bluemonkey07 590 Posted February 10, 2015 Posted February 10, 2015 In the openelec configuration add-on there is a setting to wait for network connection before start-up 2
StealthDefender 29 Posted February 10, 2015 Posted February 10, 2015 Ok with all your help it seems slowly all come to an end! Looks great so far. Only thing i would to know is to know if it is possible to show the collections in all movies. There are all films from my collections in seperate entries. When i use an extra menu shortcut with collections they show correctly but in all movies not. Settings in plugin are correct, other skins show it in groups! Greetz Stealth
marcelveldt 736 Posted February 10, 2015 Author Posted February 10, 2015 Ok with all your help it seems slowly all come to an end! Looks great so far. Only thing i would to know is to know if it is possible to show the collections in all movies. There are all films from my collections in seperate entries. When i use an extra menu shortcut with collections they show correctly but in all movies not. Settings in plugin are correct, other skins show it in groups! Greetz Stealth Ah, great to hear it's working now. There should be a setting in the mediabrowser addon to collapse the collections. If you enable that it should be fine.
StealthDefender 29 Posted February 10, 2015 Posted February 10, 2015 (edited) Ah, great to hear it's working now. There should be a setting in the mediabrowser addon to collapse the collections. If you enable that it should be fine. I know this setting, but it makes no difference if i turn it on or off?!?! By the way, it is on! Greetz Stealth Edited February 10, 2015 by StealthDefender
tube82 73 Posted February 10, 2015 Posted February 10, 2015 (edited) Another day, another question/suggestion Would you consider adding an option to show TV show thumbs in the next up widget instead of episode thumbs? I use the MB3 web interface on other devices and it shows the TV show thumbs for next up episodes, which I prefer because I find it easier to locate the show I am looking for with the very distinct looking TV show thumbs. Episode thumbs are usually not that distinctive, resulting in more "searching". Edited February 10, 2015 by tube82
marcelveldt 736 Posted February 10, 2015 Author Posted February 10, 2015 Another day, another question/suggestion Would you consider adding an option to show TV show thumbs in the next up widget instead of episode thumbs? I use the MB3 web interface on other devices and it shows the TV show thumbs for next up episodes. No problem to do but this will also change "recent episodes" etc. to use the tvshow thumb, is that a problem ?
tube82 73 Posted February 10, 2015 Posted February 10, 2015 (edited) No problem to do but this will also change "recent episodes" etc. to use the tvshow thumb, is that a problem ? For me that is no problem. The MB3 web interface also shows TV Show thumbs in the "Latest" tab. Edited February 10, 2015 by tube82
marcelveldt 736 Posted February 10, 2015 Author Posted February 10, 2015 For me that is no problem. The MB3 web interface also shows TV Show thumbs in the "Latest" tab. OK.. done! 1
marcelveldt 736 Posted February 10, 2015 Author Posted February 10, 2015 I know this setting, but it makes no difference if i turn it on or off?!?! By the way, it is on! Greetz Stealth @@xnappo, do you have any notice of this ? I checked the code and it should collapse the boxsets as far as I can see but it doesn't. Also I was wondering if we can just follow the serverpreference for this. @@ebr stated to me that this setting is supposed to be done serverside but looks like we ignore that ? See line 288 of the skinhelperthread.py, that's where the collapsed path gets assigned
xnappo 1611 Posted February 10, 2015 Posted February 10, 2015 I believe if we switched to the new User Views this would take care of itself. This is a pretty big change though... I won't have time anytime soon. Basically we need to parse the result of the new path I added to the root directory and build from that instead of the server root queries.
marcelveldt 736 Posted February 10, 2015 Author Posted February 10, 2015 I believe if we switched to the new User Views this would take care of itself. This is a pretty big change though... I won't have time anytime soon. Basically we need to parse the result of the new path I added to the root directory and build from that instead of the server root queries. Ah okay, I see. Well maybe I have some time next week to take a look at that. That new User Views option seems very nice to get consistent experience among all clients.
StealthDefender 29 Posted February 10, 2015 Posted February 10, 2015 Bigger problem Is there a way to change this by myself in any case?
marcelveldt 736 Posted February 10, 2015 Author Posted February 10, 2015 Bigger problem Is there a way to change this by myself in any case? I'll look for the quick fix tomorrow... Do you also have this problem if you open up your movies from the addon itself?
StealthDefender 29 Posted February 10, 2015 Posted February 10, 2015 (edited) Tested a bit now. Problem occurs also in 1080xf skin now ( remember it worked for a while ). When i go to the addon under all movies the movies are all separetly. When i go under user folder (genre sorted) then all show in collections. Hope this helps! Edit: is there a way to show the fsk/mpaa in info screen or nottom bar ( near the codec icons or so?) Greetz Edited February 10, 2015 by StealthDefender
tube82 73 Posted February 11, 2015 Posted February 11, 2015 OK.. done! Very nice, works as expected. Did you add a switch for this or did you just replace the episode thumb by the tv show thumb? I couldn't find a switch and I am not sure if everyone will like it better this way. I always like options, so I'd consider making it optional. Totally up to you though One more thing: With tv show thumbs being shown I think the title is obsolete and shouldn't be displayed on the tile because tv show thumbs always include the show name. The movies widget shows movie thumbs and doesn't show the title either.
StealthDefender 29 Posted February 11, 2015 Posted February 11, 2015 Beside the "collection" problem and the mpaa/fsk thing i mentioned a few posts before i have a litte other question When i change the focus between series and movies it took 10 seconds ( and thats fast, mostly it needs more time ) to show the content in the widgets. Is there a clou to accelerate this job or is this network related? Greetz Stealth
bob808 2 Posted February 11, 2015 Posted February 11, 2015 Has something changed - now I keep getting a message saying I need to install Netflixbmc to use this feature? I played with this a month ago but uninstalled and have not used since now I am getting frequent nag on the home screen?
marcelveldt 736 Posted February 11, 2015 Author Posted February 11, 2015 Beside the "collection" problem and the mpaa/fsk thing i mentioned a few posts before i have a litte other question When i change the focus between series and movies it took 10 seconds ( and thats fast, mostly it needs more time ) to show the content in the widgets. Is there a clou to accelerate this job or is this network related? Greetz Stealth Should be fixed with yesterday's update as I moved the load of the widgets to the background. They're now preloaded... The only thing is that all widgets get reloaded 5 seconds after you go back (from another page or playing video), I needed to do this in order to update the contents of the widgets. With normal Kodi libraries this wasn't needed but I guess the MB3 addon takes some time to update the played states etc. So, when you're on home and you browse around it must instantly show the widgets. If you leave the homepage and go back to home it will take 5 seconds before the widgets are loaded. The skinversion with this fix is version 3.2.54 btw
marcelveldt 736 Posted February 11, 2015 Author Posted February 11, 2015 Has something changed - now I keep getting a message saying I need to install Netflixbmc to use this feature? I played with this a month ago but uninstalled and have not used since now I am getting frequent nag on the home screen? This was a mistake in the beta version 3.2.52 and .53 . Is already fixed in version 3.2.54, please update.
StealthDefender 29 Posted February 11, 2015 Posted February 11, 2015 Ok you are right, now it works correctly, uses 5-10 seconds some time, probably a network issue! Do you have an idea of the fsk/mpaa question? Greetz Stealth
marcelveldt 736 Posted February 11, 2015 Author Posted February 11, 2015 Ok you are right, now it works correctly, uses 5-10 seconds some time, probably a network issue! Do you have an idea of the fsk/mpaa question? Greetz Stealth Also keep in mind to set the number of latest episodes/movies etc. to fetch not to high in the mb3 addon settings. I have it set at 20 (the default) and it's very fast. About the FSK/MPAA rating: that is already listed in that section with the codec info etc.
pünktchen 1411 Posted February 11, 2015 Posted February 11, 2015 Hai Marcel, maybe you remember my flickering screen problem? I don't get it away Here's a short video of it: https://www.dropbox.com/s/a456jv33uk66ho1/Untitled2.avi?dl=0 Steps to reproduce it hopefully: 1. enable fanart and extrafanart in the skin settings 2. for a library view directly accessible from a home screen tile, enable "Big Panel Details" view 3. disable background fanart only for this view 4. restart Kodi and go to this library view -> Bang! I think fanart active in general but also disabled for a view are interfering each other. Maybe a little delay for fanart loading when entering a view would help?
marcelveldt 736 Posted February 11, 2015 Author Posted February 11, 2015 (edited) Hai Marcel, maybe you remember my flickering screen problem? I don't get it away Here's a short video of it: https://www.dropbox.com/s/a456jv33uk66ho1/Untitled2.avi?dl=0 Steps to reproduce it hopefully: 1. enable fanart and extrafanart in the skin settings 2. for a library view directly accessible from a home screen tile, enable "Big Panel Details" view 3. disable background fanart only for this view 4. restart Kodi and go to this library view -> Bang! I think fanart active in general but also disabled for a view are interfering each other. Maybe a little delay for fanart loading when entering a view would help? Thanks for the detailed explaination, I will try to reproduce and if so, fix it. I think indeed this has something to do with settings interfering eachother. I'll keep you posted. BTW: just to be sure: You're using mediabrowser mode for the libraries ? EDIT: nevermind, I see in your movie the header stating mediabrowser so the answer is yes :-) Edited February 11, 2015 by marcelveldt
StealthDefender 29 Posted February 11, 2015 Posted February 11, 2015 Also keep in mind to set the number of latest episodes/movies etc. to fetch not to high in the mb3 addon settings. I have it set at 20 (the default) and it's very fast. About the FSK/MPAA rating: that is already listed in that section with the codec info etc. Oh 20? I use 5 at the moment and it is not tvat fast, anyway.....Fsk/mpaa seems not to show in my constellation. Could be that i have used a wrong string with Germany: 12 etc. maybe the addon cant see this in the nfo. In the web interface it shows correctly. Maybe i can rename the string in the code of the plugin or skin. I take a look tomorrow. Greetz
