marcelveldt 736 Posted August 2, 2015 Author Posted August 2, 2015 Here we go... Thanks, problem found... It's choking on the / in your movie folders... I will try to workaround it somehow but because you're on windows I don't think it's possible because windows "thinks" it's part of the path. Those media folders are cteated as video nodes by the Emby addon. We can either replace the illegal characters in the emby addon or you can name the folders somewhat differently...
pünktchen 1411 Posted August 2, 2015 Posted August 2, 2015 Thanks, problem found... It's choking on the / in your movie folders... I will try to workaround it somehow but because you're on windows I don't think it's possible because windows "thinks" it's part of the path. Those media folders are cteated as video nodes by the Emby addon. We can either replace the illegal characters in the emby addon or you can name the folders somewhat differently... "/" in my movie folders? I don't understand. Can you give me an example please!
marcelveldt 736 Posted August 2, 2015 Author Posted August 2, 2015 "/" in my movie folders? I don't understand. Can you give me an example please! Your collection names in Emby are like this: Filme (Anime/Filme) So, there's a slash in the path... That's why it fails. I'm already fixing the issue in the Emby addon btw.
pünktchen 1411 Posted August 2, 2015 Posted August 2, 2015 Your collection names in Emby are like this: Filme (Anime/Filme) So, there's a slash in the path... That's why it fails. I'm already fixing the issue in the Emby addon btw. Huh??? No they are only Filme (Anime), Filme (Modern) and so on... I've never used "/".
marcelveldt 736 Posted August 2, 2015 Author Posted August 2, 2015 Huh??? No they are only Filme (Anime), Filme (Modern) and so on... I've never used "/". Than it's even more strange... Do the smart shortcuts actually work correctly ? So, clicking them will open the correct library ? The smartshortcuts btw represent the so called "video nodes" of the Emby addon. When you browse to "Videos" in Kodi you get that listing of all nodes. I will do some more tests, maybe it's the ( or ) that is failing on another level. I will provide you a testversion of the emby addon in a bit.
pünktchen 1411 Posted August 2, 2015 Posted August 2, 2015 Yeah, the shortcuts are working correctly! And you are right with ( or ). I've renamed "Filme (Anime)" to "Filme Anime" in Emby and now the pictures are showing! Nevertheless it would be really nice if you can fix the problem with braces. You don't need to hurry with the testversion. It's time to sleep now 1
marcelveldt 736 Posted August 2, 2015 Author Posted August 2, 2015 Yeah, the shortcuts are working correctly! And you are right with ( or ). I've renamed "Filme (Anime)" to "Filme Anime" in Emby and now the pictures are showing! Nevertheless it would be really nice if you can fix the problem with braces. You don't need to hurry with the testversion. It's time to sleep now OK, just in case you want to test it.... Attached a testversion of the emby addon. Please install on your Kodi box and let me know. You can use the "install from zip" method in Kodi for it. plugin.video.emby-test.zip
jluce50 122 Posted August 3, 2015 Posted August 3, 2015 On two different installs (Win10 and FTV) the default widget for TV Shows isn't updating after a sync. It used to be if I stopped an episode and went back to the homescreen the incremental sync would run and the NextUp view would immediately refresh and show the percent viewed, but now it's not doing that.
tropicaljoe 2 Posted August 3, 2015 Posted August 3, 2015 From the last few betas, the "change shortcut" has been missing for me and replaced with "custom action". I do have emby beta addon enabled and I tried from a fresh install of kodi 15 ( with just the emby plugin-latest beta and skin, nothing else). I do also have the options enabled in settings to allow smartshortcuts. Is this something that is missing from the beta, or am I doing something wrong?
pünktchen 1411 Posted August 3, 2015 Posted August 3, 2015 OK, just in case you want to test it.... Attached a testversion of the emby addon. Please install on your Kodi box and let me know. You can use the "install from zip" method in Kodi for it. plugin.video.emby-test.zip Excellent! Images are working now for video nodes with brackets. However the texture cache error from my other post still exists...
pünktchen 1411 Posted August 3, 2015 Posted August 3, 2015 Excellent! Images are working now for video nodes with brackets. However the texture cache error from my other post still exists... But i've found some other "bad" characters: umlauts (ä,ö,ü) They are really not unusual in Germany. The behaviour in the Emby addon is even worse than with brackets - the complete video nodes are missing, even those without special charaters.
Angelblue05 4132 Posted August 4, 2015 Posted August 4, 2015 (edited) This should be corrected with 1.1.24. It was missing .encode('utf-8') to the tagname. Can you confirm? @@pünktchen If not, @@marcelveldt I'll look into it, if it's still a problem. Edited August 4, 2015 by Angelblue05 1
pünktchen 1411 Posted August 4, 2015 Posted August 4, 2015 This should be corrected with 1.1.24. It was missing .encode('utf-8') to the tagname. Can you confirm? @@pünktchen If not, @@marcelveldt I'll look into it, if it's still a problem. Sorry, can't check. I'm out of town until the weekend...
Angelblue05 4132 Posted August 4, 2015 Posted August 4, 2015 Sorry, can't check. I'm out of town until the weekend... No worries. I'm fairly sure it's back to working now
Tranquil 95 Posted August 5, 2015 Posted August 5, 2015 I have a small Problem with PVR enabled on a Kodi 15 Installation. On my Live-TV Menu item, I'm missing the submenu items "EPG","Channels","Recordings". Dont know if this is a skin issue or a problem with the DVBLink Addon!? Running fine on 14.2.
browned 33 Posted August 5, 2015 Posted August 5, 2015 I have a small Problem with PVR enabled on a Kodi 15 Installation. On my Live-TV Menu item, I'm missing the submenu items "EPG","Channels","Recordings". Dont know if this is a skin issue or a problem with the DVBLink Addon!? Running fine on 14.2. I had the same issue in v15. You can recreate the submenu and create custom actions Channels = ActivateWindow(TVChannels) Guide = ActivateWindow(TVGuide) Recordings = ActivateWindow(TVRecordings) Timers = ActivateWindow(TVTimers) Of note though the Channels menu opens but the page is frozen, all I can do with it is go back.
marcelveldt 736 Posted August 5, 2015 Author Posted August 5, 2015 @@Tranquil and @@browned The stable version of the skin in official Kodi repo (version 3.3.0) is a little outdated and not yet fully Isengard compliant. The update (version 3.4.0) has been submitted to the Kodi team but because of the holidays it takes a little longer to update it in the repo. Apologies for that. In the meanwhile you could try the beta version of the skin. See first post of this thread how to acquire the beta version of the skin. 1
jluce50 122 Posted August 5, 2015 Posted August 5, 2015 On two different installs (Win10 and FTV) the default widget for TV Shows isn't updating after a sync. It used to be if I stopped an episode and went back to the homescreen the incremental sync would run and the NextUp view would immediately refresh and show the percent viewed, but now it's not doing that. Just curious if this is happening for anyone else or if it's just me?
marcelveldt 736 Posted August 5, 2015 Author Posted August 5, 2015 Just curious if this is happening for anyone else or if it's just me? Let me check my setup... You mean the nextepisodes, right ?
marcelveldt 736 Posted August 5, 2015 Author Posted August 5, 2015 The stabe version 3.4.0 has been submitted to the Kodi team to be published on the repo but (I think) because of the holidays it takes a little longer then normal before the new skin version is available on the Kodi repo. Fo everyone who has issues with Isengard while using the 3.3.0 version of the skin or who is just curious about the new version and doesn't want to install the beta version, here is a direct link. Just download this zipfile and go to Settings --> Addons --> Install from zip. https://github.com/marcelveldt/xbmc.skin.titan/raw/master/skin.titan.zip 3
jluce50 122 Posted August 5, 2015 Posted August 5, 2015 Let me check my setup... You mean the nextepisodes, right ? Correct. Thanks!
marcelveldt 736 Posted August 6, 2015 Author Posted August 6, 2015 Correct. Thanks! Issue confirmed. It was an error in the Emby addon itself. I fixed it in the code. A new beta version of the emby addon will be supplied shortly. 1
bazzz3 6 Posted August 6, 2015 Posted August 6, 2015 From the last few betas, the "change shortcut" has been missing for me and replaced with "custom action". I do have emby beta addon enabled and I tried from a fresh install of kodi 15 ( with just the emby plugin-latest beta and skin, nothing else). I do also have the options enabled in settings to allow smartshortcuts. Is this something that is missing from the beta, or am I doing something wrong? Hi Marcel,I'm seeing the same as above on the latest stable version 3.4.0,just wondering is the script missing code.Or is it a mistake. I'm seeing it in on a test pc running Windows 10 and using isengard kodi. Thanks
