marcelveldt 736 Posted December 15, 2015 Author Posted December 15, 2015 @@marcelveldt Titan Beta (Isengard) When upgrading I usually get a black screen while in process. Is it possible to have a spinning circle or some other indication that the upgrade is in process? Sorry, that is not possible. At that time Kodi is upgrading the skin itself which can take some time depending on system speed, file size etc.
marcelveldt 736 Posted December 15, 2015 Author Posted December 15, 2015 It's been a while, but I believe you'll have to add them to Favorites while in Confluence. Then when you switch to Titan you should be able to add them from Favorites. Indeed, adding to favorites is the way to go for now. In the future it might become possible to browse the android apps straight from the shortcuts customizer.
marcelveldt 736 Posted December 15, 2015 Author Posted December 15, 2015 Has any one seen this issue: http://forum.kodi.tv/showthread.php?tid=247525&pid=2175704#pid2175704 The skin.help addon for me throws an error on load. What error ?
marcelveldt 736 Posted December 15, 2015 Author Posted December 15, 2015 Well - first thing I tried was to change my forced view for episodes from List to Big List - and after that, issue went away. Changed back from Big List to List, and it came back. Then I turned off the forced view for episodes (still have forced view for other areas) but that doesn't make any change. Something maybe wrong with the list view for episodes - or some combination with another setting I have. I've tried all kinds of combinations but still couldn't reproduce this. Strange...
lja 51 Posted December 15, 2015 Posted December 15, 2015 Sorry, that is not possible. At that time Kodi is upgrading the skin itself which can take some time depending on system speed, file size etc. Thanks.
puithove 209 Posted December 16, 2015 Posted December 16, 2015 I've tried all kinds of combinations but still couldn't reproduce this. Strange... Alright. Definitely appreciate you taking a look at it. At some point when I have more time I may try starting all over from scratch and see how it goes (not restoring skin settings).
Yogi 367 Posted December 22, 2015 Posted December 22, 2015 Is there anyway to display season overview in card view, at the moment it is just picking up the series overview for all seasons. It shows in the web client and Emby for WMC but I cannot figure out how to make it show in Kodi. Example of The 100 with series and episode overview. https://www.themoviedb.org/tv/48866-the-100
Glyde62 50 Posted December 27, 2015 Posted December 27, 2015 Since the latest updates Home Screen tiles have no image, Have tried resetting them,But hasn't fixed the problem Have had problem before and fixed it but buggered if I remember how
browned 33 Posted December 27, 2015 Posted December 27, 2015 Emby 1.1.65+ updates seen to have changed the names of the images, at least on mine previous entries for images were movies, tv, kids movies, kids tv, now they appear as emby movies, emby tv, emby kids movies, emby kids tv. Changing them in the shortcut configuration fixes them up.
jluce50 122 Posted December 28, 2015 Posted December 28, 2015 Since the latest updates Home Screen tiles have no image, Have tried resetting them,But hasn't fixed the problem Have had problem before and fixed it but buggered if I remember how Yep, same here. None of the widgets seem to work at all.
Glyde62 50 Posted December 28, 2015 Posted December 28, 2015 (edited) Yep, same here. None of the widgets seem to work at all. Hopefully a fix be released soon, Has happened after updates before Edited December 28, 2015 by Glyde62
Glyde62 50 Posted December 28, 2015 Posted December 28, 2015 (edited) Actually think it is a Emby problem, Discovered if I went back to Emby 1.1.62 they all working again Well it did until I restarted Kodi again.........Oh well wait for a fix Edited December 28, 2015 by Glyde62
Angelblue05 4132 Posted December 30, 2015 Posted December 30, 2015 (edited) Yeah, I'm waiting on marcelveldt's response. The only issue I've noticed is fanart not changing when the cursor moves for movies. I already know the cause of the problem. However the cause is also the fix to other issues. So for now disabling extra fanart temporarily fixes the fanart problem. I'm waiting to see if marcelveldt can adjust his script accordingly. Edited December 30, 2015 by Angelblue05 1
marcelveldt 736 Posted January 2, 2016 Author Posted January 2, 2016 Is there anyway to display season overview in card view, at the moment it is just picking up the series overview for all seasons. It shows in the web client and Emby for WMC but I cannot figure out how to make it show in Kodi. Example of The 100 with series and episode overview. https://www.themoviedb.org/tv/48866-the-100 Kodi doesnt support season info, only series info.
marcelveldt 736 Posted January 2, 2016 Author Posted January 2, 2016 Yep, same here. None of the widgets seem to work at all. Latest Emby addon changes included changes to the way the views are loaded into Kodi which has impact on all smart shortcuts. Try resetting your shortcuts to defaults or re-add your emby nodes to your main menu to fix it.
Yogi 367 Posted January 3, 2016 Posted January 3, 2016 Kodi doesnt support season info, only series info. Thanks good to know!!
chrisoldroyd 12 Posted January 4, 2016 Posted January 4, 2016 Hi Guys, I need some help, after a recent update I am getting constant "Skin Helper Service Errors" using Kodi 15.2 and Titan stable latest version. I can no longer use Random Movie Artwork as backgrounds either so I guess this is linked, any way to sort this out? Thanks
browned 33 Posted January 4, 2016 Posted January 4, 2016 Hi Guys, I need some help, after a recent update I am getting constant "Skin Helper Service Errors" using Kodi 15.2 and Titan stable latest version. I can no longer use Random Movie Artwork as backgrounds either so I guess this is linked, any way to sort this out? Thanks I had an issue with the latest release and had to install a beautifulsoup 3.4.1 addon, error log suggested it was required but not found on my android tv devices. Once that was installed, Titan backup used for a restore and all was ok again. 2
rauldiz 2 Posted January 4, 2016 Posted January 4, 2016 Hi Guys, I need some help, after a recent update I am getting constant "Skin Helper Service Errors" using Kodi 15.2 and Titan stable latest version. I can no longer use Random Movie Artwork as backgrounds either so I guess this is linked, any way to sort this out? Thanks I had an issue with the latest release and had to install a beautifulsoup 3.4.1 addon, error log suggested it was required but not found on my android tv devices. Once that was installed, Titan backup used for a restore and all was ok again. Hello, thanks for this... I had the same problem as chrisoldroyd. I found that installing TVTunes from the Kodi repository (which I wanted anyway) installed beautifulsoup along with a few other plugin/addons. All seems to be fine now. 1
chrisoldroyd 12 Posted January 4, 2016 Posted January 4, 2016 I had an issue with the latest release and had to install a beautifulsoup 3.4.1 addon, error log suggested it was required but not found on my android tv devices. Once that was installed, Titan backup used for a restore and all was ok again. Thank you so much, that sorted all my issues, top man!
Glyde62 50 Posted January 4, 2016 Posted January 4, 2016 (edited) Latest Emby addon changes included changes to the way the views are loaded into Kodi which has impact on all smart shortcuts. Try resetting your shortcuts to defaults or re-add your emby nodes to your main menu to fix it. Tried all that but still no luck with the latest version Any other suggestions? Edited January 5, 2016 by Glyde62
foghat 65 Posted January 5, 2016 Posted January 5, 2016 Is it possible to add the viewing of chapter images and being able to start playing from a given chapter? I haven't seen this in any skin, so I am guessing that kodi does not support it?
Glyde62 50 Posted January 5, 2016 Posted January 5, 2016 Are there issues with titan and the latest Kodi addon beta. None of my smart menu items have images now, I have tried resetting and a fresh install.I have had the same problem for a week or so now, Only fix that's works for me so far is to not use the latest version of Emby.
Angelblue05 4132 Posted January 5, 2016 Posted January 5, 2016 Hmm. And no one starts a thread to make me aware of this? Sent from my iPhone using Tapatalk
