marcelveldt 736 Posted February 13, 2015 Author Posted February 13, 2015 Ok the mpaa now works, i have to deinstal the media browser plugin and delete all mediabrowser data on the machine. After a clean instal the mpaa is shown ( only the fsk12 and 18 are corrupt like you know). Now the last issue in momentum is the collection thing. Greetz Stealth OK, great to hear that is is resolved now. Did you already get any news on the collection thing ? From what I've heard it's something with the latest server updates ?
StealthDefender 29 Posted February 13, 2015 Posted February 13, 2015 I switched the server from beta release to public now the collections work. How long...... Thats the question I posted many times but no one cares ( developer ) Greetz Stealth
jasonmcroy 320 Posted February 14, 2015 Posted February 14, 2015 Hi Marcel, Is there any way to set multi image custom backgrounds? I can see the setting for setting it for one constant background but I thought there used to be a setting that you select the folder with a number of different images that rotated. It would also be cool if I could select a different background for each tile. Is there a setting I am not seeing somewhere? -Jason
somy 25 Posted February 14, 2015 Posted February 14, 2015 Ah, that's strange! I will take a look at the code if I can find any cause for this. You can always try to reset the shortcuts to defaults also in the skin settings, maybe that will help. What happens if you open that second movie tile ? Will it also open your movie collection from MB3 ? I tried to reset the shortcuts, and it doesn't seem to help. Both movies tile open the movie collection from MB. TV and TV shows tiles also open the TV collection from MB.
marcelveldt 736 Posted February 14, 2015 Author Posted February 14, 2015 Hi Marcel, Is there any way to set multi image custom backgrounds? I can see the setting for setting it for one constant background but I thought there used to be a setting that you select the folder with a number of different images that rotated. It would also be cool if I could select a different background for each tile. Is there a setting I am not seeing somewhere? -Jason Hi Jason, please make sure to enable section backgrounds in the skin settings. After that, you can set a background per-tile if you want, also multi image.
tube82 73 Posted February 14, 2015 Posted February 14, 2015 OK, I've added this as optional setting and hide the titles. Available in next beta! Tried the new beta and this is exactly how I pictured it. Thanks a lot for all the effort you put into this skin! 1
StealthDefender 29 Posted February 14, 2015 Posted February 14, 2015 @@marcelveldt Thanx for FSK solution . Greetz Stealth 1
tube82 73 Posted February 14, 2015 Posted February 14, 2015 While playing around and looking for things to nitpick on I discovered a very small thing while scrolling in views. Scrolling down behaves differently from scrolling up. What I mean: Scrolling down is very smooth, the row of items in the top is shifted away Scrolling up is not equally smooth. The first item of the bottom row is shifted out of sight like in down-scrolling, but the other items instantly fade out before scrolling takes place. Its not easy to describe, but if you look for it while scrolling you'll understand what I mean. I noticed this in Thumbs and Panel Wall views, but I guess this is the case in all views that scroll vertically.
jasonmcroy 320 Posted February 14, 2015 Posted February 14, 2015 Hi Jason, please make sure to enable section backgrounds in the skin settings. After that, you can set a background per-tile if you want, also multi image.Ah! I didn't go back into the skin settings after enabling that. Thanks!
kmarq13 5 Posted February 14, 2015 Posted February 14, 2015 Another feature request for you. The confluence theme seems to have a widget for LiveTV showing the upcoming timers. Any chance to add that as an option?
ToBeFrank 1 Posted February 15, 2015 Posted February 15, 2015 (edited) Adding programs to the power screen works, but you can barely see the program because the screen is dimmed. For example, I added the openelec configuration program, but I can't see it. Is there another way to get to the openelec configuration? Edited February 15, 2015 by ToBeFrank
dark_slayer 103 Posted February 15, 2015 Posted February 15, 2015 I think something is borked in Titan (for me at least) Media browser app keeps removing password, finding the server, asking which user, then seemingly going okay (but fails soon with password removed) Tried both beta and stable. Running helix and switched to XF for now. It's reverting other changes as well like theme music and videos (which I always turn off) and changing default select from info to play In other news, I like how you skinned the add-ons info screen dialog to match your skin (and made it full screen !!!!!!!!)
dark_slayer 103 Posted February 15, 2015 Posted February 15, 2015 Meant to attach the log. Happens on my x86 OE box as well. I can't tell what triggers it uploadfromtaptalk1423993119557.txt
rauldiz 2 Posted February 15, 2015 Posted February 15, 2015 (edited) Hello, First of, well done on a great skin - thanks for creating it. I was holding back moving from Kodi's own library to xbmb3c until I tried this skin. I have the same issue as somy (quoted below), in that I had two movies & two tv show tiles appearing on the home screen. I removed the (only) listing of tv-shows and movies in the skin settings in "Customise Main Menu" (so neither are listed in the shortcuts > customise main menu screen) and it does now only show one of each in the main menu - but now I can't change the order of how they appear. Also - one other small issue, the main menu lists NetFlix - even though I don't have the add-on installed. It's not listed in the shortcuts menu, so I can't find a way to remove. I'm running off the beta repo. I did try uninstalling everything and going to the stable, but I got the same issue - so back on beta. @@marcelveldt I'd like to report an issue with the latest beta version of the skin: I see two "Movies" tiles and two "TV"/"TV Shows" tiles in my home screen (please see the screen below). In the screen settings I can only see one "Movies" and one "TV". I'm using the latest beta version of XBMB3C, could that be the problem? Thanks! Thanks again. Edited February 15, 2015 by rauldiz
kmarq13 5 Posted February 15, 2015 Posted February 15, 2015 Hello, First of, well done on a great skin - thanks for creating it. I was holding back moving from Kodi's own library to xbmb3c until I tried this skin. I have the same issue as somy (quoted below), in that I had two movies & two tv show tiles appearing on the home screen. I removed the (only) listing of tv-shows and movies in the skin settings in "Customise Main Menu" (so neither are listed in the shortcuts > customise main menu screen) and it does now only show one of each in the main menu - but now I can't change the order of how they appear. Also - one other small issue, the main menu lists NetFlix - even though I don't have the add-on installed. It's not listed in the shortcuts menu, so I can't find a way to remove. I'm running off the beta repo. I did try uninstalling everything and going to the stable, but I got the same issue - so back on beta. Thanks again. I had the same issue and found a bit of a workaround. 1) Go into skin options and turn off MediaBrowser mode 2) Go back to home screen (not sure if necessary but I did) 3) Go into skin options and customize the shortcuts 4) Delete the shortcut for Movies 5) Go to home screen (there should be no Movies shortcuts now) 6) Go back to skin settings and turn MediaBrowser mode back on 7) Go to homescreen (movies should be back) Now there should only be one movies and it will show up in the customization menu. I had to do this for Movies and TV but seems to have worked.
e123enitan 276 Posted February 15, 2015 Posted February 15, 2015 I had the same issue and found a bit of a workaround. 1) Go into skin options and turn off MediaBrowser mode 2) Go back to home screen (not sure if necessary but I did) 3) Go into skin options and customize the shortcuts 4) Delete the shortcut for Movies 5) Go to home screen (there should be no Movies shortcuts now) 6) Go back to skin settings and turn MediaBrowser mode back on 7) Go to homescreen (movies should be back) Now there should only be one movies and it will show up in the customization menu. I had to do this for Movies and TV but seems to have worked. I have same issues in the Main Screen it dsiplayed TV & Movies show twice, including Netflix which I dont have addon Under Skin setting>Configure shortcuts>edit menu shortcut>Customize Main Menu:one would expect to see two for TV and Movies including Netflix, but only one of each is listed and nothing for Netflix Under Skin setting>Skin Mode: Netflix integration is not active
StealthDefender 29 Posted February 15, 2015 Posted February 15, 2015 Delete all Movie and Series and put some new entries to the menu. This helped in my case! Greetz Stealth
dark_slayer 103 Posted February 16, 2015 Posted February 16, 2015 I think something is borked in Titan (for me at least) Media browser app keeps removing password, finding the server, asking which user, then seemingly going okay (but fails soon with password removed) Tried both beta and stable. Running helix and switched to XF for now. It's reverting other changes as well like theme music and videos (which I always turn off) and changing default select from info to play In other news, I like how you skinned the add-ons info screen dialog to match your skin (and made it full screen !!!!!!!!) Meant to attach the log. Happens on my x86 OE box as well. I can't tell what triggers it (log attached) @@marcelveldt - this is just horrible. I'm at a loss for why Titan is doing this Did you make a change that tries to force MBConnect over the credentials in the MB add-on? The add-on credentials keep getting removed. It then finds my server but leaves the password field empty Other things it keeps changing are the add-on Info Screen (which you skinned nicely, but Titan keeps flipping it back to "Play") as well as the Theme Videos and Music (which I always have to flip back off). This is a more over-arching skin question, but really I'd prefer if all the skins had a way to simply notify the user of the preferred add-on settings but leave all the switching to the user. I don't know exactly how to do that, but it's quite annoying for skins to switch my settings around. I understand that on the other end of the spectrum it's annoying to explain what settings should be toggled 100+ times and it's easier to force the necessary changes. I need a happy medium Overall still very happy with Titan. I think it's a great skin with a lot of great features worked into it. After a few reboots my add-on changes finally stick. I'll stick with the skin for a while to see if it tries to reset my settings again (it seems to only do that when first switched to from another skin). It didn't help that my server was throwing out of memory exceptions until I went and let it do it's windows updates and reboot today
marcelveldt 736 Posted February 16, 2015 Author Posted February 16, 2015 @@marcelveldt - this is just horrible. I'm at a loss for why Titan is doing this Did you make a change that tries to force MBConnect over the credentials in the MB add-on? The add-on credentials keep getting removed. It then finds my server but leaves the password field empty Other things it keeps changing are the add-on Info Screen (which you skinned nicely, but Titan keeps flipping it back to "Play") as well as the Theme Videos and Music (which I always have to flip back off). This is a more over-arching skin question, but really I'd prefer if all the skins had a way to simply notify the user of the preferred add-on settings but leave all the switching to the user. I don't know exactly how to do that, but it's quite annoying for skins to switch my settings around. I understand that on the other end of the spectrum it's annoying to explain what settings should be toggled 100+ times and it's easier to force the necessary changes. I need a happy medium Overall still very happy with Titan. I think it's a great skin with a lot of great features worked into it. After a few reboots my add-on changes finally stick. I'll stick with the skin for a while to see if it tries to reset my settings again (it seems to only do that when first switched to from another skin). It didn't help that my server was throwing out of memory exceptions until I went and let it do it's windows updates and reboot today Titan doesn't touch these settings at all.... I have no clue why this is happening to you. Maybe the 1080XF theme touches this configuration ? In the past I did set some initial settings for the MB3 addon, like disabling some services that are not needed for the skin and the watched indicators but only at first install of the skin. Decided to also remove that. Like you said, leave it up to the user. So long story short, it's not the skin that is messing with your settings, I'm 100% sure of that. 2
kmarq13 5 Posted February 16, 2015 Posted February 16, 2015 (edited) @marcelveldt Is there a way to increase the text size on the TV Guide? It is quite hard to read. I can't get a screenshot right now, but compared to the guide in WMC the WMC one is much clearer. I already adjusted to show only 7 rows, but that hasn't made any noticeable difference. Also, a minor display bug. I'm using the vertical menu, and on my TV shows using the next up widget. The images are all squished. Compared to the Movies widget which looks just fine. Is there a change log anywhere that you keep updated? At some point I think I'm going to want to move from the beta to the stable release now that my experimental htpc is going to take over as the main screen. I'd like to be able to keep up on what's new. Thanks again for the great work. This is honestly one of the best Kodi skins out there, the number of customization options out of the box is just astounding. This kind of flexibility is really what the default skin should be. Edit - one other issue I noticed last night. NetfliXBMC seems to be updating rather frequently. I'm not sure if this is an addon or skin issue. I'll get the full screen notification that its updating when I go into my local Movie or TV library. It seems to pop up randomly when I go into settings or pretty much any other screen as well. Any thoughts on what controls that? I would have expected it to only update when I go into the add-on. I do not have NetfliXMBC mode activated, and it isn't an item on my homescreen with any widgets that would need updating. Edited February 16, 2015 by kmarq13
e123enitan 276 Posted February 16, 2015 Posted February 16, 2015 (edited) I have same issues in the Main Screen it dsiplayed TV & Movies show twice, including Netflix which I dont have addon Under Skin setting>Configure shortcuts>edit menu shortcut>Customize Main Menu:one would expect to see two for TV and Movies including Netflix, but only one of each is listed and nothing for Netflix Under Skin setting>Skin Mode: Netflix integration is not active Hi Marcel, Thanks for your efforts, all above issues have been resolved, although Genere poster is still missing, but this is minor, it would be nice if it's fixed. I'II keep you posted if anything unusual popup. Cheers Great work Edited February 17, 2015 by e123enitan
dsorion 0 Posted February 16, 2015 Posted February 16, 2015 Hello this is my first post but let me say I have been using your skin and the MB3 addon for a while now(newest beta repo) and its been great. I have come across 2 issues the first I consider minimal the second not so much. Issue 1 - Hide widget backgrounds no longer seems to work and is always on meaning I try to hide the background and it stays on. Issue 2 - All library views no longer respect "Sort Name" in the metadata. Example I have all the batman movies and even thought I have the sort names set to Batman 1, Batman 2, ect. they only sort by their title so they appear out of chronological order. I have also tried collections(boxsets) with the same result. I have also gone through all the Mediabrowser and MB addon settings as well as Kodi and Titan settings and nothing fixes it. Also it has been happening I think for over a month or 2 now if that matters. Thanks for your skin and time. ps setting a widget to none on one of my shortcuts just makes it default to TV Shows widget.
dark_slayer 103 Posted February 17, 2015 Posted February 17, 2015 it's not the skin that is messing with your settings, I'm 100% sure of that. Thanks for the feedback
e123enitan 276 Posted February 17, 2015 Posted February 17, 2015 Hi Marcel, Thanks for your efforts, all above issues have been resolved, although Genere poster is still missing, but this is minor, it would be nice if it's fixed. I'II keep you posted if anything unusual popup. Cheers Great work Hi - Following, Genre posters for TVshow works but not for movies, nothing major, but it worth noting, also I couldn't get the substitute to work? any suggestions? Thanks
marcelveldt 736 Posted February 18, 2015 Author Posted February 18, 2015 Hello this is my first post but let me say I have been using your skin and the MB3 addon for a while now(newest beta repo) and its been great. I have come across 2 issues the first I consider minimal the second not so much. Issue 1 - Hide widget backgrounds no longer seems to work and is always on meaning I try to hide the background and it stays on. Issue 2 - All library views no longer respect "Sort Name" in the metadata. Example I have all the batman movies and even thought I have the sort names set to Batman 1, Batman 2, ect. they only sort by their title so they appear out of chronological order. I have also tried collections(boxsets) with the same result. I have also gone through all the Mediabrowser and MB addon settings as well as Kodi and Titan settings and nothing fixes it. Also it has been happening I think for over a month or 2 now if that matters. Thanks for your skin and time. ps setting a widget to none on one of my shortcuts just makes it default to TV Shows widget. Hi, thanks for your feedback. I just tried to reproduce your issues but I can't so I think I need some more info... Issue 1 - Hide widget backgrounds no longer seems to work and is always on meaning I try to hide the background and it stays on. What do you mean by widget backgrounds ? You mean the background on a per-tile base ? What steps did you take to accomplish this ? Which homescreen layout are you using ? Do you know that you can completely disable section backgrounds in the skin settings ? Please describe in more detail how you'd like to see things. Issue 2 - All library views no longer respect "Sort Name" in the metadata. The MB3 addon now uses the native Kodi sort methods for this, this is not done by the MB3 server or addon any more. In order to change the sort options look in the Kodi settings and especially the "side blade menu", left key on your remove/keyboard. For me the sort is working fine, but I might be missing something... Issue 3 - setting a widget to none on one of my shortcuts just makes it default to TV Shows widget Couldn't reproduce. What steps did you take to accomplish and what homescreen layout are you using ?
