josh4trunks 70 Posted April 20, 2015 Posted April 20, 2015 Love this skin! Here's an issue I'm having... If I enabled kiosk mode, then navigate into the TV widget to play a recent show (that has some progress), I can't play it. I says I have kiosk mode enabled. Without kiosk mode enabled, a panel on the left pops up asking me if I want to start from the beginning or resume. Thanks!
saitoh183 137 Posted April 20, 2015 Posted April 20, 2015 I just checked the Kodi forums and there was an error reported about images not drawn correctly when using a certain transition effect (which Titan uses). Please wait a couple of days and check the latest nightly for Isengard. @@saitoh183, I saw you submitting this same issue. Are you on Isengard too ? If not there may still be an issue in the skin itself and I'll have to investigate. No im on Helix
reluctantflux 39 Posted April 21, 2015 Posted April 21, 2015 In Progress Episodes appears to be broken as a widget. Works fine a submenu item, and In Progress Shows still works as a widget. I'm on 3.2.81
marcelveldt 736 Posted April 21, 2015 Author Posted April 21, 2015 Love this skin! Here's an issue I'm having... If I enabled kiosk mode, then navigate into the TV widget to play a recent show (that has some progress), I can't play it. I says I have kiosk mode enabled. Without kiosk mode enabled, a panel on the left pops up asking me if I want to start from the beginning or resume. Thanks! Just fixed in the skin's code. Will provide new version of the skin soon.
marcelveldt 736 Posted April 21, 2015 Author Posted April 21, 2015 @@marcelveldt yeah i have a similar issue as previous post with my submenus when i go from movies to TV and when i click on tv there is a weird delay causing a bad transition effect I couldn't reproduce this issue but I found a few places in the code that could be optimized to prevent this. Will provide a new skin beta tonight, please see if this helps and the issue is resolved.
marcelveldt 736 Posted April 21, 2015 Author Posted April 21, 2015 In Progress Episodes appears to be broken as a widget. Works fine a submenu item, and In Progress Shows still works as a widget. I'm on 3.2.81 Are you using native Kodi, the Emby addon or the "old" MediaBrowser addon ? I couldn't reproduce with native Kodi/Emby addon...
reluctantflux 39 Posted April 22, 2015 Posted April 22, 2015 I'm using the Emby for Kodi add on. I'll do a fresh db Sync.
marcelveldt 736 Posted April 22, 2015 Author Posted April 22, 2015 I'm using the Emby for Kodi add on. I'll do a fresh db Sync. It's working for me. Did you try a fresh db sync ?
reluctantflux 39 Posted April 23, 2015 Posted April 23, 2015 It's working for me. Did you try a fresh db sync ? Aha! So the Assign Widget->TV Shows->In Progress Episodes is coming back blank for me. If I go Assign-Widget-> TV Shows Widget, it was defaulting on Favorites, which is empty, so when I tried to use my remote to get to it, it wouldn't let me, because it needs a jumping off point as you move to the right. So it couldn't select the bottom right title of which section it is on. When I use my mouse, though, and change that to In Progress Episodes, my episodes show up. Still, though, the straight up Assign Widget->TV Shows->In Progress Episodes returns a blank screen.
josh4trunks 70 Posted April 23, 2015 Posted April 23, 2015 Just fixed in the skin's code. Will provide new version of the skin soon.thanks!
marcelveldt 736 Posted April 26, 2015 Author Posted April 26, 2015 NEW STABLE VERSION AVAILABLE OF THE SKIN: V 3.3.0 This version contains all fixes as discussed here including some exiting new features.The update is available as of now in the official Kodi repo. A small grasp from the changes in this new version: - auto focus episodes now also active for seasons- code cleanup and speedup- studio logo support in Video Info Dialog (thanks to taurus35)- Updated support for trakt addon (thanks to mgonzales)- Isengard support general- Isengard seek steps support (thanks to punkchten)- Various fixes to PVR windows- Updated languages from Transifex (thanks to all translators)- Smart shortcuts feature- Optimized images- Boxsets support in views- Openelec settings dialog skinned- New ClearLogo view- Fixes for view reverting to showcase- Lot's of small changes to graphics and views- Lot's of bugs and issues resolved A big thank you to all translators, beta-testers and users who contributed with fixes for the skin, feature requests etc ! 5
bazzz3 6 Posted April 26, 2015 Posted April 26, 2015 Excellent job Marcel,thanx a million for everything 1
mata7 45 Posted April 27, 2015 Posted April 27, 2015 hey marcel thanks for the update, can you please tell me how activate the clear logo view, is that equal a clearart view? i dont see it thanks
e123enitan 276 Posted April 27, 2015 Posted April 27, 2015 (edited) Hi Marcel, Need help in seeting each menu as shown in the pic to reflect there respective posters and background, the current display the same for Kids, Forien and Movies. If I may say the data is derived from vidoe>Movies>Tags, which is how my media collections are brokendown in server, which find found to be kool, so what I wish to achieve as per aforementioned is been able to set each tag/menu such that the rotations for title and backdrop reflect there respective grouping user collections. I have tried playing around with sking edit setting for "set custome title image & Overide background" each option does not result what I expected. I must add this method of using tag is efficient as it make it easier to manage adding/removing users collections for each category from server perspective. appreciate if you can make this happen. Thanks in advance of your usual efforts and supports. Cheers! Foreign Kids taken from defualt confluence Video>Movies>Tags Edited April 27, 2015 by e123enitan
marcelveldt 736 Posted April 27, 2015 Author Posted April 27, 2015 Hi Marcel, Need help in seeting each menu as shown in the pic to reflect there respective posters and background, the current display the same for Kids, Forien and Movies. If I may say the data is derived from vidoe>Movies>Tags, which is how my media collections are brokendown in server, which find found to be kool, so what I wish to achieve as per aforementioned is been able to set each tag/menu such that the rotations for title and backdrop reflect there respective grouping user collections. I have tried playing around with sking edit setting for "set custome title image & Overide background" each option does not result what I expected. I must add this method of using tag is efficient as it make it easier to manage adding/removing users collections for each category from server perspective. appreciate if you can make this happen. Thanks in advance of your usual efforts and supports. Cheers! This is why I created the "smart shortcuts" feature. Those smart shortcuts are created automatically for both your playlists and for any favourites. You can ad dthem from the menu editor in the skin settings. A smart shortcut will display both the tile picture and the background with images from the collection it points to. So, in your case: 1. Make sure that smart shortcuts are enabled for favourites (see skin settings - advanced settings) 2. Go to Videos --> Movies --> Tags and add each tag to your favorites 3. Go skin settings --> configure menu shortcuts --> add and select your items from the smart shortcuts list That's all,
marcelveldt 736 Posted April 27, 2015 Author Posted April 27, 2015 hey marcel thanks for the update, can you please tell me how activate the clear logo view, is that equal a clearart view? i dont see it The view is called Logo and is available in the Video library while you're browsing movies.
e123enitan 276 Posted April 27, 2015 Posted April 27, 2015 This is why I created the "smart shortcuts" feature. Those smart shortcuts are created automatically for both your playlists and for any favourites. You can ad dthem from the menu editor in the skin settings. A smart shortcut will display both the tile picture and the background with images from the collection it points to. So, in your case: 1. Make sure that smart shortcuts are enabled for favourites (see skin settings - advanced settings) 2. Go to Videos --> Movies --> Tags and add each tag to your favorites 3. Go skin settings --> configure menu shortcuts --> add and select your items from the smart shortcuts list That's all, I got it, thanks I shall keep you posted. Thanks
e123enitan 276 Posted April 28, 2015 Posted April 28, 2015 I got it, thanks I shall keep you posted. Thanks @ Marcel, Thanks in millions, my kids are happy seeing there skin rotating. However, I noticed some usual screen patterns, see below pictures any suggestion on how to fixed this issue. On Ace ventura this happen happen on Alien User title and backdrop takes a while to show, and rotation is slow to change, at times the backdrop is blanked out
mata7 45 Posted April 28, 2015 Posted April 28, 2015 The view is called Logo and is available in the Video library while you're browsing movies. thanks marcel, any idea where are you gone add clear art view? thanks
marcelveldt 736 Posted April 28, 2015 Author Posted April 28, 2015 @ Marcel, Thanks in millions, my kids are happy seeing there skin rotating. However, I noticed some usual screen patterns, see below pictures any suggestion on how to fixed this issue. On Ace ventura this happen happen on Alien User title and backdrop takes a while to show, and rotation is slow to change, at times the backdrop is blanked out Could you provide me your XBMC logfile after this issue has occured ? Please also try to rebuild your texture cache.. Just google for rebuild texture cache kodi and you'll find out how to do that.
marcelveldt 736 Posted April 28, 2015 Author Posted April 28, 2015 thanks marcel, any idea where are you gone add clear art view? thanks I will add a toggle to the logo view to prefer clearart instead of clearlogo, will provide new beta tomorrow.
e123enitan 276 Posted April 28, 2015 Posted April 28, 2015 (edited) Could you provide me your XBMC logfile after this issue has occured ? Please also try to rebuild your texture cache.. Just google for rebuild texture cache kodi and you'll find out how to do that. I google and came accrosed this steps, supposely would resolved texture issue? In Kodi File manager> Profile Directory > Database> Texture 13db Press C on the keyboard to populate context menu and highligt delete power of the system and should correct/clean the texture issue Edited April 28, 2015 by e123enitan
marcelveldt 736 Posted April 28, 2015 Author Posted April 28, 2015 I google and came accrosed this steps, supposely would resolved texture issue? In Kodi File manager> Profile Directory > Database> Texture 13db Press C on the keyboard to populate context menu and highligt delete power of the system and should correct/clean the texture issue Yes, please try if that fixes the corrupted images...
