marcelveldt 736 Posted February 28, 2016 Author Posted February 28, 2016 I saw in another thread that Rotten Tomatoes support was added to the skin helper. Are there any plans to implement RT ratings in Titan? It's already supported since a long time. See the Video info screen.
lja 51 Posted February 28, 2016 Posted February 28, 2016 See the skin settings, you can customize the header now to your liking Thanks.
dark_slayer 103 Posted February 28, 2016 Posted February 28, 2016 You can choose the behaviour in the skin settings altough this option is not yet in the stable (will be tomorrow)You can choose extended info or native, but I'm saying the native skin info dialog appears to be missing the button to view cast. Used to be there longer ago. At one point you had to click up in the dialog to see cast as well
balkerman 7 Posted February 29, 2016 Posted February 29, 2016 (edited) I too am getting misaligned flags on posters: Edited February 29, 2016 by balkerman
jluce50 122 Posted February 29, 2016 Posted February 29, 2016 It's already supported since a long time. See the Video info screen. Ah, now that you mention it, I do remember seeing that. Any chance we might be able to replace the IMDB rating in the footer with the RT score?
borenson 0 Posted February 29, 2016 Posted February 29, 2016 Hi, I am getting an offset issue on landscape widgets. Also any chance of removing the background image on PVR widgets for clear art? Thanks
balkerman 7 Posted February 29, 2016 Posted February 29, 2016 I too am getting misaligned flags on posters: Last night I realised it was the poster, not the flag which was moved/misaligned. Hope this helps. Thanks for the skin! [emoji3]
Glyde62 50 Posted March 1, 2016 Posted March 1, 2016 Last night I realised it was the poster, not the flag which was moved/misaligned. Hope this helps. Thanks for the skin! [emoji3] Yeah I have noticed this for a few days now
jluce50 122 Posted March 2, 2016 Posted March 2, 2016 All of a sudden I'm getting the Skin Helper error I've seen mentioned before. I uninstalled and reinstalled Titan but it's still happening. 20:37:33 T:14864 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.ImportError'> Error Contents: No module named resources.lib.PluginContent Traceback (most recent call last): File "C:\Users\xxx\AppData\Roaming\Kodi\addons\script.skin.helper.service\plugin.py", line 3, in <module> import resources.lib.PluginContent as plugincontent ImportError: No module named resources.lib.PluginContent -->End of Python script error report<--
jluce50 122 Posted March 4, 2016 Posted March 4, 2016 Okay, I completely wiped all the skin data, reinstalled, and that seems to have resolved the skin helper error. However, now I'm getting this when I attempt to upgrade to 3.6.39. 08:20:07 T:4548 ERROR: EXCEPTION: Unknown addon id 'skin.titan.jarvisbeta'. 08:20:07 T:4548 ERROR: Skin Helper Service --> Error in setSkinVersion --> Unknown addon id 'skin.titan.jarvisbeta'. 08:20:07 T:4548 ERROR: Traceback (most recent call last): 08:20:07 T:4548 ERROR: File "C:\Users\Jeremy\AppData\Roaming\Kodi\addons\script.skin.helper.service\service.py", line 20, in checkSkinVersion 08:20:07 T:4548 ERROR: skinLabel = xbmcaddon.Addon(id=skin).getAddonInfo('name').decode("utf-8") 08:20:07 T:4548 ERROR: RuntimeError: Unknown addon id 'skin.titan.jarvisbeta'. 08:20:17 T:4548 ERROR: EXCEPTION: Unknown addon id 'skin.titan.jarvisbeta'. 08:20:17 T:4548 ERROR: Skin Helper Service --> Error in setSkinVersion --> Unknown addon id 'skin.titan.jarvisbeta'. 08:20:17 T:4548 ERROR: Traceback (most recent call last): 08:20:17 T:4548 ERROR: File "C:\Users\Jeremy\AppData\Roaming\Kodi\addons\script.skin.helper.service\service.py", line 20, in checkSkinVersion 08:20:17 T:4548 ERROR: skinLabel = xbmcaddon.Addon(id=skin).getAddonInfo('name').decode("utf-8") 08:20:17 T:4548 ERROR: RuntimeError: Unknown addon id 'skin.titan.jarvisbeta'. 08:20:27 T:4548 ERROR: EXCEPTION: Unknown addon id 'skin.titan.jarvisbeta'. 08:20:27 T:4548 ERROR: Skin Helper Service --> Error in setSkinVersion --> Unknown addon id 'skin.titan.jarvisbeta'. 08:20:27 T:4548 ERROR: Traceback (most recent call last): 08:20:27 T:4548 ERROR: File "C:\Users\Jeremy\AppData\Roaming\Kodi\addons\script.skin.helper.service\service.py", line 20, in checkSkinVersion 08:20:27 T:4548 ERROR: skinLabel = xbmcaddon.Addon(id=skin).getAddonInfo('name').decode("utf-8") 08:20:27 T:4548 ERROR: RuntimeError: Unknown addon id 'skin.titan.jarvisbeta'.
marcelveldt 736 Posted March 4, 2016 Author Posted March 4, 2016 Okay, I completely wiped all the skin data, reinstalled, and that seems to have resolved the skin helper error. However, now I'm getting this when I attempt to upgrade to 3.6.39. How did you install ? By using the repo ?
marcelveldt 736 Posted March 4, 2016 Author Posted March 4, 2016 Ah, now that you mention it, I do remember seeing that. Any chance we might be able to replace the IMDB rating in the footer with the RT score? Yes, that will be added later
marcelveldt 736 Posted March 4, 2016 Author Posted March 4, 2016 Hi, I am getting an offset issue on landscape widgets. Also any chance of removing the background image on PVR widgets for clear art? Thanks Where is the offset issue ? All widgets are correctly aligned to the right
jluce50 122 Posted March 4, 2016 Posted March 4, 2016 How did you install ? By using the repo ? Yeah, I used the new 1.0.5 repo.
marcelveldt 736 Posted March 4, 2016 Author Posted March 4, 2016 Yeah, I used the new 1.0.5 repo. Strange... does the skin work correctly ?
jluce50 122 Posted March 4, 2016 Posted March 4, 2016 Strange... does the skin work correctly ? Yes, 3.6.38 seems to work fine. It's just trying to upgrade to 39 that is causing problems.
marcelveldt 736 Posted March 4, 2016 Author Posted March 4, 2016 Yes, 3.6.38 seems to work fine. It's just trying to upgrade to 39 that is causing problems. My mistake, the version in the addon.xml is wrong so it's trying to upgrade over and over again. Will be fixed in next beta 1
Luke 42243 Posted March 4, 2016 Posted March 4, 2016 If anyone here seasoned with HTML, CSS, and JavaScript and interested in putting this to emby theater? PM me. Thanks:) 1
e123enitan 276 Posted March 5, 2016 Posted March 5, 2016 Hi Marcel, Titan Jarvis, is not avaialble for download in either emby/Kodi stable or beta, also I couldn't locate it among Kodi default skin. In the stable skin only Arctic is found, inside beta two Titan skins Helix and Isengard, any chance of looking into this at your convinient. Or could you provide link where I could download it and install directly on my system Thanks
e123enitan 276 Posted March 5, 2016 Posted March 5, 2016 Hi Marcel, Titan Jarvis, is not avaialble for download in either emby/Kodi stable or beta, also I couldn't locate it among Kodi default skin. In the stable skin only Arctic is found, inside beta two Titan skins Helix and Isengard, any chance of looking into this at your convinient. Or could you provide link where I could download it and install directly on my system Thanks Hi Marcel I just downloaded titan from here http://addons.kodi.tv/show/skin.titan/, but it won't install, I got error such as dependance etc not avaialble, thanks for looking into the issue http://xbmclogs.com/pgp7ul1ip
borenson 0 Posted March 6, 2016 Posted March 6, 2016 Where is the offset issue ? All widgets are correctly aligned to the right Sorry my mistake. Its not offset, it has just gone from having 4 items displaying in landscape to 3.
e123enitan 276 Posted March 6, 2016 Posted March 6, 2016 Hi Marcel I just downloaded titan from here http://addons.kodi.tv/show/skin.titan/, but it won't install, I got error such as dependance etc not avaialble, thanks for looking into the issue http://xbmclogs.com/pgp7ul1ip I have to report that, Titan Jarvis is not avaliable for download anywhere, I can confirm this for sure, coz on my new wetek box, same issue noted #2175-76 for Openelec general windows 7. Anyone noticed same issue? Cheers!
borenson 0 Posted March 6, 2016 Posted March 6, 2016 I have to report that, Titan Jarvis is not avaliable for download anywhere, I can confirm this for sure, coz on my new wetek box, same issue noted #2175-76 for Openelec general windows 7. Anyone noticed same issue? Cheers! Try here http://www.mb3admin.com/downloads/addons/xbmb3c/kodi-beta-repo/
marcelveldt 736 Posted March 6, 2016 Author Posted March 6, 2016 Sorry my mistake. Its not offset, it has just gone from having 4 items displaying in landscape to 3 Yes, sorry, you're right. I'll make sure to change it back to 4 asap.
marcelveldt 736 Posted March 6, 2016 Author Posted March 6, 2016 I have to report that, Titan Jarvis is not avaliable for download anywhere, I can confirm this for sure, coz on my new wetek box, same issue noted #2175-76 for Openelec general windows 7. Anyone noticed same issue? Cheers! The stable version is available on the official Kodi repo only. The skin beta versions are on the Emby beta repo. So, the skin is NOT available on the emby stable repo.
