Tranquil 95 Posted September 23, 2015 Posted September 23, 2015 Ah okay, I see. Thanks for fast response!
bob808 2 Posted September 23, 2015 Posted September 23, 2015 is there an issue with the latest stable? I am getting a crash on bootup with pvr enabled on 15.1 (openelec 6 latest beta). With other skins I dont get the problem but with Titan it starts to load, shows the main menu and 'loading recordings' then reboots. If I pull the network cable I can disable the PVR and it then works, but with pvr enabled and titan it keeps rebooting. The default skin and artyc zephyr both work with no reboot so this seems to be skin specific. Any ideas?
puithove 209 Posted September 23, 2015 Posted September 23, 2015 Hmm, you're right... It's a Jarvis issue. It's fine on Isengard. I think it will be fixed soon, Jarvis is still at alpha stage.Ok cool. Wanted to let you know it was there. Thanks. Sent from my iPhone using Tapatalk
e123enitan 276 Posted September 23, 2015 Posted September 23, 2015 Marcel just wish to report that I am experiencing freezing when I tried to select any menu, it appears nothing is not right somewhere. http://xbmclogs.com/pat5ppfcn http://xbmclogs.com/pypvk5lhf There are errors in both logs, I am sure what could have casued the either emby or Titam or Openelec OS, anyway I shall rebuild Kodi from strach, with latest Beta Titan/Emby and see if the issue happen again. Thanks
jluce50 122 Posted September 24, 2015 Posted September 24, 2015 Have Next Up notifications been removed from the skin? I just realized I haven't seen them in a while...
marcelveldt 736 Posted September 24, 2015 Author Posted September 24, 2015 is there an issue with the latest stable? I am getting a crash on bootup with pvr enabled on 15.1 (openelec 6 latest beta). With other skins I dont get the problem but with Titan it starts to load, shows the main menu and 'loading recordings' then reboots. If I pull the network cable I can disable the PVR and it then works, but with pvr enabled and titan it keeps rebooting. The default skin and artyc zephyr both work with no reboot so this seems to be skin specific. Any ideas? There seems to be a bug currently which I'll fix later today. You have to disable grouping of recordings. 1
marcelveldt 736 Posted September 24, 2015 Author Posted September 24, 2015 Marcel just wish to report that I am experiencing freezing when I tried to select any menu, it appears nothing is not right somewhere. http://xbmclogs.com/pat5ppfcn http://xbmclogs.com/pypvk5lhf There are errors in both logs, I am sure what could have casued the either emby or Titam or Openelec OS, anyway I shall rebuild Kodi from strach, with latest Beta Titan/Emby and see if the issue happen again. Thanks I have been working on the "Forced Views" features in latest betas, possible that it contains a bug... Are you using forced views ? If so, please try to disable it and look if it's fixed
marcelveldt 736 Posted September 24, 2015 Author Posted September 24, 2015 Have Next Up notifications been removed from the skin? I just realized I haven't seen them in a while... No, should still be there although I haven't tested it for a while. Sure that it is enabled and configured correctly ?
puithove 209 Posted September 24, 2015 Posted September 24, 2015 Yea, Next Up Notifications works fine if you launched from the library view. Pretty sure it doesn't work if you launched from home screen widget. 1
jluce50 122 Posted September 24, 2015 Posted September 24, 2015 Yea, Next Up Notifications works fine if you launched from the library view. Pretty sure it doesn't work if you launched from home screen widget. Ah, that must be it. I watch most of my shows from the Next Up widget.
marcelveldt 736 Posted September 25, 2015 Author Posted September 25, 2015 Marcel just wish to report that I am experiencing freezing when I tried to select any menu, it appears nothing is not right somewhere. http://xbmclogs.com/pat5ppfcn http://xbmclogs.com/pypvk5lhf There are errors in both logs, I am sure what could have casued the either emby or Titam or Openelec OS, anyway I shall rebuild Kodi from strach, with latest Beta Titan/Emby and see if the issue happen again. Thanks The issues with freezing/crashing Kodi should now be fixed with the latest skin beta.
marcelveldt 736 Posted September 25, 2015 Author Posted September 25, 2015 Yea, Next Up Notifications works fine if you launched from the library view. Pretty sure it doesn't work if you launched from home screen widget. Maybe you should post that on the thread/forum for the NextUp Episodes addon, Might be that Ian isn't aware of the issue.
Glyde62 50 Posted September 25, 2015 Posted September 25, 2015 Having problems with Titan Beta today, When I open a collection (Movies,TV etc) I cant scroll shows On the Home screen I can move from item to item with keyboard or remote Works fine when I try other skins
marcelveldt 736 Posted September 25, 2015 Author Posted September 25, 2015 Having problems with Titan Beta today, When I open a collection (Movies,TV etc) I cant scroll shows On the Home screen I can move from item to item with keyboard or remote Works fine when I try other skins That should be fixed in the 3.5.11 versio. Can you confirm?
Glyde62 50 Posted September 25, 2015 Posted September 25, 2015 (edited) Link for Beta repo on fist page doesn't seem to be working My version says 3.5.12 Edited September 25, 2015 by Glyde62
Glyde62 50 Posted September 25, 2015 Posted September 25, 2015 Tried uninstalling it and re installing and still same problem
marcelveldt 736 Posted September 25, 2015 Author Posted September 25, 2015 Tried uninstalling it and re installing and still same problem Skin settings, Advanced, reset skin settings Does that help?
Glyde62 50 Posted September 25, 2015 Posted September 25, 2015 Skin settings, Advanced, reset skin settings Does that help? Nope didn't help, Still same problem
marcelveldt 736 Posted September 25, 2015 Author Posted September 25, 2015 Nope didn't help, Still same problemStrange! One more try... In the kodi userdata folder, subfolder Database, delete (or rename) the file ViewModes3
Glyde62 50 Posted September 25, 2015 Posted September 25, 2015 Strange! One more try... In the kodi userdata folder, subfolder Database, delete (or rename) the file ViewModes3 Ok will try that out soon, strange it's only doing it in certain viewsIs doing it on my pc and on my Htpc
marcelveldt 736 Posted September 25, 2015 Author Posted September 25, 2015 (edited) Ok will try that out soon, strange it's only doing it in certain views Is doing it on my pc and on my Htpc Remember which view it was ? So I can fix it Edited September 25, 2015 by marcelveldt
Glyde62 50 Posted September 25, 2015 Posted September 25, 2015 (edited) Remember which view it was ? So I can fix it The view I prefer to use is Large Poster, That was one that was playing up, most other views worked fine. Just had a look, Only have a ViewModes6 no ViewModes3 Edited September 25, 2015 by Glyde62
marcelveldt 736 Posted September 25, 2015 Author Posted September 25, 2015 The view I prefer to use is Large Poster, That was one that was playing up, most other views worked fine. Just had a look, Only have a ViewModes6 no ViewModes3 I reproduced the issue... Both Large poster and Single poster were broken. I've just fixed it and will provide new beta later today. You can either wait for that or delete the ViewModes6 file
Glyde62 50 Posted September 25, 2015 Posted September 25, 2015 I reproduced the issue... Both Large poster and Single poster were broken. I've just fixed it and will provide new beta later today. You can either wait for that or delete the ViewModes6 file I deleted the ViewModes6 file but didn't fix the problem, will wait for your update
im85288 1493 Posted September 25, 2015 Posted September 25, 2015 Yea, Next Up Notifications works fine if you launched from the library view. Pretty sure it doesn't work if you launched from home screen widget. I started noticing this recently too when switching from using direct paths to using the emby addon paths. If someone get's a chance could you test with it using direct paths and let me know. Cheers 1
