marcelveldt 736 Posted January 7, 2016 Author Posted January 7, 2016 (edited) Was working, But had a skin helper service update and now they gone again Skin helper service is giving error. Going back to 1.0.25 of the Skin Helper Service fixed it What is the error ? Please post your log or the part with the error so I can fix it. EDIT: nvm, I found the error and fixed it. Edited January 7, 2016 by marcelveldt 1
Gustovier 4 Posted January 9, 2016 Posted January 9, 2016 I'm using kodi Jarvis beta 4 and I can't for the life of me get skin gui sounds to work. This is actually effecting all skins not just Titan. I have the gui sounds package downloaded. Even tried using confluence sounds and no dice. Has anybody seen this problem? Media (tv/movies) sound works just fine.
marcelveldt 736 Posted January 9, 2016 Author Posted January 9, 2016 I'm using kodi Jarvis beta 4 and I can't for the life of me get skin gui sounds to work. This is actually effecting all skins not just Titan. I have the gui sounds package downloaded. Even tried using confluence sounds and no dice. Has anybody seen this problem? Media (tv/movies) sound works just fine. This sounds like your sound device isn't configured correctly. Did you try to play a stereo MP3 file or radio stream ? Does that work ? If you're on Linux and you have a receiver attached to your setup there might be an issue with the handshake between the HTTPC and receiver over HDMI, I have the exact same issue on my openelec box in the living room and fixed it with some custom configuration to the sound device. If you go to Kodi Settings --> System --> Audio, at the top there will be a setting for the default audio device and more below is the audio device to be used for bitstreaming audio. Make sure the same device is setup there.
Glyde62 50 Posted January 9, 2016 Posted January 9, 2016 (edited) Problem I noticed tonight, After watching a show it was being marked as watched, But wasn't being hidden. If I went back to series level then back to episode it wasn't marked as watched anymore, But if I marked it watched manually it was hidden. Edited January 11, 2016 by Glyde62
jluce50 122 Posted January 11, 2016 Posted January 11, 2016 No, but I'm seeing a bunch of other weird issues. I created my homescreen shortcuts using the Emby shortcuts (to avoid the home videos) and now when I enter a library it automatically pops out the left sidebar (with sort options and whatnot). It's also stopped grouping movies into sets and the default action of Show Information doesn't work (items play when selected rather than showing the info screen).
marcelveldt 736 Posted January 11, 2016 Author Posted January 11, 2016 Problem I noticed tonight, After watching a show it was being marked as watched, But wasn't being hidden. If I went back to series level then back to episode it wasn't marked as watched anymore, But if I marked it watched manually it was hidden. Try to reset your kodi db with the emby addon settings, it sounds like some stuff is messed up. Note that this can happen when you're at the beta.
marcelveldt 736 Posted January 11, 2016 Author Posted January 11, 2016 No, but I'm seeing a bunch of other weird issues. I created my homescreen shortcuts using the Emby shortcuts (to avoid the home videos) and now when I enter a library it automatically pops out the left sidebar (with sort options and whatnot). It's also stopped grouping movies into sets and the default action of Show Information doesn't work (items play when selected rather than showing the info screen). Did you use the smart shortcuts ?
jluce50 122 Posted January 11, 2016 Posted January 11, 2016 Did you use the smart shortcuts ? No, I added them through the Emby addon (Add-ons -> Emby -> Movies -> Movies, or something like that). I thought that's what I needed to do to filter out the home videos...
marcelveldt 736 Posted January 11, 2016 Author Posted January 11, 2016 No, I added them through the Emby addon (Add-ons -> Emby -> Movies -> Movies, or something like that). I thought that's what I needed to do to filter out the home videos... It should both be fine, however using smart shortcuts is easier as it creates the submenu and images automatically for you. Skin settings --> Configure menu shortcuts --> Add --> Select smart shortcuts --> select your node
browned 33 Posted January 11, 2016 Posted January 11, 2016 I have one Shield TV and one PC that finishes playing a movie, and it starts it again. I haven't tested on my other Shield TV yet but I would assume it is the same. All running latest Kodi16b4, emby 1.1.72, titan 3.6.17.
Glyde62 50 Posted January 14, 2016 Posted January 14, 2016 Noticed today that when in any of my movie folders, backgrounds aren't changing to the movies backgrounds They are just staying on whatever the 1st movie was that was selected, Is only happening in Movies folders, TV Folders are working fine
Angelblue05 4132 Posted January 14, 2016 Posted January 14, 2016 Update the script skin helper to the latest version Sent from my iPhone using Tapatalk
Glyde62 50 Posted January 14, 2016 Posted January 14, 2016 Update the script skin helper to the latest version Sent from my iPhone using Tapatalk Have the latest version, no New one showing in updates
Angelblue05 4132 Posted January 14, 2016 Posted January 14, 2016 Ok, and what is the version for the emby add-on? You can open the info dialog for the add-on.
Glyde62 50 Posted January 14, 2016 Posted January 14, 2016 (edited) Ok, and what is the version for the emby add-on? You can open the info dialog for the add-on. 1.1.72 Discovered if I turn off "Use Extra Fan Art" it all works as expected Edited January 14, 2016 by Glyde62
marcelveldt 736 Posted January 15, 2016 Author Posted January 15, 2016 1.1.72 Discovered if I turn off "Use Extra Fan Art" it all works as expected @@Angelblue05 did you see this ? Could it be that we missed a spot when fixing the extrafanart ?
Angelblue05 4132 Posted January 15, 2016 Posted January 15, 2016 (edited) I've tested Titan, with emby for Kodi 1.1.72 and script helper 1.0.30 - Use Extra Fan Art enabled, it displays the correct artwork displayed from item to item in Movies, etc. I saw the problem Glyde62 mentioned, but since your fix, it's working as expected. @@Glyde62 Can you confirm the version of the script skin helper you have installed? I know I asked if you had the latest version, but I should have really confirmed the version. Thanks. Edited January 15, 2016 by Angelblue05
Glyde62 50 Posted January 15, 2016 Posted January 15, 2016 I've tested Titan, with emby for Kodi 1.1.72 and script helper 1.0.30 - Use Extra Fan Art enabled, it displays the correct artwork displayed from item to item in Movies, etc. I saw the problem Glyde62 mentioned, but since your fix, it's working as expected. @@Glyde62 Can you confirm the version of the script skin helper you have installed? I know I asked if you had the latest version, but I should have really confirmed the version. Thanks. Where do I check what version I have?
marcelveldt 736 Posted January 15, 2016 Author Posted January 15, 2016 Where do I check what version I have? I think the fastest is to go to video addons --> skin helper service
Glyde62 50 Posted January 16, 2016 Posted January 16, 2016 I think the fastest is to go to video addons --> skin helper serviceHave 1.0.30
Glyde62 50 Posted January 16, 2016 Posted January 16, 2016 (edited) Noticed today that when in any of my movie folders, backgrounds aren't changing to the movies backgrounds They are just staying on whatever the 1st movie was that was selected, Is only happening in Movies folders, TV Folders are working fine Had Emby Update Just before, Thought it may have fixed this problem, But still have to have Extra Fan Art turned off Edited January 16, 2016 by Glyde62
xnappo 1611 Posted January 17, 2016 Posted January 17, 2016 Hi @@marcelveldt - sorry if this has been covered I haven't read the whole thread. I am really liking the new(ish?) simple horizontal menu. One small thing that bugs my though is that when you are on the left-most or right-most item, it gets the focus. It would be less jarring if when you were on the first item, the focus stayed on the center selection and to the left was the last item and vice-versa. Simply stated, the focus should always stay centered.. xnappo
marcelveldt 736 Posted January 17, 2016 Author Posted January 17, 2016 Had Emby Update Just before, Thought it may have fixed this problem, But still have to have Extra Fan Art turned off I have just published an updated version of the skin, can you check if that resolves the issue ? 1
Glyde62 50 Posted January 18, 2016 Posted January 18, 2016 I have just published an updated version of the skin, can you check if that resolves the issue ? Yep that's fixed it thanks 2
