e123enitan 276 Posted March 8, 2016 Posted March 8, 2016 @@e123enitan You are using Kodi 15.2 Which is Kodi Isengard. Jarvis is version 16.... My fault I completely forgot I was on 15.2, my apology, I have wasted every one time
jluce50 122 Posted March 8, 2016 Posted March 8, 2016 I can't reproduce this on my dev machine so it appears to be fixed. Please test again in next skin update Latest update didn't fix it. A few more details. This appears to only happen with the Next Up smart shortcut widget.
marcelveldt 736 Posted March 9, 2016 Author Posted March 9, 2016 Latest update didn't fix it. A few more details. This appears to only happen with the Next Up smart shortcut widget. Ah, issue reproduced. will be fixed in next update
jluce50 122 Posted March 9, 2016 Posted March 9, 2016 Ah, issue reproduced. will be fixed in next update Excellent, thanks!
Zodler 18 Posted March 10, 2016 Posted March 10, 2016 (edited) I have only problems with this skin. I use widgets for Episodes in Progress and it does not work correctly. This skin has major major bugs and problems to show correctly Episode in Progress for example which is a simple thing. Edited March 10, 2016 by Zodler
Diedrich 380 Posted March 11, 2016 Posted March 11, 2016 I have only problems with this skin. I use widgets for Episodes in Progress and it does not work correctly. This skin has major major bugs and problems to show correctly Episode in Progress for example which is a simple thing."Episodes in Progress" works quite well, actually. Please provide more information: * With which version Titan are you experiencing this? * What version of Kodi? * What is the source for your library? Are you using Plex, Emby or is Kodi managing the library (video files)?
mootscicle 0 Posted March 12, 2016 Posted March 12, 2016 I've used the search as best I can and the issue of widgets refreshing way too frequently seems to have come up before but I couldn't find a solution further than that it would be fixed in an update but thats the problem i'm having now. I've got widgets for random movies and random episodes in the Windows 10 style home screen and they refresh very 5 seconds. I can't find any way to slow it down in the settings. The refreshing stops when i'm not connected to the internet so i'd imagine its in sync with the emby updates? I'm on Jarvis 16 and Titan 3.6.43. I attached a log of Kodi running for a few minutes if that helps kodi.txt
e123enitan 276 Posted March 15, 2016 Posted March 15, 2016 Hi Marcel, Could you provide on how to add search and year function to the submenu, I do know how to create submenu, but I couldn't find the exact locate to add these two functions, i mean folders/links where they are stored. Thanks
e123enitan 276 Posted March 16, 2016 Posted March 16, 2016 Hi Marcel, Could you provide on how to add search and year function to the submenu, I do know how to create submenu, but I couldn't find the exact locate to add these two functions, i mean folders/links where they are stored. Thanks I am able to locate the search and added to the submenu, but yet I am unable to locate the year, I will continue to research, however if you could point me to the location to grab this would save a lot of effort researching. Thanks
e123enitan 276 Posted March 16, 2016 Posted March 16, 2016 I am able to locate the search and added to the submenu, but yet I am unable to locate the year, I will continue to research, however if you could point me to the location to grab this would save a lot of effort researching. Thanks I just noticed that after adding the search to submenu, it actually populate a search movie or tv show, but the issue I experienced is when click on any of the item search it won't play or launch for further action, could you advice what might haven, or best I should provide a log, if this would help, pls let me know what your prefer. Thanks
lja 51 Posted March 18, 2016 Posted March 18, 2016 (edited) Is it possible to show genre in TV Guide as in the attached image? https://dl.dropboxusercontent.com/u/19298307/genre.JPG Also: Is it possible to have genre colours in the guide? Edited March 18, 2016 by lja
dark_slayer 103 Posted March 19, 2016 Posted March 19, 2016 General noob question, but how do you play trailers full screen? Starting a trailer from the video info screen plays in a small window inside video info Sent from my Nexus 7 using Tapatalk
Diedrich 380 Posted March 19, 2016 Posted March 19, 2016 General noob question, but how do you play trailers full screen? Starting a trailer from the video info screen plays in a small window inside video info Sent from my Nexus 7 using Tapatalk I apologize that this isn't a complete answer, I'm not at home to look for that info but... there is a setting for that somewhere in the settings menu.
jluce50 122 Posted March 22, 2016 Posted March 22, 2016 Playing the next episode from the NextUp notification doesn't seem to work. I started the first episode from a home screen widget if that matters. I believe this is the relevant portion of the log. Let me know if this should be posted in the NextUp thread. 18:42:09 T:124 NOTICE: libspotify: notified main thread 18:44:26 T:11116 NOTICE: EMBY KodiMonitor -> Method: Player.OnPause Data: {"item":{"title":"Muscle Cars","type":"movie","year":2008},"player":{"playerid":1,"speed":0}} 18:47:09 T:124 NOTICE: libspotify: notified main thread 18:47:10 T:9584 NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 24 18:47:10 T:9584 NOTICE: CDVDPlayerAudio::OutputPacket duplicate 4 packets of duration 24 18:47:10 T:11116 NOTICE: Previous line repeats 3 times. 18:47:10 T:11116 NOTICE: EMBY KodiMonitor -> Method: Player.OnPlay Data: {"item":{"title":"Muscle Cars","type":"movie","year":2008},"player":{"playerid":1,"speed":1}} 18:47:10 T:11116 NOTICE: EMBY KodiMonitor -> Item is invalid for playstate update. 18:47:10 T:9584 NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 24 18:48:38 T:11088 NOTICE: Previous line repeats 6 times. 18:48:38 T:11088 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.AttributeError'> Error Contents: 'xbmcgui.ControlTextBox' object has no attribute 'setLabel' Traceback (most recent call last): File "C:\Users\Jeremy\AppData\Roaming\Kodi\addons\service.nextup.notification\resources\lib\NextUpInfo.py", line 42, in onInit self.getControl(3001).setLabel(overview) AttributeError: 'xbmcgui.ControlTextBox' object has no attribute 'setLabel' -->End of Python script error report<-- 18:48:43 T:11088 NOTICE: nextup info onclick: 3012 18:48:43 T:11088 NOTICE: nextup info action: 7 18:48:43 T:11116 NOTICE: EMBY KodiMonitor -> Method: Other.NEXTUPWATCHEDSIGNAL Data: ["7b22657069736f64656964223a20313239307d"] 18:48:43 T:11756 NOTICE: Using Image Cache Thread Count: 0 -> 1 18:48:43 T:11756 NOTICE: plugin.video.emby started 18:48:43 T:11756 NOTICE: Parameter string: ?id=TV Shows&mode=nextup&limit=25&reload=2016032223104120160322231014 18:48:43 T:10644 NOTICE: CDVDPlayer::CloseFile() 18:48:43 T:10644 NOTICE: DVDPlayer: waiting for threads to exit 18:48:43 T:76 NOTICE: CDVDPlayer::OnExit() 18:48:43 T:76 NOTICE: Closing stream player 1 18:48:43 T:76 NOTICE: Waiting for audio thread to exit 18:48:43 T:9584 NOTICE: thread end: CDVDPlayerAudio::OnExit() 18:48:43 T:76 NOTICE: Closing audio device 18:48:43 T:76 NOTICE: Deleting audio codec 18:48:43 T:76 NOTICE: Closing stream player 2 18:48:43 T:76 NOTICE: waiting for video thread to exit 18:48:44 T:8476 NOTICE: thread end: video_thread 18:48:44 T:76 NOTICE: deleting video codec 18:48:44 T:10644 NOTICE: DVDPlayer: finished waiting 18:48:44 T:10644 NOTICE: DVDPlayer: Opening: 12x03 - Second-Hand Sports Saloon.avi 18:48:44 T:10312 NOTICE: Creating InputStream 18:48:44 T:10312 ERROR: CDVDPlayer::OpenInputStream - error opening [12x03 - Second-Hand Sports Saloon.avi] 18:48:44 T:10312 NOTICE: CDVDPlayer::OnExit() 18:48:44 T:10644 NOTICE: CDVDPlayer::CloseFile() 18:48:44 T:10644 NOTICE: DVDPlayer: waiting for threads to exit 18:48:44 T:10644 NOTICE: DVDPlayer: finished waiting 18:48:44 T:10644 NOTICE: CDVDPlayer::CloseFile() 18:48:44 T:10644 NOTICE: DVDPlayer: waiting for threads to exit 18:48:44 T:10644 NOTICE: DVDPlayer: finished waiting 18:48:44 T:11116 NOTICE: EMBY Player -> Clear playlist properties. 18:48:44 T:11116 NOTICE: EMBY Player -> Played_information: {'smb://192.168.0.5/TV Shows/Top Gear/Season 12/12x02 - Muscle Cars.avi': {'paused': False, 'refresh_id': '9b1f8458c6b47f85d1f932e8d1e53ed6', 'AudioStreamIndex': 1, 'SubtitleStreamIndex': '', 'currentPosition': 3641.64013671875, 'item_id': 'df97c1056765af186de2b5d34e2a1c8a', 'currentfile': 'smb://192.168.0.5/TV Shows/Top Gear/Season 12/12x02 - Muscle Cars.avi', 'runtime': 36659280000L, 'Type': 'Episode', 'playmethod': 'DirectPlay'}} 18:48:44 T:11116 NOTICE: EMBY Player -> Percent complete: 0.993374702591 Mark played at: 0.95 18:48:44 T:3672 NOTICE: Using Image Cache Thread Count: 0 -> 1 18:48:44 T:3672 NOTICE: plugin.video.emby started
jluce50 122 Posted March 29, 2016 Posted March 29, 2016 Found another problem. The Rotten Tomato scores seem to be miscalculated. All my movies are showing single digit scores.
Emby Tower 34 Posted March 31, 2016 Posted March 31, 2016 (edited) I've got a problem: If I play music, the discart doesn't appear. I've tried it with Aeon Nox and a Confluence Mod and everything was fine there... Edited March 31, 2016 by XBMC Workstation
Diedrich 380 Posted April 2, 2016 Posted April 2, 2016 I've got a problem: If I play music, the discart doesn't appear. I've tried it with Aeon Nox and a Confluence Mod and everything was fine there...Is it enabled in the skin's settings?
Emby Tower 34 Posted April 3, 2016 Posted April 3, 2016 Is it enabled in the skin's settings? Yes it is. After some tests I found out that is pure chance if the discart appears or not. There is no scheme ... With the view "landscapre single row" I could see that the discarts are present ...
altramarine 21 Posted April 8, 2016 Posted April 8, 2016 (edited) Hi,I've just installed Kodi Jarvis (16) with Emby stable repo + Titan skin and of course forgot to backup previous skin settings before uninstalling.Needless to say, I am looking to return a particular functionality.Using the the Titan 2 row default look, whenever I press up or down to retireve "Recently added" and then press episode or movie, it starts to play.The way I had it before, i was taken into TV show's root where seasons were listed instead of playing. Not sure what happened to the movies but idealy it'd be nice to be taken into "Info" instead direct play.I've gone through every setting in Titan skin settings and cannot find it for the life of me.Any help is appreciated:) Edited April 8, 2016 by altramarine
Diedrich 380 Posted April 8, 2016 Posted April 8, 2016 You will be editing the shortcuts in the shortcuts menu editor.
altramarine 21 Posted April 9, 2016 Posted April 9, 2016 Thanks dvgmar,Can you please elaborate?Shortcut menu editor can only point to a certain folder(Smart shortcuts in my case)I remember it being a settings, but cant figure out whichThank you!
justpig 27 Posted April 12, 2016 Posted April 12, 2016 Hello I am experiencing a bit of a problem. I am using the Windows 10 homescreen, the squares to the right that represent all movies/all tv shows, sets, recently added etc, no longer display the title. That is to say you can no longer tell what each square represents.
3dcooper 0 Posted April 18, 2016 Posted April 18, 2016 Hi there Guys may I ask for a little help? I'm running Shield ATV, SPMC16.2.1 (Titan 3.6.51) , Emby and Emby for Kodi 2.2.10. I am 99% there with my setup except a couple of niggles around music. I have selected Emby for Kodi Direct Stream and music plays fine but: - 1. Even though my library is 320kbps mp3 is always transcodes to 128kbps? 2. When I select play on "Highway to Hell" I get random fanart background as opposed to AC/DC (for example) Are these a limitation of the Emby Addon for Kodi (Direct stream) / Titan (Skin Helper) / (most likely) I'm doing something wrong :-) Thanks for your help Dave
jhoff80 94 Posted April 21, 2016 Posted April 21, 2016 I think my Titan must've updated in the past few days. I no longer have my unwatched counts on the main TV shows and main Movies pages, despite all settings that I can find being enabled. Also, not a fan of how the name of the widget (eg "Recommended TV shows") is now above the posters on the homescreen, it looked nicer on the bottom before. 1
totalhavoc 13 Posted April 23, 2016 Posted April 23, 2016 The latest beta seems to have changed the watched indicator from show the number of episodes unwatched to a percentage. The problem I'm seeing is the percentage on all my shows is listed at 0%. Honestly I like have the number better than percentage as I have kodi set to hide watched and sort by episodes. so the shows with the most watched episodes is always at the top. 1
