e123enitan 276 Posted August 12, 2016 Posted August 12, 2016 Hi Marcel, how could obtain log for skin activities, with the recent Beta, thinks does not look impressive on the custom user screen, the system lags a lot. Appreciate your feedback Thanks
e123enitan 276 Posted August 14, 2016 Posted August 14, 2016 HI Marcel, In the attached log, it appears that some error might relates to skin which I thought may interest you, sorry its a long list, hope you find it useful, if however I have raised false alarm accept my sincere apology. Thanks Kodi Log.txt
e123enitan 276 Posted August 14, 2016 Posted August 14, 2016 Hi Marcel -Kodi for Windows 7> Titan 3.6.78 Error extract from log file, just to note I have not include for Emby/Kodi add-on, this a just a fresh instal nothing installed yet. Hope you find the log useful. Thanks 15:07:29 T:4672 ERROR: CImageLoader::DoWork - Direct texture file loading failed for resource://resource.images.weathericons.default/.png 15:07:30 T:13216 NOTICE: Skin Helper Service --> skin helper service version 1.0.90 started 15:07:30 T:13216 NOTICE: Skin Helper Service --> WebService - start helper webservice on port 52307 15:07:34 T:11492 ERROR: Skin Helper Service --> Error in plugin.py --> name 'RECENTMUSICVIDEOS' is not defined 15:07:34 T:11492 ERROR: Traceback (most recent call last): 15:07:34 T:11492 ERROR: File "C:\Users\Media\AppData\Roaming\Kodi\addons\script.skin.helper.service\plugin.py", line 173, in <module> 15:07:34 T:11492 ERROR: Main() 15:07:34 T:11492 ERROR: File "C:\Users\Media\AppData\Roaming\Kodi\addons\script.skin.helper.service\plugin.py", line 149, in __init__ 15:07:34 T:11492 ERROR: plugincontent.getPluginListing(action,limit,refresh,optionalParam,randomize) 15:07:34 T:11492 ERROR: File "C:\Users\Media\AppData\Roaming\Kodi\addons\script.skin.helper.service\resources\lib\PluginContent.py", line 69, in getPluginListing 15:07:34 T:11492 ERROR: allItems = eval(action)(limit) 15:07:34 T:11492 ERROR: File "<string>", line 1, in <module> 15:07:34 T:11492 ERROR: NameError: name 'RECENTMUSICVIDEOS' is not defined 15:07:35 T:3400 ERROR: Skin Helper Service --> Error in plugin.py --> name 'RECENTMOVIES' is not defined 15:07:35 T:3400 ERROR: Traceback (most recent call last): 15:07:35 T:3400 ERROR: File "C:\Users\Media\AppData\Roaming\Kodi\addons\script.skin.helper.service\plugin.py", line 173, in <module> 15:07:35 T:3400 ERROR: Main() 15:07:35 T:3400 ERROR: File "C:\Users\Media\AppData\Roaming\Kodi\addons\script.skin.helper.service\plugin.py", line 149, in __init__ 15:07:35 T:3400 ERROR: plugincontent.getPluginListing(action,limit,refresh,optionalParam,randomize) 15:07:35 T:3400 ERROR: File "C:\Users\Media\AppData\Roaming\Kodi\addons\script.skin.helper.service\resources\lib\PluginContent.py", line 69, in getPluginListing 15:07:35 T:3400 ERROR: allItems = eval(action)(limit) 15:07:35 T:3400 ERROR: File "<string>", line 1, in <module> 15:07:35 T:3400 ERROR: NameError: name 'RECENTMOVIES' is not defined 15:07:36 T:10048 ERROR: Skin Helper Service --> Error in plugin.py --> name 'RECENTEPISODES' is not defined 15:07:36 T:10048 ERROR: Traceback (most recent call last): 15:07:36 T:10048 ERROR: File "C:\Users\Media\AppData\Roaming\Kodi\addons\script.skin.helper.service\plugin.py", line 173, in <module> 15:07:36 T:10048 ERROR: Main() 15:07:36 T:10048 ERROR: File "C:\Users\Media\AppData\Roaming\Kodi\addons\script.skin.helper.service\plugin.py", line 149, in __init__ 15:07:36 T:10048 ERROR: plugincontent.getPluginListing(action,limit,refresh,optionalParam,randomize) 15:07:36 T:10048 ERROR: File "C:\Users\Media\AppData\Roaming\Kodi\addons\script.skin.helper.service\resources\lib\PluginContent.py", line 69, in getPluginListing 15:07:36 T:10048 ERROR: allItems = eval(action)(limit) 15:07:36 T:10048 ERROR: File "<string>", line 1, in <module> 15:07:36 T:10048 ERROR: NameError: name 'RECENTEPISODES' is not defined
sh0rty 727 Posted August 15, 2016 Posted August 15, 2016 (edited) @@marcelveldt The generated resolutions for ebrs coverart plugin, I picked out the most common formats I've seen people using here on the forum: SideDisc Treatment "Diamond Discs" treated images: 664x720 - AR 0.92:1 (but I streched and everything until 0.98:1 seems fine) "ClearCase Discs" 696x706 - AR 0.99:1 "SideCase Discs" 754x780 - AR 0.97:1 As a middle, I think 0.98:1 should do. Stack Cover Treatment "Stack" treated image are a bit difficult, as the width varies on the amount of movies and the cover treatment for the single movie items: 4 Movies 845x1095 - AR 0.77:1 3 Movies 780x1030 - AR 0.76:1 2 Movies 715x965 - AR 0.74:1 As a middle, I think 0.76:1 should do. Misalignment in Titan Views I just took the views suitable (e.g. no landscape views). -Right List (cut off) -Big List (squeezed) -Big List 2 (too small) -Compact List (too small) -Panel (squeezed) -PanelDetails (squeezed) -PanelWall (squeezed) -DownPanel (squeezed) -BigPanel (squeezed) -BigPanelDetails (squeezed) -BigPanelWall (squeezed) -Horizontal Panels (squeezed) -BigPoster (squeezed) -PosterRow (cut off) -Scrolling Posters (cut off) -ShowCase (cut off) -Netflix (squeezed) Imo the nicest ones for a cool Boxset presentation are Right List, Big List, Big List 2, Poster Row, Scrolling Posters, Showcase and Netflix. I hope this is something you can work with. Cheers Edited August 15, 2016 by shorty1483 1
sh0rty 727 Posted August 16, 2016 Posted August 16, 2016 OT: Are you powermarcel10 from MePo Forum @@marcelveldt ?
marcelveldt 736 Posted August 16, 2016 Author Posted August 16, 2016 Hi Marcel, Any ideas regarding this issue? Many thanks Sorry for the late reply. You get faster respponse when reporting on the official Kodi thread for the skin. Was this issue already fixed in recent (beta) versions of the skin ?
e123enitan 276 Posted August 16, 2016 Posted August 16, 2016 Sorry for the late reply. You get faster respponse when reporting on the official Kodi thread for the skin. Was this issue already fixed in recent (beta) versions of the skin ? Hi Marcel, Good to heard from you, so you're suggesting Kodi is more efficient for you to respond to issues raised with Titan, therefore do you want these issues raised here be reinstate in Kodi?. Thanks
marcelveldt 736 Posted August 17, 2016 Author Posted August 17, 2016 Trying to do a little customizing beyond what the menus will allow... I'm using the Netflix layout and I have my favorites added as a widget row so I can get to my add-ons from the home screen. I love the look of the layout for movies and TV shows but when I get down to the add-ons it just looks kind of meh. I was able to change the fanart and icons for my add-ons but I cannot figure out if it's possible to add a logo and description so that my add-ons look similar to my movies and TV shows. I did some experimenting and I can't seem to make it work. Any ideas? There is an option in the (advanced) skin settings to enable artwork lookups for addons. That should get the result you're seeking for.
marcelveldt 736 Posted August 17, 2016 Author Posted August 17, 2016 Hi Marcel, Good to heard from you, so you're suggesting Kodi is more efficient for you to respond to issues raised with Titan, therefore do you want these issues raised here be reinstate in Kodi?. The Kodi threads for the skin are far more active, if you want to keep up with the latest news/updates it's good to follow the threads for the skin on the Kodi repo: http://forum.kodi.tv/forumdisplay.php?fid=212 Anyway, do you still have the issues you descibed in previous posts ? A lot of skin updates came out since then so it might be already resolved. Keep in mind that I suggest you to use the beta version of the skin if you want to have/use the latest bits of features.
marcelveldt 736 Posted August 17, 2016 Author Posted August 17, 2016 OT: Are you powermarcel10 from MePo Forum @@marcelveldt ? Sorry, no I'm not.
marcelveldt 736 Posted August 17, 2016 Author Posted August 17, 2016 @@shorty1483 thanks for the accurate research. I will go ahead and try to resolve the issues. I will post back here or on the Kodi forums (where you also seem to be active) when I have something to test for you. 1
marcelveldt 736 Posted August 18, 2016 Author Posted August 18, 2016 Imo the nicest ones for a cool Boxset presentation are Right List, Big List, Big List 2, Poster Row, Scrolling Posters, Showcase and Netflix. I am looking into it and this is going to be very hard to fix. The whole skin is aligned based on the normal aspect ratio's for posters, for example the watched indicators etc. etc. I was just experimenting with it by setting the aspect ratio not to stretch but it looks very strange now. Yeah the aspect ratio is now correct for the images but the images look really out of place now. That said, the cover art plugin has an option to respect the default aspect ratio, it's in the main settings for the plugin: "Use original art aspect ratio" Why not use that ? I'm going to test a little with that now but it looks promising.
sh0rty 727 Posted August 18, 2016 Posted August 18, 2016 (edited) I am looking into it and this is going to be very hard to fix. The whole skin is aligned based on the normal aspect ratio's for posters, for example the watched indicators etc. etc. I was just experimenting with it by setting the aspect ratio not to stretch but it looks very strange now. Yeah the aspect ratio is now correct for the images but the images look really out of place now. That said, the cover art plugin has an option to respect the default aspect ratio, it's in the main settings for the plugin: "Use original art aspect ratio" Why not use that ? I'm going to test a little with that now but it looks promising. No problem m8 if it's too hard to fix. Then I will just change the right list view to my delight like in the last versions. Or you just include my modifications for Right List 522 as a "Emby SideDisc View"? When using the original art aspect ration, the images will get more square because of the sidediscs. So the setting does not work in this case. View_522_RightList.xml Edited August 18, 2016 by shorty1483
marcelveldt 736 Posted August 18, 2016 Author Posted August 18, 2016 No problem m8 if it's too hard to fix. Then I will just change the right list view to my delight like in the last versions. Or you just include my modifications for Right List 522 as a "Emby SideDisc View"? When using the original art aspect ration, the images will get more square because of the sidediscs. So the setting does not work in this case. OK, I managed to fix it at an acceptable level. Are you on the beta repo ? I will provide a new beta skin version later today which includes the fixes. --> Make sure to enable "Emby coverart compatibility" in the skin settings -- general skin settings I'll upload the new beta skin tonight. 1
sh0rty 727 Posted August 18, 2016 Posted August 18, 2016 OK, I managed to fix it at an acceptable level. Are you on the beta repo ? I will provide a new beta skin version later today which includes the fixes. --> Make sure to enable "Emby coverart compatibility" in the skin settings -- general skin settings I'll upload the new beta skin tonight. Yip betA Repo, will give feedback. Thanks!
e123enitan 276 Posted August 18, 2016 Posted August 18, 2016 Ok, will upload new beta skin tonight. Currently enjoying the weather at the pool as its still my vacation Hi Marcel, appreciate you're taken your rest period to supports, however, is it reasonable to assumed that the issues that I reported have been fixed in the next update? Thanks
sh0rty 727 Posted August 18, 2016 Posted August 18, 2016 Ok, will upload new beta skin tonight. Currently enjoying the weather at the pool as its still my vacation Enjoy http://static.twoday.net/fabiano/images/retro-wohnwagen-merzedes-w-spaeth-chr.jpg
sh0rty 727 Posted August 19, 2016 Posted August 19, 2016 (edited) Ok, will upload new beta skin tonight. Currently enjoying the weather at the pool as its still my vacation Exceptional work! Every view mentioned is now working with Emby Collection coverart. Also a nice catch to take the plain not enhanced coverart for the views like Netflix or Showcase (if I guess right)! Finally a solution to have @@ebr 's great enhanced coverart in Emby and still using all the great Titan Kodi views simulaniously. You got a paypal donation address? Edited August 19, 2016 by shorty1483 1
e123enitan 276 Posted August 19, 2016 Posted August 19, 2016 Exceptional work! Every view mentioned is now working with Emby Collection coverart. Also a nice catch to take the plain not enhanced coverart for the views like Netflix or Showcase (if I guess right)! Finally a solution to have @@ebr 's great enhanced coverart in Emby and still using all the great Titan Kodi views simulaniously. You got a paypal donation address? @ Shorty, Nice screen, could your settings and screen views. Thanks
sh0rty 727 Posted August 19, 2016 Posted August 19, 2016 @@e123enitan https://1drv.ms/u/s!Ai4ct6wPYF8Eh_wWqIDd2ag-R2dy-Q Included is my Colortheme Titan_Avalon, my custom splashs and Logo and the background I made. Be sure to set the included background in background settings. My views are set to horizontal panel for every movie section, for series to Banner list, seasons to big Panel Details and episodes to Wide. My homescreen uses the enhanced all-in-one homescreen.
lja 51 Posted August 19, 2016 Posted August 19, 2016 Beta version Under Extras-skin themes there are a number of themes, however under settings only three appear. How can I get the others to appear?
sh0rty 727 Posted August 19, 2016 Posted August 19, 2016 Beta version Under Extras-skin themes there are a number of themes, however under settings only three appear. How can I get the others to appear? Mmh, on my 2 installations the themes are all appearing. Try reinstalling perhaps?
lja 51 Posted August 19, 2016 Posted August 19, 2016 Mmh, on my 2 installations the themes are all appearing. Try reinstalling perhaps? Thanks @ shorty1483. This is the screen to which I refer: https://dl.dropboxusercontent.com/u/19298307/theme.PNG
sh0rty 727 Posted August 19, 2016 Posted August 19, 2016 (edited) But aren't the themes in extras/skin themes color themes? At least they appear there in kodi Gesendet von meinem HTC One M8 mit Tapatalk Edited August 19, 2016 by shorty1483
