e123enitan 276 Posted February 27, 2015 Posted February 27, 2015 Nice, is this done? And how can one incorporate its own logo, I am guessing it have jpeg file of specific parameters saved in a drive where it will be upload into Titan, correct?
e123enitan 276 Posted February 27, 2015 Posted February 27, 2015 Which device are you using again? Few device's, 1 Lap(vista) 3 Desktop (Windows 7) 2 Tronsmart Vega Elite s89, Soc 802, 1 (Andriod KitKat), 2 (Android KitKat migrated to Openelec) yesterday, still in testing process, so far things are looking good. Hope it helps Cheers!
dark_slayer 103 Posted February 27, 2015 Posted February 27, 2015 Few device's, 1 Lap(vista) 3 Desktop (Windows 7) 2 Tronsmart Vega Elite s89, Soc 802, 1 (Andriod KitKat), 2 (Android KitKat migrated to Openelec) yesterday, still in testing process, so far things are looking good. Hope it helps Cheers! Okay. I had been wondering specifically about the amlogic SoC performance in android Were you trying spmc? Did auto refresh rate adjustment switch to 24 for you? Only asking in terms of android, couldn't care less as far as it's OE performance goes. That being said I hope it's more stable for you running OE with media browser
marcelveldt 736 Posted February 27, 2015 Author Posted February 27, 2015 Hi marcel -Any update on this issue? Also the issue that I report a while back where poster for split dvd did show blank, I think its related to "user collections". When I check all movies both Genre and split poster covers shows, I although I dont think the issue is related to T-skin, I would guess it an addon issue, since it is not displayed on MB addon >launch Hope this make sense-Thanks No update yet on this issue... This has to be fixed/added to the addon. I'll try to take a look at this myself tomorrow but not sure if I can fix it. If not, we'll have to wait a bit untill one of the other devs has some time left to look into it. I'm sure it will be fine soon.
marcelveldt 736 Posted February 27, 2015 Author Posted February 27, 2015 Nice, is this done? And how can one incorporate its own logo, I am guessing it have jpeg file of specific parameters saved in a drive where it will be upload into Titan, correct? I've added this option today. Is available in the next beta of the skin which I will upload within an hour. You'll notice an extra setting in the skin settings --> home meny layout for this. Just point to a image file and you're all set. Maybe someone can provide a good looking mediabrowser transparent png ?
jluce50 122 Posted February 27, 2015 Posted February 27, 2015 I've added this option today. Is available in the next beta of the skin which I will upload within an hour. You'll notice an extra setting in the skin settings --> home meny layout for this. Just point to a image file and you're all set. Maybe someone can provide a good looking mediabrowser transparent png ? What size should it be?
e123enitan 276 Posted February 28, 2015 Posted February 28, 2015 No update yet on this issue... This has to be fixed/added to the addon. I'll try to take a look at this myself tomorrow but not sure if I can fix it. If not, we'll have to wait a bit untill one of the other devs has some time left to look into it. I'm sure it will be fine soon. Great Thanks
e123enitan 276 Posted February 28, 2015 Posted February 28, 2015 Marcel 3.2.67 will not update, although it shows update is available., I thought I let you know. Cheers
bazzz3 6 Posted February 28, 2015 Posted February 28, 2015 Marcel 3.2.67 will not update, although it shows update is available., I thought I let you know. Cheers Yeah I'm seeing the same too,I'm sure it'll come good eventually.
e123enitan 276 Posted February 28, 2015 Posted February 28, 2015 (edited) Hi Marcel, I am not sure what may have prevented this, I am not able to play movies mostly HD content. System behaves erratic, so difficult to narrate but these few are obvious Instances are : -rotation fanart for TVs show under Movies and could appears either ways -In TV shows mode: I am can only play 480p content, not 720 or 1080p -In Movies mode: I couldn't play any movies Below are logs files for both client and server, I noted in both that there are errors, errors noted therein doesn't make sense to me, not my expertise Just to mention on board OS is an OpenElect on Arm Soc 802, Amalogy s89 Let me know if any other info is needed or if should post the issues in another forum or open a new thread. Sorry I don't know how to grab screen shot from Kodi OpenElec, any idea? Cheers Edited February 28, 2015 by e123enitan
Angelblue05 4132 Posted February 28, 2015 Posted February 28, 2015 (edited) @@e123enitan Please see how to set your log debug properly: http://mediabrowser.tv/community/index.php?/topic/17599-how-to-report-a-problem/ Thanks as your current Kodi logs don't display relevant information. You can set the log level to info. Edited February 28, 2015 by Angelblue05
marcelveldt 736 Posted February 28, 2015 Author Posted February 28, 2015 Yeah I'm seeing the same too,I'm sure it'll come good eventually. I just checked and the update is now available and installing fine. In your case I guess a corrupted, partial version of the zip is downloaded to your system. Go to your kodi folder, subfolder addons. You should see a folder called packages. In there please remove skin.titan.helix-3.2.67.zip. After that start kodi and try to update.
bazzz3 6 Posted February 28, 2015 Posted February 28, 2015 I just checked and the update is now available and installing fine. In your case I guess a corrupted, partial version of the zip is downloaded to your system. Go to your kodi folder, subfolder addons. You should see a folder called packages. In there please remove skin.titan.helix-3.2.67.zip. After that start kodi and try to update. Hi Marcel and thanx again for the reply.I had already tried clearing the packages folder and it's still not updating. http://i.imgur.com/1DMrK3P.png I'm also still seeing a few issues like the following : Two or three of my main menu Addon Tiles,when I enter then they are stuck on on Showcase with no art or names. http://i.imgur.com/rrEF5E3.jpg http://i.imgur.com/TIgU5xb.png There are also some glitches and bugs regarding blurring text and background images unstable.I've gone so far into customising this skin,I'd love if you could help me out with fixing the above.Thanx Marcel
e123enitan 276 Posted February 28, 2015 Posted February 28, 2015 @@e123enitan Please see how to set your log debug properly: http://mediabrowser.tv/community/index.php?/topic/17599-how-to-report-a-problem/ Thanks as your current Kodi logs don't display relevant information. You can set the log level to info. I am sure I have the debug set, but I shall follow the instructions provided and resend a new log-Thanks
nekromantik 24 Posted February 28, 2015 Posted February 28, 2015 Is it possible to add a new section under Movies and TV? So it only displays recently added titles.
e123enitan 276 Posted March 2, 2015 Posted March 2, 2015 Hi Marcel and thanx again for the reply.I had already tried clearing the packages folder and it's still not updating. http://i.imgur.com/1DMrK3P.png I'm also still seeing a few issues like the following : Two or three of my main menu Addon Tiles,when I enter then they are stuck on on Showcase with no art or names. http://i.imgur.com/rrEF5E3.jpg http://i.imgur.com/TIgU5xb.png There are also some glitches and bugs regarding blurring text and background images unstable.I've gone so far into customising this skin,I'd love if you could help me out with fixing the above.Thanx Marcel Marcel, I have resolved this issue, just a disconnection in naming in server library path which Openelec did not recognised. Still I couldn't update 3.2.67 in any of my systems both on window visa and openelec any suggestions Thanks
Angelblue05 4132 Posted March 2, 2015 Posted March 2, 2015 I am sure I have the debug set, but I shall follow the instructions provided and resend a new log-Thanks Since you are having trouble playing Movie content, then yes only the Mediabrowser add-on debug is required (not the Kodi debug), so we can see what the add-on is doing when you try to play something. ------------------------- Regarding Titan, I'm also unable to get 3.2.67. It results in a 404 not found in my Kodi log.
e123enitan 276 Posted March 2, 2015 Posted March 2, 2015 Good to know that titan issue is know to others, as mentioned I have RESOLVED THE ISSUE OF FAILED TO PLAY HD, kodi can't connect to nfa due incorrect path, since changed it EVERYTHING IS FINE IN THIS REGARD. Thanks for your kind supports.
jluce50 122 Posted March 2, 2015 Posted March 2, 2015 Regarding Titan, I'm also unable to get 3.2.67. It results in a 404 not found in my Kodi log. Yep, same here. 08:27:33 T:8652 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404 08:27:33 T:8652 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1 08:27:33 T:8652 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404 08:27:33 T:8652 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream. 08:27:33 T:7924 NOTICE: Thread BackgroundLoader start, auto delete: false
e123enitan 276 Posted March 2, 2015 Posted March 2, 2015 Yep, same here. 08:27:33 T:8652 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404 08:27:33 T:8652 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1 08:27:33 T:8652 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 404 08:27:33 T:8652 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream. 08:27:33 T:7924 NOTICE: Thread BackgroundLoader start, auto delete: false I can't even instal on new Opelect OpenElec, while other OS windows and android Incan not update to the latest version. I trust Marcel will get the Titan up soon no doubt
e123enitan 276 Posted March 3, 2015 Posted March 3, 2015 I can't even instal on new Opelect OpenElec, while other OS windows and android Incan not update to the latest version. I trust Marcel will get the Titan up soon no doubt any update? Can't still download Titan, every other MB skins I am able to except for Titan
bazzz3 6 Posted March 3, 2015 Posted March 3, 2015 Still waiting on news myself....have not seen any updates regarding the updates...lol
marcelveldt 736 Posted March 3, 2015 Author Posted March 3, 2015 I have just replaced the update zip on the repo. Hopefully this works... I'll check again tomorrow 1
bazzz3 6 Posted March 3, 2015 Posted March 3, 2015 (edited) I have just replaced the update zip on the repo. Hopefully this works... I'll check again tomorrow Just tried and it's still the same 3.2.67 stuck as an update.No option in the Packages folder,for corrupt packet.I could use some help with my other issues I asked about above too.Please and thanx as always. Edit : Sorry another question.....Was logo ever added as a view method,I remember it being mentioned before? Edited March 4, 2015 by bazzz3
somy 25 Posted March 5, 2015 Posted March 5, 2015 Hi, thank for the great skin and integration to XBMB3C! I'd like to ask if it is possible to have music section pointing to the album view instead of song view? Right now when I open the music section it lists all the songs which are not organized by albums which is a bit annoying. I tried to configure it in skin settings but couldn't find out how to do it...... Any suggestion? Thx!
