jluce50 122 Posted August 29, 2015 Posted August 29, 2015 So I noticed that there was a new beta version (I was on the one marked OLDVERSION). I tried to install it but it failed and I was left unable to use the current version that I'm on. I switched to Confluence, uninstalled the OLDVERSION, and attempted to install the newer one which also failed due to a dependency error. Now I'm unable to install any of the Titan skins! I've deleted all the relevant folders from the addons folder and the addon_data folder but still no dice. Where did I go wrong here and how do I fix it?
jluce50 122 Posted August 30, 2015 Posted August 30, 2015 (edited) delete guisettings.xml Now they're all showing as incompatible... Edit: Actually, all skins in all repos are showing as incompatible. Wtf?! Edited August 30, 2015 by jluce50
badaas 139 Posted August 30, 2015 Posted August 30, 2015 (edited) edit: nm Edited August 30, 2015 by badaas
marcelveldt 736 Posted August 30, 2015 Author Posted August 30, 2015 if you have all addons installed then dl from from git and install zip via addonsNever download the skin from Github as it contains invalid code and is not packaged to use with Kodi... The repo versions should work fine 1
jluce50 122 Posted August 30, 2015 Posted August 30, 2015 Something got really hosed. I did a complete uninstall and reinstalled everything from scratch and now it's working. 1
e123enitan 276 Posted August 31, 2015 Posted August 31, 2015 (edited) Hi Marcel, I just noticed on the latest Titan Beta I couldn’t find any program add-on, In past build, not sure exactly the version, I was able to add to my menu several program add-on (Ivue or F/T guides, and so on!), could it be that program add-on have been remapped elsewhere or under different grouping kindly advice. Thanks Edited September 2, 2015 by e123enitan
e123enitan 276 Posted August 31, 2015 Posted August 31, 2015 (edited) Hi Marcel, I just noticed on the latest Titan Beta I couldn’t find any program add-on, I past build, not sure exactly the version, I was able to my menu several program add-on (Ivue or F/T guides, and so on!), could it be that program add-on have been remapped elsewhere or under different grouping kindly advice. Thanks Just want to add, that music and video addons can be found, except program addons. Thanks Edited August 31, 2015 by e123enitan
jluce50 122 Posted August 31, 2015 Posted August 31, 2015 Hi Marcel, I just noticed on the latest Titan Beta I couldn’t find any program add-on, I past build, not sure exactly the version, I was able to my menu several program add-on (Ivue or F/T guides, and so on!), could it be that program add-on have been remapped elsewhere or under different grouping kindly advice. Thanks Have you recently installed a new version of Jarvis? I installed a more recent nightly version and noticed they now group certain addon types in categories. For instance, Skins is now inside the "Look and Feel" category.
e123enitan 276 Posted August 31, 2015 Posted August 31, 2015 Have you recently installed a new version of Jarvis? I installed a more recent nightly version and noticed they now group certain addon types in categories. For instance, Skins is now inside the "Look and Feel" category. Not at all-I am still on Kodi 15.2 Isengard, my questions is to Titan, in the option to create user specific menu is missing add-on listed under program addon.
jluce50 122 Posted August 31, 2015 Posted August 31, 2015 Probably not specific to this skin, but it's the only one I use ... Does anyone notice if they've gotten rid of StartAndroidActivity in Jarvis? My shortcuts to start other apps on my FireTV stopped working when I upgraded to Jarvis.
marcelveldt 736 Posted August 31, 2015 Author Posted August 31, 2015 Will be fixed in the new beta. I've been working last couple of weeks to completely revamp parts of the skin. Already got rid of 1000''s lines of code by optimizing it. It will be very fast... Also stuff like the widgets and shortcuts sections are improved a lot. I''m not ready yet to share a beta but will be within a few days. 2
e123enitan 276 Posted August 31, 2015 Posted August 31, 2015 Will be fixed in the new beta. I've been working last couple of weeks to completely revamp parts of the skin. Already got rid of 1000''s lines of code by optimizing it. It will be very fast... Also stuff like the widgets and shortcuts sections are improved a lot. I''m not ready yet to share a beta but will be within a few days. You are the man minus a thousand codes would mean faster and smother on a low powered devices, please take your time to perfect and shared at your convenience. Cheers!
e123enitan 276 Posted August 31, 2015 Posted August 31, 2015 You are the man minus a thousand codes would mean faster and smother on a low powered devices, please take your time to perfect and shared at your convenience. Cheers! Please could I make a request to add year and search to default submenu of each user menu(movie, TV shows, Anima, Kids and etc), the current default have Genre, recently added, Unwatched, this would aid the process for searching/narrow down movies, especially where one have large collections of media files, hope this make sense. Thanks again.
marcelveldt 736 Posted September 1, 2015 Author Posted September 1, 2015 Not at all-I am still on Kodi 15.2 Isengard, my questions is to Titan, in the option to create user specific menu is missing add-on listed under program addon. Isn't that listed under "common" ?
e123enitan 276 Posted September 1, 2015 Posted September 1, 2015 Isn't that listed under "common" ? Is it? I didn't realized, I shall check it out, thanks
Diedrich 380 Posted September 1, 2015 Posted September 1, 2015 Oh. My. God! This looks epic! I can't wait to get home to install it!
Diedrich 380 Posted September 2, 2015 Posted September 2, 2015 (edited) Well, Titan is beautiful! Great job! I have three major complaints though. I'm on Kodi 15.2 and Titan stable (well, I don't know the version because that's one of the major issues. 1. There is no menu or button to return to the home screen when either in TV or Movies. Edit: I found the setting for enabling a mouse. 2. Other than pressing 'S', I do not see another way to access the Settings and Shutdown controls. Edit: Also found this by enabling the mouse support setting. 3. The Settings shortcut in the bottom Settings and Shutdown controls does not work, I just get an audible ding. Edit: This was solved by installing Jarvis Alpha and the Emby for Kodi beta repository. This was broken in Kodi 15.1 and downloading Titan through the Kodi repository. Edited September 2, 2015 by dvgmar 1
lkrkkrsaz 0 Posted September 2, 2015 Posted September 2, 2015 Have the newest version of Isengard. Installed Titan. Cannot access settings. I hit 's' and have Settings selected and hit enter but nothing happens. Bit ridiculous. Can't do much with Settings not working.
bazzz3 6 Posted September 2, 2015 Posted September 2, 2015 Have the newest version of Isengard. Installed Titan. Cannot access settings. I hit 's' and have Settings selected and hit enter but nothing happens. Bit ridiculous. Can't do much with Settings not working. Try change skin to confluence and then uninstall the Titan Skin and the Titan Script helpers and reboot.Then try reinstall and test again.
Diedrich 380 Posted September 3, 2015 Posted September 3, 2015 Have the newest version of Isengard. Installed Titan. Cannot access settings. I hit 's' and have Settings selected and hit enter but nothing happens. Bit ridiculous. Can't do much with Settings not working.Read item 3 in my post above. Getting the beta skin worked for me. The official skin seems to have that bug.
Diedrich 380 Posted September 3, 2015 Posted September 3, 2015 (edited) @@marcelveldt Confirmation number: 3286722356458680W I hope that buys a good beer in the Netherlands Here is my home screen. I love it and I have one request to make it perfect! As you can see from the Photoshop'ing, I'd like to request the skin settings option to have the sub-menu items expand above the home tiles. I use a mouse to navigate and having the sub-menus open above the tiles would prevent the bottom bar from shading up as well as prevent sloppy mousing over the other tiles and therefore popping up their own sub-menu. Edited September 3, 2015 by dvgmar 1
jluce50 122 Posted September 5, 2015 Posted September 5, 2015 When I enable the extended info panel, I get the following error. Any idea how to fix this? 15:45:34 T:548 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.AttributeError'> Error Contents: 'module' object has no attribute 'ACTION_OSD_SHOW_LEFT' Traceback (most recent call last): File "C:\Users\Jeremy\AppData\Roaming\Kodi\addons\script.extendedinfo\default.py", line 45, in <module> Main() File "C:\Users\Jeremy\AppData\Roaming\Kodi\addons\script.extendedinfo\default.py", line 19, in __init__ start_info_actions(self.infos, self.params) File "C:\Users\Jeremy\AppData\Roaming\Kodi\addons\script.extendedinfo\resources\lib\process.py", line 365, in start_info_actions name=params.get("name", "")) File "C:\Users\Jeremy\AppData\Roaming\Kodi\addons\script.extendedinfo\resources\lib\WindowManager.py", line 68, in open_movie_info from dialogs import DialogVideoInfo File "C:\Users\Jeremy\AppData\Roaming\Kodi\addons\script.extendedinfo\resources\lib\dialogs\DialogVideoInfo.py", line 13, in <module> from DialogBaseInfo import DialogBaseInfo File "C:\Users\Jeremy\AppData\Roaming\Kodi\addons\script.extendedinfo\resources\lib\dialogs\DialogBaseInfo.py", line 11, in <module> from ..OnClickHandler import OnClickHandler File "C:\Users\Jeremy\AppData\Roaming\Kodi\addons\script.extendedinfo\resources\lib\OnClickHandler.py", line 84, in <module> "osdleft": xbmcgui.ACTION_OSD_SHOW_LEFT, AttributeError: 'module' object has no attribute 'ACTION_OSD_SHOW_LEFT' -->End of Python script error report<--
jhoff80 94 Posted September 6, 2015 Posted September 6, 2015 (edited) Starting to seriously use Kodi for the first time in a decade, and loving this skin once I configured it to my liking. One small question though, would it be possible to make the "Nextup" service popup a little smaller and more subtle? In Confluence, it pops up as a small window in the corner, which makes it far easier to deal with different media file's different lengths (some shows, 30 seconds is far too early, other shows have two minutes of credits). In Titan, it pops up in the left center of the screen, and blocks a large portion of the picture. Edit: Actually, I realized it might not be Confluence I'm thinking of but one of the other skins I've tried, but my point still stands, I'd love to see something far more subtle in the corner of the screen instead of a huge popup blocking everything. Edited September 7, 2015 by jhoff80 1
e123enitan 276 Posted September 7, 2015 Posted September 7, 2015 When I enable the extended info panel, I get the following error. Any idea how to fix this? 15:45:34 T:548 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.AttributeError'> Error Contents: 'module' object has no attribute 'ACTION_OSD_SHOW_LEFT' Traceback (most recent call last): File "C:\Users\Jeremy\AppData\Roaming\Kodi\addons\script.extendedinfo\default.py", line 45, in <module> Main() File "C:\Users\Jeremy\AppData\Roaming\Kodi\addons\script.extendedinfo\default.py", line 19, in __init__ start_info_actions(self.infos, self.params) File "C:\Users\Jeremy\AppData\Roaming\Kodi\addons\script.extendedinfo\resources\lib\process.py", line 365, in start_info_actions name=params.get("name", "")) File "C:\Users\Jeremy\AppData\Roaming\Kodi\addons\script.extendedinfo\resources\lib\WindowManager.py", line 68, in open_movie_info from dialogs import DialogVideoInfo File "C:\Users\Jeremy\AppData\Roaming\Kodi\addons\script.extendedinfo\resources\lib\dialogs\DialogVideoInfo.py", line 13, in <module> from DialogBaseInfo import DialogBaseInfo File "C:\Users\Jeremy\AppData\Roaming\Kodi\addons\script.extendedinfo\resources\lib\dialogs\DialogBaseInfo.py", line 11, in <module> from ..OnClickHandler import OnClickHandler File "C:\Users\Jeremy\AppData\Roaming\Kodi\addons\script.extendedinfo\resources\lib\OnClickHandler.py", line 84, in <module> "osdleft": xbmcgui.ACTION_OSD_SHOW_LEFT, AttributeError: 'module' object has no attribute 'ACTION_OSD_SHOW_LEFT' -->End of Python script error report<-- I have similar thing before, so I went to skin settings>media library view>use extended video info dialog, when this enable it should down load the script, I hope it works for you.
