Glyde62 50 Posted January 5, 2016 Posted January 5, 2016 Hmm. And no one starts a thread to make me aware of this? Sent from my iPhone using Tapatalk I did mention it further up in this thread
Angelblue05 4132 Posted January 5, 2016 Posted January 5, 2016 (edited) Unfortunately, I wasn't aware of the issue until now. add-on issues should be posted in the main kodi section of this forum. Can you tell me the path of your shortcuts that do not work(missing artwork)? Thanks. I'll look into it. Sent from my iPhone using Tapatalk Edited January 5, 2016 by Angelblue05
Glyde62 50 Posted January 5, 2016 Posted January 5, 2016 They are all missing artwork except for live tv. not at pc at the moment so can't give more details
Glyde62 50 Posted January 5, 2016 Posted January 5, 2016 Isn't the first time this problem has happened, Have had exactly same problem another time, Maybe 6 months or so Not exactly sure
Angelblue05 4132 Posted January 5, 2016 Posted January 5, 2016 Ok, I thought you were saying that the latest beta was causing the issue and the only way to have it work was to use 1.1.62. Nevermind, if it turns out to be an add-on issue, let me know!
Glyde62 50 Posted January 5, 2016 Posted January 5, 2016 Ok, I thought you were saying that the latest beta was causing the issue and the only way to have it work was to use 1.1.62. Nevermind, if it turns out to be an add-on issue, let me know! Yes that's correct it's the latest beta, if I use previous beta shortcuts work fine
Angelblue05 4132 Posted January 5, 2016 Posted January 5, 2016 So version 1.1.70? 1.1.69 was fine? Let me know if that's what you meant by previous beta.
Glyde62 50 Posted January 5, 2016 Posted January 5, 2016 1.1.62 stable works fine 1.1.70 beta doesn't 1
Angelblue05 4132 Posted January 5, 2016 Posted January 5, 2016 Then it must be an add-on issue. I will look into it. Can you let me know your shortcut paths when you get the chance? It should help pinpoint where the issue is. Thanks
dark_slayer 103 Posted January 5, 2016 Posted January 5, 2016 Not to cloud the issue, but I just setup my new shield last night with the beta and Titan. I have images of all my recent episodes and movies. I was getting a content does not exist error until I disabled YouTube Checked in on the shield tonight and it updated with my latest sonarr episodes. Only using the beta repo
Angelblue05 4132 Posted January 5, 2016 Posted January 5, 2016 content does not exist? hm? Do you have the kodi log?
Glyde62 50 Posted January 5, 2016 Posted January 5, 2016 Then it must be an add-on issue. I will look into it. Can you let me know your shortcut paths when you get the chance? It should help pinpoint where the issue is. Thanks is this what you want? Smart Shortcuts>Movies>Movies I notice when using 1.1.70 when I go into Smart Shortcuts they little picture that is beside the Names isn't there, Just a white folder icon
e123enitan 276 Posted January 5, 2016 Posted January 5, 2016 (edited) 1.1.62 stable works fine 1.1.70 beta doesn't Yes to this this, I have noticed this for a while, it work fine on the stable/beta 1.1.62, on beta beyond 1.1.62 smart shortcut >>> backdrops rotations stopped working, I never get chance to report this issue, as I am not sure if its skin or addon related matter. Edited January 5, 2016 by e123enitan
marcelveldt 736 Posted January 5, 2016 Author Posted January 5, 2016 Not to cloud the issue, but I just setup my new shield last night with the beta and Titan. I have images of all my recent episodes and movies. I was getting a content does not exist error until I disabled YouTube Checked in on the shield tonight and it updated with my latest sonarr episodes. Only using the beta repo Yep, issue with using YouTube as widget. It is giving content provider exception errors. Just disable the widget for YouTube for now untill the issue is resolved.
marcelveldt 736 Posted January 5, 2016 Author Posted January 5, 2016 I am still not even sure this is an issue or if it is a problem with the addon or the skin helper, I was just reporting it here first to see if anyone else has had any issues. It has something to do with latest changes in the addon, that breaks the smart shortcuts compatability. @@Angelblue05 need any help ? I have some time now
dazed 27 Posted January 5, 2016 Posted January 5, 2016 I dont think I was using the youtube widget. I deleted all menu items except settings and adding in just my movie nodes from Emby. Is it using the youtube widget automatically for something? Simple question, how and where do I disable the YouTube widget? From here marcelveldt Wrote: For now just disable the widget for YouTube. Skin settings --> Configure menu shortcuts --> select the YouTube shortcut --> Press widgets --> Press select widget --> Select None I'll look for a permanent fix later this week.
dazed 27 Posted January 5, 2016 Posted January 5, 2016 Yeah if the buttons not there there's nothing to refresh. I have mine like this just click it when i want the addon
marcelveldt 736 Posted January 5, 2016 Author Posted January 5, 2016 So just to be clear here, the Youtube wiget is not causing the issue I am seeing then. My Emby smart menu items do not have artwork, this looks like it is a problem with the latest Emby Addon beta. Yeah, sorry about the confusion. Youtube widget is another error. I'm looking at the recent emby addon changes to fix the artwork. 1
marcelveldt 736 Posted January 6, 2016 Author Posted January 6, 2016 So do we know if it is an issue with the skin/skin helper or is it the new emby addon, I can do some work on the emby addon but would not know where to start with the skin. Issue was with the Emby addon. I have just fixed it on Git. Is it possible for you to grab the latest version from Git to check if the issues are resolved ? Note that after fresh start it can take a minute to refill the cache again with the images.
Glyde62 50 Posted January 6, 2016 Posted January 6, 2016 Issue was with the Emby addon. I have just fixed it on Git. Is it possible for you to grab the latest version from Git to check if the issues are resolved ? Note that after fresh start it can take a minute to refill the cache again with the images.Thanks for finding the problemLook forward to it once it's released
marcelveldt 736 Posted January 6, 2016 Author Posted January 6, 2016 Ok think I found it, checking in now. All issues now resolved ? 1
AgileHumor 123 Posted January 6, 2016 Posted January 6, 2016 Is there a "thumbnail" view for the "unwatched TV episodes (or series)" and "unwatched movies" images? I tried Recent Movies and Recent Episodes for the Titan skin thumbnail for TV and Movies icon.
e123enitan 276 Posted January 6, 2016 Posted January 6, 2016 All issues now resolved Thanks -I will give it a try tonight and keep you posted
Glyde62 50 Posted January 7, 2016 Posted January 7, 2016 (edited) I am not sure about ALL issues but the one I was having with artwork for the smart menu items is now fixed. Was working, But had a skin helper service update and now they gone again Skin helper service is giving error. Going back to 1.0.25 of the Skin Helper Service fixed it Edited January 7, 2016 by Glyde62
