e123enitan 276 Posted March 6, 2016 Posted March 6, 2016 The stable version is available on the official Kodi repo only. The skin beta versions are on the Emby beta repo. So, the skin is NOT available on the emby stable repo. There are two in official repo, one is Titan -Version 3.5.81, not titled Jarvis, I am guessing this is the stable? The other is Isengard, I was expecting to see Jarvis as a Title as usual, could you mark the stable as Jarvis, to avoid confusion, thanks for your support.
puithove 209 Posted March 7, 2016 Posted March 7, 2016 (edited) Hi Marcel - I see the poster/flag alignment on the Poster Shift view is fixed in this version - Thanks! However, I have another one for you. The widgets on the horizontal single-row homescreen are overlapping the tiles if the "lower the widgets" option is enabled. If you turn the option off, the widgets are placed correctly. I've had it set with the lower option on for quite a while, it just started doing this when I updated last night. Edit: Noticed that this only seems to happen on 16:9 displays. on my 2160x1440 display, the widgets stay above the tiles. Edited March 7, 2016 by puithove 1
jluce50 122 Posted March 7, 2016 Posted March 7, 2016 Something appears to have broken when inline submenus are used with the vertical menu. Normally, if you click right on a menu item the submenu displays and then clicking right again selects an item in the widget. Now, when clicking right a second time, nothing happens. Both the menu and the widget items are unselectable. First click: Second click:
marcelveldt 736 Posted March 7, 2016 Author Posted March 7, 2016 There are two in official repo, one is Titan -Version 3.5.81, not titled Jarvis, I am guessing this is the stable? The other is Isengard, I was expecting to see Jarvis as a Title as usual, could you mark the stable as Jarvis, to avoid confusion, thanks for your support. You are not looking at the official kodi repo... The official version in Kodi repo is named just Titan... version 3.5.x is Isengard, version 3.6.x is Jarvis. the Kodi repo only lists the compatible version. In the beta repo each version has the Kodi version appended, so Titan BETA Isengard, Titan BETA Jarvis etc.
marcelveldt 736 Posted March 7, 2016 Author Posted March 7, 2016 Hi Marcel - I see the poster/flag alignment on the Poster Shift view is fixed in this version - Thanks! However, I have another one for you. The widgets on the horizontal single-row homescreen are overlapping the tiles if the "lower the widgets" option is enabled. If you turn the option off, the widgets are placed correctly. I've had it set with the lower option on for quite a while, it just started doing this when I updated last night. Edit: Noticed that this only seems to happen on 16:9 displays. on my 2160x1440 display, the widgets stay above the tiles. Thanks for the catch, will be fixed in next update. 1
marcelveldt 736 Posted March 7, 2016 Author Posted March 7, 2016 Something appears to have broken when inline submenus are used with the vertical menu. Normally, if you click right on a menu item the submenu displays and then clicking right again selects an item in the widget. Now, when clicking right a second time, nothing happens. Both the menu and the widget items are unselectable. I can't reproduce this on my dev machine so it appears to be fixed. Please test again in next skin update
e123enitan 276 Posted March 7, 2016 Posted March 7, 2016 You are not looking at the official kodi repo... The official version in Kodi repo is named just Titan... version 3.5.x is Isengard, version 3.6.x is Jarvis. the Kodi repo only lists the compatible version. In the beta repo each version has the Kodi version appended, so Titan BETA Isengard, Titan BETA Jarvis etc. I will double check Thanks
e123enitan 276 Posted March 8, 2016 Posted March 8, 2016 I will double check Thanks There is no Jarvis in the list of Kodi default skin
Angelblue05 4132 Posted March 8, 2016 Posted March 8, 2016 @@e123enitan Go to settings > add-ons > open the side panel, temporarily disable "Hide incompatible". Then go to Install from repository > Kodi Emby beta add-ons > Skin. What do you see? 1
e123enitan 276 Posted March 8, 2016 Posted March 8, 2016 (edited) @@e123enitan Go to settings > add-ons > open the side panel, temporarily disable "Hide incompatible". Then go to Install from repository > Kodi Emby beta add-ons > Skin. What do you see? I can't install, incompatible, so what should I do 3.6.46 " message" Addon is Incompatible of has bee maked broken in repository, Dependencies not met, please contact add on author" Edited March 8, 2016 by e123enitan
Angelblue05 4132 Posted March 8, 2016 Posted March 8, 2016 And the Kodi running is Jarvis? O.o Do the following, enable Kodi debug, then try to install Titan BETA (Jarvis). Post your Kodi log
e123enitan 276 Posted March 8, 2016 Posted March 8, 2016 And the Kodi running is Jarvis? O.o Do the following, enable Kodi debug, then try to install Titan BETA (Jarvis). Post your Kodi log Kodi debug or emby/kodi debug And the Kodi running is Jarvis? O.o Do the following, enable Kodi debug, then try to install Titan BETA (Jarvis). Post your Kodi log Kodi debug or emby/kodi debug?
e123enitan 276 Posted March 8, 2016 Posted March 8, 2016 Kodi debug or emby/kodi debug Kodi debug or emby/kodi debug? http://xbmclogs.com/pyxceg3zg
Angelblue05 4132 Posted March 8, 2016 Posted March 8, 2016 @@e123enitan your repository is out of date. Try this out, you can install the beta repo using this new method: http://emby.media/community/index.php?/topic/32196-new-fresh-install-method-no-side-loading/ Or just grab the new zip and install it: https://github.com/MediaBrowser/plugin.video.emby/wiki
e123enitan 276 Posted March 8, 2016 Posted March 8, 2016 http://xbmclogs.com/pyxceg3zg http://xbmclogs.com/pdzxvk6d8 http://xbmclogs.com/ph1m6jyen
Angelblue05 4132 Posted March 8, 2016 Posted March 8, 2016 @@e123enitan Why are you posting more logs? See my post #2196
e123enitan 276 Posted March 8, 2016 Posted March 8, 2016 @@e123enitan Why are you posting more logs? See my post #2196 http://xbmclogs.com/p9oiyzsfm http://xbmclogs.com/pcug3kaib SAME ISSUE Incompatability
Angelblue05 4132 Posted March 8, 2016 Posted March 8, 2016 @@e123enitan When did you try to install the skin in your previous log?
e123enitan 276 Posted March 8, 2016 Posted March 8, 2016 @@e123enitan When did you try to install the skin in your previous log? I just rebuild my openelec, install beta repo, turn on Kodi debug, try to install, same result, then pull log, would like me to repeat the processs again with a new log>?
Angelblue05 4132 Posted March 8, 2016 Posted March 8, 2016 Yes, get a new log. You just need to hit on the incompatible entry with Kodi debug. That's all. Don't rebuild anything.
e123enitan 276 Posted March 8, 2016 Posted March 8, 2016 Yes, get a new log. You just need to hit on the incompatible entry with Kodi debug. That's all. Don't rebuild anything. New Log http://xbmclogs.com/puap44c4k 1
Angelblue05 4132 Posted March 8, 2016 Posted March 8, 2016 It didn't install? There's no errors hmm... I will test on my side.
e123enitan 276 Posted March 8, 2016 Posted March 8, 2016 It didn't install? There's no errors hmm... I will test on my side. Ok Thanks for trouble shooting
Angelblue05 4132 Posted March 8, 2016 Posted March 8, 2016 @@e123enitan You are using Kodi 15.2 Which is Kodi Isengard. Jarvis is version 16....
