lja 51 Posted August 9, 2015 Posted August 9, 2015 Go to Skin Settings>General Skin Settings>And turn on Enable Artist Slideshow While Playing Music. Thanks.
browned 33 Posted August 9, 2015 Posted August 9, 2015 Anyone else having issues with Collections? I moved a couple of PC's to Live using Titan 3.4, Emby 1.1.13 and Kodi 15. I would assume it is Titan using Showcase view as other views do not display so many images. Other skins do not as well, but I didn't check the view settings on other skins.
marcelveldt 736 Posted August 9, 2015 Author Posted August 9, 2015 Anyone else having issues with Collections? I moved a couple of PC's to Live using Titan 3.4, Emby 1.1.13 and Kodi 15. I would assume it is Titan using Showcase view as other views do not display so many images. Other skins do not as well, but I didn't check the view settings on other skins. titan_3.4_collections.JPG It's the showcase view. It's not a problem, its by design because in a set there are only few items. Use another view for the sets collection level is the correct solution.
bob808 2 Posted August 9, 2015 Posted August 9, 2015 Oops, you're right. I changed this to have the same overall experience in every menu were left button would open the sideblade menu. It was kind of strange that only in the guide the back button would open the sideblade, Offcourse I'm open for comments if you say that this is a bad change. The problem with scrolling left to get the sideblade is kodi remembers the last 24 hours of my guide, so I have to scroll way left before the blade comes up, a 1 button press to bring up the blade makes more sense. Back feels a bit weird, but its the default in the other skins - maybe a menu item to allow a button to be configured to bring up the sideblade if left scroll is not the best option would work? I only need it to change channel group from sports to movies etc.
bob808 2 Posted August 9, 2015 Posted August 9, 2015 I had been using the stable release as the back button still worked there, but now its updated to 3.4 and this has been removed, is there anything you can do to get the 1 button functionality back? Thanks!
bazzz3 6 Posted August 9, 2015 Posted August 9, 2015 Hi again Marcel, just wondering could you share any info on my question from a page or two back http://emby.media/community/index.php?/topic/9255-titan-skin/page-80&do=findComment&comment=235532 and here http://emby.media/community/index.php?/topic/9255-titan-skin/page-80&do=findComment&comment=235684 .Now like I've already said it's not a big issue for me.Just wondering is it correct(have you intentionally removed the Change Shortcut option).Thank you
browned 33 Posted August 9, 2015 Posted August 9, 2015 It's the showcase view. It's not a problem, its by design because in a set there are only few items. Use another view for the sets collection level is the correct solution. hmm ok, makes sense I suppose, although I would have thought no matter what the view only a single item will display for the content you have. Not really Titan related but it would be great having forced views for music, pictures, recorded tv, in fact all content following the same structure would be best for WAF. Thanks.
blakmumba 0 Posted August 11, 2015 Posted August 11, 2015 HI, sorry my first post so apologise in advance for any noobs questions/problems. I'm using the Titan skin on my Amazon Fire TV Box and notice a major lag navigating or opening streams or sub menu icons which I don't get using other skins. I really do not want to change the skin as I love the Titan image so could someone assist or correct any noob problem that I may be overlooking. Kind Regards
jluce50 122 Posted August 11, 2015 Posted August 11, 2015 HI, sorry my first post so apologise in advance for any noobs questions/problems. I'm using the Titan skin on my Amazon Fire TV Box and notice a major lag navigating or opening streams or sub menu icons which I don't get using other skins. I really do not want to change the skin as I love the Titan image so could someone assist or correct any noob problem that I may be overlooking. Kind Regards There's an "Optimize for low power devices" option somewhere in the Skin Settings. I'm at work right now so I can't look it up. You'll lose some of the fancier UI flourishes, but after enabling that it runs great on my Fire TV Stick. 1
blublub 10 Posted August 11, 2015 Posted August 11, 2015 In the Emby addon you have an option to reset the local DB. Yes, support of the video extras is on our todo list: https://trello.com/b/qBJ49ka4/emby-for-kodi OK, I already signed that trello feature and totally forgot about it :-). --- please make it work! I can't imagine I am the only one wanting to watch some extras !? :-) PS new 3.5 version is really awesome
blakmumba 0 Posted August 12, 2015 Posted August 12, 2015 There's an "Optimize for low power devices" option somewhere in the Skin Settings. I'm at work right now so I can't look it up. You'll lose some of the fancier UI flourishes, but after enabling that it runs great on my Fire TV Stick.Many thanks for taking the time to reply. Using the fire tv box I thought it would be fast enough with the quad cpu however I selected the 'optimise for low power devices' and rebooted and yet still the same problem. The weird thing is, when I select favourites it loads up in a flash. It's everything else such as selecting the shortcuts to sub menus from the main screen (ie. Main screen movies icon and then sub menu to latest movies). Also when I go into the skin settings under customise shortcuts, custom command button takes at least 20-30secs to highlight so I can select it.Sorry for the long reply but I hope someone can shed some light weather this is normal or not as I really really like the skin.
puithove 209 Posted August 18, 2015 Posted August 18, 2015 Hey Marcel - here's a request. Wonder if you'd be interested in adding a new PVR field to the various PVR views (OSD, EPG, Channels, Recordings, etc.). As of Isengard, they added an "Episode Title" field. For serial shows, or sports the name of the episode is placed here. This is a discussion on it in the Kodi forums: http://forum.kodi.tv/showthread.php?tid=223720&page=3 And here are some screenshots of it in Confluence (Only a couple of the available views where it'd have to be added): The Episode Title is "Fresh Brood"
Tranquil 95 Posted August 20, 2015 Posted August 20, 2015 Anyone else experiencing problems with the user logoff button? I have two profiles installed on my kodi setup and I'm no longer able to switch between them. After clicking the lock button nothing happens at all.
kmarq13 5 Posted August 20, 2015 Posted August 20, 2015 Running the latest stable version. Every time I open Kodi I now get a NetfliXBMC window coming up. While I have NetfliXBMC installed, I don't have it on my homescreen anywhere, so there shouldn't be anything for it to load up.
balkerman 7 Posted August 21, 2015 Posted August 21, 2015 An idea! Have a unwatched flag, like the watched flag but for unwatched items. That way the watched (most of the content) flag can be turned off... Hate having a watched flag on everything in the library, looks real bad. Want to turn it off but there is no unwatched flag. Just an idea! Using beta as it loads the artwork faster when scrolling media.
blakmumba 0 Posted August 21, 2015 Posted August 21, 2015 MY unwatched flag also does not work. Is there a chance you could include more than 5 sub menu's in the text format. Currently you have to scroll as only shows 5 per page. Many Thanks
altramarine 21 Posted August 22, 2015 Posted August 22, 2015 (edited) Hi there, Hopefuly an easy one: I installed Kodi 15.1 and stable repo from http://www.mb3admin.com/downloads/addons/xbmb3c/kodi-repo/repository.emby.kodi-1.0.2.zip I do not see Titan among the available skins. In fact, there is only Arctic Zephyr Exploded . Am I to use beta repo? or 15.1 is not compatible? confused. Thanks, Edited August 22, 2015 by altramarine
Tranquil 95 Posted August 22, 2015 Posted August 22, 2015 The skin can be found in the official Kodi repro. Gesendet von meinem GT-I9506 mit Tapatalk 2
altramarine 21 Posted August 22, 2015 Posted August 22, 2015 The skin can be found in the official Kodi repro. Gesendet von meinem GT-I9506 mit Tapatalk Thanks, all is well now:)
marcelveldt 736 Posted August 22, 2015 Author Posted August 22, 2015 Running the latest stable version. Every time I open Kodi I now get a NetfliXBMC window coming up. While I have NetfliXBMC installed, I don't have it on my homescreen anywhere, so there shouldn't be anything for it to load up.Please install latest version of Netflixbmc to stop that from happening. Btw, it should only happen when you have enabled smart shortcuts for netflixbmc in the skinsettings
marcelveldt 736 Posted August 22, 2015 Author Posted August 22, 2015 An idea! Have a unwatched flag, like the watched flag but for unwatched items. That way the watched (most of the content) flag can be turned off... Hate having a watched flag on everything in the library, looks real bad. Want to turn it off but there is no unwatched flag. Just an idea! Using beta as it loads the artwork faster when scrolling media. I will add unwatched flag in next release... Note that you can already disable the watched flag in the skinsettings
marcelveldt 736 Posted August 22, 2015 Author Posted August 22, 2015 MY unwatched flag also does not work. Is there a chance you could include more than 5 sub menu's in the text format. Currently you have to scroll as only shows 5 per page. Many Thanks Hmm, the only way to do that is if I make the sub menu buttons really small or append a second line... Do you have that many sub menu items?
marcelveldt 736 Posted August 22, 2015 Author Posted August 22, 2015 hmm ok, makes sense I suppose, although I would have thought no matter what the view only a single item will display for the content you have. Not really Titan related but it would be great having forced views for music, pictures, recorded tv, in fact all content following the same structure would be best for WAF. Thanks. Extending the forced views function for other media types will be added soon. I have been working lately on my skin helper service which makes all this possible. In fact, expect it to be available in more Kodi skins soon.
marcelveldt 736 Posted August 22, 2015 Author Posted August 22, 2015 Many thanks for taking the time to reply. Using the fire tv box I thought it would be fast enough with the quad cpu however I selected the 'optimise for low power devices' and rebooted and yet still the same problem. The weird thing is, when I select favourites it loads up in a flash. It's everything else such as selecting the shortcuts to sub menus from the main screen (ie. Main screen movies icon and then sub menu to latest movies). Also when I go into the skin settings under customise shortcuts, custom command button takes at least 20-30secs to highlight so I can select it. Sorry for the long reply but I hope someone can shed some light weather this is normal or not as I really really like the skin. The lag with skinshortcuts will be fixed in next release. In fact, the first improvements are already in the current beta of the skin. 1
marcelveldt 736 Posted August 22, 2015 Author Posted August 22, 2015 Hey Marcel - here's a request. Wonder if you'd be interested in adding a new PVR field to the various PVR views (OSD, EPG, Channels, Recordings, etc.). As of Isengard, they added an "Episode Title" field. For serial shows, or sports the name of the episode is placed here. This is a discussion on it in the Kodi forums: http://forum.kodi.tv/showthread.php?tid=223720&page=3 And here are some screenshots of it in Confluence (Only a couple of the available views where it'd have to be added): The Episode Title is "Fresh Brood" Oh, I forgot to add that field... Will add it for next release. 1
