2016 HI Marcel, here are series of logs that I generated, hope it helps https://paste.ubuntu.com/23129527/ https://paste.ubuntu.com/23129539/ https://paste.ubuntu.com/23129558/ https://paste.ubuntu.com/23129560/ Ok, I will take a look at them, thanks
e123enitan 276 Posted September 7, 2016 Posted September 7, 2016 Thanks, I missed the skin, it has been 3 months or more that I have enjoyed it last. Something is definately skewed in logic that may have cause the problem from recurring, let know when to test or if additional log is required pls let me know. Cheers
e123enitan 276 Posted September 9, 2016 Posted September 9, 2016 Ok, I will take a look at them, thanks Hi Marcel, just a gentle nudge, any update?
blublub 10 Posted October 9, 2016 Posted October 9, 2016 (edited) Hi The current "skin helper script " somehow prevents Kodi from properly shutdown / restart - it just sits unresponsive for ages. Log file: http://pastebin.com/q9hTQtKL thx PS: I tried version .100 and .110 - so standard and beta Edited October 9, 2016 by blublub
e123enitan 276 Posted October 9, 2016 Posted October 9, 2016 (edited) Post Hi The current "skin helper script " somehow prevents Kodi from properly shutdown / restart - it just sits unresponsive for ages. Log file: http://pastebin.com/q9hTQtKL thx PS: I tried version .100 and .110 - so standard and beta Marcel more active and responsive on Kodi forum, post your issue here http://forum.kodi.tv/forumdisplay.php?fid=212 Edited October 9, 2016 by e123enitan
blublub 10 Posted October 10, 2016 Posted October 10, 2016 Post Marcel more active and responsive on Kodi forum, post your issue here http://forum.kodi.tv/forumdisplay.php?fid=212 k, thx - posted there
marcelveldt 736 Posted October 10, 2016 Author Posted October 10, 2016 Hi Marcel, just a gentle nudge, any update? Do you still have issues with the latest beta Emby version and latest beta skin version ?
e123enitan 276 Posted October 10, 2016 Posted October 10, 2016 Do you still have issues with the latest beta Emby version and latest beta skin version ? Hi Marcel, Good to heard from you, thanks for asking the issue still persist, my smart short cuts Back drop rotations reported several times still not resolved, I am on the latest version Ver3.6.86 01_KODI.log
e123enitan 276 Posted October 11, 2016 Posted October 11, 2016 Hi The current "skin helper script " somehow prevents Kodi from properly shutdown / restart - it just sits unresponsive for ages. Log file: http://pastebin.com/q9hTQtKL thx PS: I tried version .100 and .110 - so standard and beta Same here, I had to rebuild my Kodi to get thing working without Titan
blublub 10 Posted October 11, 2016 Posted October 11, 2016 Same here, I had to rebuild my Kodi to get thing working without Titan Hi Can you chime in here: http://forum.kodi.tv/showthread.php?tid=293463&pid=2434733#pid2434733 thx - for me just disabling/removing skin helper is enough for Kodi to run smoothly
altramarine 21 Posted October 17, 2016 Posted October 17, 2016 (edited) Sorry for the late reply. You get faster respponse when reporting on the official Kodi thread for the skin. Was this issue already fixed in recent (beta) versions of the skin ? Hi Marcel, Thanks for your response. I will contact you via Kodi forums in the future. I haven't checked if the issue is still there. I will do so today and report back. I am using the stable emby repo. Edited October 17, 2016 by altramarine
e123enitan 276 Posted November 6, 2016 Posted November 6, 2016 Hi Marcel, Pls I have issue with Titan when I try to create a smart short cut a short error log is snapped here below and a full log link is here too, appreciate if you can take a look and let me know when to revisit the titan install https://emby.media/community/index.php?/topic/41068-error-log-could-it-be-e4k-or-titan-issue/ 22:08:01 T:547522625536 ERROR: Unable to find plugin script.skin.helper.colorpicker <----------- script.skin.helper.colorpicker22:08:30 T:545452454112 ERROR: GetDirectory - Error getting /storage/.kodi/userdata/library/music22:08:30 T:545452454112 ERROR: Traceback (most recent call last):22:08:30 T:545452454112 ERROR: File "/storage/.kodi/addons/script.skinshortcuts/resources/lib/library.py", line 144, in loadLibrary22:08:30 T:545452454112 ERROR: self.musiclibrary()22:08:30 T:545452454112 ERROR: File "/storage/.kodi/addons/script.skinshortcuts/resources/lib/library.py", line 930, in musiclibrary <------ it's script.skinshortcuts22:08:30 T:545452454112 ERROR: self.addToDictionary( "music", listitems )22:08:30 T:545452454112 ERROR: NameError: global name 'listitems' is not defined https://paste.ubuntu.com/23418885/ https://paste.ubuntu.com/23418884/ Kodi logs.txt
Angelblue05 4132 Posted November 6, 2016 Posted November 6, 2016 @@e123enitan I suggest you post on the official Kodi forums, in the titan's skin thread so marcelveldt can see this. He replies way faster there, than here. Sent from my iPhone using Tapatalk
e123enitan 276 Posted November 6, 2016 Posted November 6, 2016 Thanks, I have reported the issue in Kodi>Titan thread, I hope he find time to address the issue, it has been on going for over six months that the issue was first reported. I hope he find time to resolved it.. Cheers!
