bazzz3 6 Posted February 24, 2015 Posted February 24, 2015 (edited) The stable version will be updated today so that problem should be fixed then. Great to hear that you managed to get it working with the beta version. For a direct tile (shortcut) to music addons: Settings --> skin settings --> configure menu shortcuts Press Add --> Select Add-On --> Music Add-On --> Select Music Add-Ons Thanx once again.I tried that in the first place when originally setting up.Then I tried the custom shortcut scripts(with a bit more luck).ActivateWindow etc,etc it shows the tile now but not selectable,the sub menu's are present too and they are selectable........wait......I just tried change the script again, instead of ActivateWindow(MusicLibrary,addons://sources/audio/,return) ,I used the following : http://i59.tinypic.com/2j6330n.png Well I'm glad that's sorted So the only issues I'm still seeing are the following.. 1 : The image bleed is still present,mainly when I jump into the skin settings menu.If you look at the next image you'll see the skin settings tabs & menu's overlapping each time I open one of the main skin settings tabs. http://i58.tinypic.com/2rd9nhl.png http://i61.tinypic.com/zuh6s2.png Thanx for the replies,hope I'm not bothering you with this. Edited February 24, 2015 by bazzz3
JDizzy 21 Posted February 25, 2015 Posted February 25, 2015 Yes you can... The MB3 addon is default set to "remember" your view per item type. It's possible to disable this behaviour so it will fallback to the normal Kodi way... Open the MediaBrowser addon from video-addons. Scroll all the way down untill you see "set views". Select the itemtype, for example movies, press OK/enter and in the next dialog choose disable. This way you'll disable the addon's forcing of the view and Kodi will just remember your last view from each entry point. Hmmm... I can't seem to find 'set views'. I am using version 0.9.802 of plugin.
jluce50 122 Posted February 25, 2015 Posted February 25, 2015 (edited) Just curious, is it possible for me to replace this Kodi logo? I'd like to put a MB3 logo there instead, but I can't seem to find where it's located or where it's referenced in the skin. Edited February 25, 2015 by jluce50
jluce50 122 Posted February 25, 2015 Posted February 25, 2015 Hmmm... I can't seem to find 'set views'. I am using version 0.9.802 of plugin. Settings -> Addons -> Enabled Addons -> Video Addons -> MediaBrowser -> Launch -> Set Views -> Movies/Series/etc. -> Disable Forced View
bazzz301 0 Posted February 25, 2015 Posted February 25, 2015 Hello again good people,just wondering could anyone here(excuse the incoming pun) point me in the right direction.I'm trying to add a quick access button in the Power menu for direct access to the connman in OpenELEC......example : ActivateWindow(connman.openelec://etc,etc,return) Sent from my iPhone using Tapatalk
JDizzy 21 Posted February 25, 2015 Posted February 25, 2015 Settings -> Addons -> Enabled Addons -> Video Addons -> MediaBrowser -> Launch -> Set Views -> Movies/Series/etc. -> Disable Forced View Ok thanks, I found it. The Launch button was to the right off my screen. Also, after clicking 'Disable Forced View', another menu pops up but there was no 'Disable' option on it. I clicked on 'Play' and it then showed Disable Forced View as '(Active). None the less, it worked but might want to check the naming of the options in that pop-up menu. Thanks all!
marcelveldt 736 Posted February 25, 2015 Author Posted February 25, 2015 Just curious, is it possible for me to replace this Kodi logo? I'd like to put a MB3 logo there instead, but I can't seem to find where it's located or where it's referenced in the skin. It's in "IncludesSimpleHome.xml" line 336... Please remember that any changes you make get overwritten by the skin's updates so maybe I can take a look to include in the skin so others can benefit too ? Maybe show the MB3 logo instead of Kodi logo when MB3 mode is activated for both Movies and TV shows or something ? 1
marcelveldt 736 Posted February 25, 2015 Author Posted February 25, 2015 Thanx once again.I tried that in the first place when originally setting up.Then I tried the custom shortcut scripts(with a bit more luck).ActivateWindow etc,etc it shows the tile now but not selectable,the sub menu's are present too and they are selectable........wait......I just tried change the script again, instead of ActivateWindow(MusicLibrary,addons://sources/audio/,return) ,I used the following : http://i59.tinypic.com/2j6330n.png Well I'm glad that's sorted So the only issues I'm still seeing are the following.. 1 : The image bleed is still present,mainly when I jump into the skin settings menu.If you look at the next image you'll see the skin settings tabs & menu's overlapping each time I open one of the main skin settings tabs. http://i58.tinypic.com/2rd9nhl.png http://i61.tinypic.com/zuh6s2.png Thanx for the replies,hope I'm not bothering you with this. I think I know why this is happening to you... You don't have a background setup, is that correct ? If you don't have a background setup the windows will just show on top of eachother. I'll try to take a look if I can find a way to solve this.
bazzz301 0 Posted February 25, 2015 Posted February 25, 2015 Thanx Marcel,I've a custom background set.But using background overrides for individual home tiles.Could you also help me with the connman script,I asked for above. I'm on tap talk so Im showing as a different user,but I'm still bazzz3...lol I really appreciate you replying.Thank you Sent from my iPhone using Tapatalk
marcelveldt 736 Posted February 25, 2015 Author Posted February 25, 2015 Thanx Marcel,I've a custom background set.But using background overrides for individual home tiles.Could you also help me with the connman script,I asked for above. I'm on tap talk so Im showing as a different user,but I'm still bazzz3...lol I really appreciate you replying.Thank you Sent from my iPhone using Tapatalk OK, please download the attached file (includesbackgroundbuilding.xml) and overwrite it in the folder addons\skin.titan.helix\1080i after that (re)start Kodi and see if the problem with the background bleeding is fixed. As for the question about the openelec addon, can't answer that right now. I'll install my pi tonight with openelec and let you know. IncludesBackgroundBuilding.xml 1
bazzz3 6 Posted February 25, 2015 Posted February 25, 2015 OK, please download the attached file (includesbackgroundbuilding.xml) and overwrite it in the folder addons\skin.titan.helix\1080i after that (re)start Kodi and see if the problem with the background bleeding is fixed. As for the question about the openelec addon, can't answer that right now. I'll install my pi tonight with openelec and let you know. Marcel,thank you so much for the file and the reply.I've just tried it and it looks fixed now and I'm seeing smoother transitions while scrolling through main menu custom tiles too.So great work and nevermind trying the openELEC help I was looking for.I don't want you to go through the hassle for me .I will continue to try figure it out myself and if I have any luck with it I will post it here.You are much appreciated and your help.Thanx
e123enitan 276 Posted February 25, 2015 Posted February 25, 2015 (edited) It's in "IncludesSimpleHome.xml" line 336... Please remember that any changes you make get overwritten by the skin's updates so maybe I can take a look to include in the skin so others can benefit too ? Maybe show the MB3 logo instead of Kodi logo when MB3 mode is activated for both Movies and TV shows or something ? Nice I prefer MB Logo or User custom Logo Edited February 25, 2015 by e123enitan
marcelveldt 736 Posted February 25, 2015 Author Posted February 25, 2015 Marcel,thank you so much for the file and the reply.I've just tried it and it looks fixed now and I'm seeing smoother transitions while scrolling through main menu custom tiles too.So great work and nevermind trying the openELEC help I was looking for.I don't want you to go through the hassle for me .I will continue to try figure it out myself and if I have any luck with it I will post it here.You are much appreciated and your help.Thanx Great to hear that it is fixed now. This fix will be included in tonight's update of the skin. Thanks for the patience. I've just fired up my pi with openelec. I'll play a bit with it and let you know my findings. 1
marcelveldt 736 Posted February 25, 2015 Author Posted February 25, 2015 Nice I prefer MB Logo or User custom Logo I'll go with the option to let the user define a custom logo. That way you can have a freedom of showing whatever logo you want in there 1
bazzz3 6 Posted February 25, 2015 Posted February 25, 2015 (edited) Great to hear that it is fixed now. This fix will be included in tonight's update of the skin. Thanks for the patience. I've just fired up my pi with openelec. I'll play a bit with it and let you know my findings. Thanx again,I've now got a new issue from changing the background file.When I press the tab Key to bring up full screen playback in live IPTV,I just get a black screen and the audio plays.If I backspace out to the main menu the video is playing in the background. EDIT : This is happening in all video plugins blank screen,but audio.The only way to see the video is to back out to the main menu.Also while playing music the visualiser works as normal with the tab to fullscreen. Edited February 25, 2015 by bazzz3
marcelveldt 736 Posted February 25, 2015 Author Posted February 25, 2015 Thanx again,I've now got a new issue from changing the background file.When I press the tab Key to bring up full screen playback in live IPTV,I just get a black screen and the audio plays.If I backspace out to the main menu the video is playing in the background. EDIT : This is happening in all video plugins blank screen,but audio.The only way to see the video is to back out to the main menu.Also while playing music the visualiser works as normal with the tab to fullscreen. Working perfectly here in my testsetup... What are the exact steps to reproduce ?
bazzz3 6 Posted February 25, 2015 Posted February 25, 2015 Working perfectly here in my testsetup... What are the exact steps to reproduce ? Ok I have it working again,I rebooted again after the initial reboot(when adding the.xml)...Now I have picture again,thanx;) Is it possible to disable the overlay on the power menu.......http://i.imgur.com/J0ThY6j.jpg
jluce50 122 Posted February 25, 2015 Posted February 25, 2015 I'll go with the option to let the user define a custom logo. That way you can have a freedom of showing whatever logo you want in there That would be awesome! Thanks!
jluce50 122 Posted February 26, 2015 Posted February 26, 2015 (edited) I've noticed an intermittent problem updating this skin and it happened again this morning. I'll try to update and the screen just goes black. Eventually it comes back with the default Confluence skin. When I go back to Addons it still says there is an update available for Titan, but when I attempt to update it says "Update failed". Titan no longer shows up under Enabled Addons and I have to manually delete the skin's addon folders and then reinstall. Here is the relevant log portion: 08:08:01 T:5804 ERROR: unable to load:C:\Users\xxxx\AppData\Roaming\Kodi\addons\skin.titan.helix\1080i\Settings.xml, Line 0 Failed to open file 08:08:15 T:5804 ERROR: unable to load:C:\Users\xxxx\AppData\Roaming\Kodi\addons\skin.titan.helix\1080i\Home.xml, Line 0 Failed to open file 08:08:21 T:5804 ERROR: failed to load requested skin 'skin.titan.helix' 08:08:21 T:5804 ERROR: FillInSkinFonts: Couldn't load C:\Users\xxxx\AppData\Roaming\Kodi\addons\skin.titan.helix\1080i\Font.xml 08:08:21 T:5804 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Users\xxxx\AppData\Roaming\Kodi\addons\skin.titan.helix\colors 08:08:27 T:8420 NOTICE: Thread JobWorker start, auto delete: true 08:08:30 T:1540 NOTICE: Thread BackgroundLoader start, auto delete: false 08:08:35 T:9068 NOTICE: Previous line repeats 1 times. 08:08:35 T:9068 NOTICE: Thread JobWorker start, auto delete: true 08:08:43 T:8420 ERROR: XFILE::CFile::Delete - Error deleting file C:\Users\xxxx\AppData\Roaming\Kodi\addons\skin.titan.helix\media\Textures.xbt 08:08:43 T:8420 ERROR: XFILE::CFile::Delete - Error deleting file special://home/addons/skin.titan.helix/media/Textures.xbt 08:08:43 T:8420 ERROR: Could not read addon description of skin.titan.helix 08:08:43 T:8420 ERROR: XFILE::CFile::Delete - Error deleting file C:\Users\xxxx\AppData\Roaming\Kodi\addons\skin.titan.helix\media\Textures.xbt 08:08:43 T:8420 ERROR: XFILE::CFile::Delete - Error deleting file special://home/addons/skin.titan.helix/media/Textures.xbt 08:08:43 T:4928 NOTICE: Thread BackgroundLoader start, auto delete: false Any idea what might be causing this? Edited February 26, 2015 by jluce50
marcelveldt 736 Posted February 26, 2015 Author Posted February 26, 2015 I've noticed an intermittent problem updating this skin and it happened again this morning. I'll try to update and the screen just goes black. Eventually it comes back with the default Confluence skin. When I go back to Addons it still says there is an update available for Titan, but when I attempt to update it says "Update failed". Titan no longer shows up under Enabled Addons and I have to manually delete the skin's addon folders and then reinstall. Here is the relevant log portion: Any idea what might be causing this? Yes, this is caused by the beta repository here at MediaBrowser. Sometimes it's contents are not yet fully synced so basically when you try to update the skin you have a corrupted zip downloaded to your machine which then fails to install on Kodi. Not really much to do about this other then wait a bit and after an update comes available. Official Kodi repo doesn't have this problem.
marcelveldt 736 Posted February 26, 2015 Author Posted February 26, 2015 Ok I have it working again,I rebooted again after the initial reboot(when adding the.xml)...Now I have picture again,thanx;) Is it possible to disable the overlay on the power menu.......http://i.imgur.com/J0ThY6j.jpg It is possible to disable the overlay but it will not have much use... If the powermenu is opened all other controls/windows are locked by Kodi so you will have to exit the powermenu first to use them.
e123enitan 276 Posted February 26, 2015 Posted February 26, 2015 You're right. Now I see.... On user collections the genre posters are missing. It does work on the "all movies" node though. I will check the addon's code if I can see the error, if not I'll ask one of the other devs to take a look. Something must have changed because you're right that it had always worked well before. EDIT: couldn't figure out what's causing it to fail. I filled in a issue report that will hopefully soon be picked up. https://github.com/MediaBrowser/MediaBrowser.Kodi/issues/105 Hi marcel -Any update on this issue? Also the issue that I report a while back where poster for split dvd did show blank, I think its related to "user collections". When I check all movies both Genre and split poster covers shows, I although I dont think the issue is related to T-skin, I would guess it an addon issue, since it is not displayed on MB addon >launch Hope this make sense-Thanks
e123enitan 276 Posted February 27, 2015 Posted February 27, 2015 I just replaced Kitkat with an openelec, Waooooooooooo Titan works like magic on this platform, at lease you dont have to deal with my android issues anymore. Thanks for the great work
dark_slayer 103 Posted February 27, 2015 Posted February 27, 2015 I just replaced Kitkat with an openelec, Waooooooooooo Titan works like magic on this platform, at lease you dont have to deal with my android issues anymore Which device are you using again?
e123enitan 276 Posted February 27, 2015 Posted February 27, 2015 I'll go with the option to let the user define a custom logo. That way you can have a freedom of showing whatever logo you want in there
