marcelveldt 736 Posted February 4, 2015 Author Posted February 4, 2015 One more thing then i will shut up at last Still no autoscrolling for the description in pvr recordings... Damn, I was so sure I checked that change in but I forgot Changed all textboxes to autoscroll, with a delay of 8 seconds. If needed I can create a skinsetting to enable/disable autoscroll and maybe to set it's delay but as most users want the scroll and the delay seems fine to me I'll start with this. I can always do the extra skinsetting but if there's no need for it will only add extra complexity. new beta available in few hours.
marcelveldt 736 Posted February 4, 2015 Author Posted February 4, 2015 Is it possible to get rid of the call sign and just show the logos in the EPG? Then shrink the logo field? Yeah, but it takes quitte a lot of changes to the dialog because I want it to be an optional setting (most users do want the channel name to be there). Will take a quick look if I can do a quick fix, otherwise I'll implement it next week, after current release has been updated to the stable repo. 1
marcelveldt 736 Posted February 4, 2015 Author Posted February 4, 2015 Hi mercel thanks for making the change to the menu bar (confluence) it looks nicer, one other issue I have noticed worth mentioning is when select power off bottom on android set, it just simple closed Kodi, whiles on Wins7 the whole system short down, is there a reason why Titan behaves differently I would I have thought power off mean shot down across board regardless of the system. Secondly is a way to clear cache on android box without going to android to clear cache/data, the reason I asked, I noticed after several Titan update, plus adding new movies and making changes to My library, MB3/Kodi movies loads repeats twice meaning after loading 1000 movies, then it start over again. I have reported this issue in past, and I recalled it was mentioned that it is due to dirty cache between client and server, also I recalled you wrote a patched to stop this recurrence, but this repeats still continues. To overcome this issue, I will open android> setting>app>Kodi and clean cache, restart Kodi configuration from scratch, this seem to work but not efficient as I have to reset MB3 add on from beginning which very annoying, should i post a log if that would help to trouble shoot, pls let me know. Thz The settings in the powermenu are indeed different between windows and android platform. This was a request by the Kodi developers on the skinshortcuts script a while back because android shouldn't have a shutdown option. You can alter the shutdown menu yourself and add some other buttons in there. See skin settings --> homescreen layout --> customize powermenu The issue you describe has also been mentioned in another forumthread, looks like the same issue to me... See: http://mediabrowser.tv/community/index.php?/topic/17217-slow-media-load-times/page-4&do=findComment&comment=173482 Are you using it on a FTV too ? To keep things organized could you please post this issue in there as I don't think it's skinrelated... 1
e123enitan 276 Posted February 4, 2015 Posted February 4, 2015 The settings in the powermenu are indeed different between windows and android platform. This was a request by the Kodi developers on the skinshortcuts script a while back because android shouldn't have a shutdown option. You can alter the shutdown menu yourself and add some other buttons in there. See skin settings --> homescreen layout --> customize powermenu The issue you describe has also been mentioned in another forumthread, looks like the same issue to me... See: http://mediabrowser.tv/community/index.php?/topic/17217-slow-media-load-times/page-4&do=findComment&comment=173482 Are you using it on a FTV too ? To keep things organized could you please post this issue in there as I don't think it's skinrelated... Thanks for your quick turnaround- First issue: I will give your suggestion on the first issue a try. Second issue: the link/comments therein described my experienced perfectly, I will monitor progress through the link No I am not on Fire TV, I am using Tronsmart Box OS=Kitkat Thanks alot
marcelveldt 736 Posted February 4, 2015 Author Posted February 4, 2015 Thanks for your quick turnaround- First issue: I will give your suggestion on the first issue a try. Second issue: the link/comments therein described my experienced perfectly, I will monitor progress through the link No I am not on Fire TV, I am using Tronsmart Box OS=Kitkat Thanks alot Also notice that you can turn off "show load progress" in the addonsettings
tube82 73 Posted February 4, 2015 Posted February 4, 2015 (edited) One thing I noticed using the latest betas: Next Up Episodes no longer updates after playback finishes. If I start an episode from the Next Up widget, the same episode is still shown as next episode after playback finishes. A refresh used to be triggered after finished playback. I am not sure when/how the content is currently updated, but it is no longer right after playback. Edited February 5, 2015 by tube82
e123enitan 276 Posted February 5, 2015 Posted February 5, 2015 (edited) The settings in the powermenu are indeed different between windows and android platform. This was a request by the Kodi developers on the skinshortcuts script a while back because android shouldn't have a shutdown option. You can alter the shutdown menu yourself and add some other buttons in there. See skin settings --> homescreen layout --> customize powermenu The issue you describe has also been mentioned in another forumthread, looks like the same issue to me... See: http://mediabrowser.tv/community/index.php?/topic/17217-slow-media-load-times/page-4&do=findComment&comment=173482 Are you using it on a FTV too ? To keep things organized could you please post this issue in there as I don't think it's skinrelated... Just want to commend that, android kitkat is super fast, I mean its very very fast, well done guys. Back to the issue of power off, I did as U have suggested, I added Power off system to custom list, but when return to main-menu, i can see settings, Quit, Shutdown and Reboot, but no power off system, any idea where I may have missed steps. Edited February 5, 2015 by e123enitan
Bkam 1 Posted February 5, 2015 Posted February 5, 2015 Is there any way to get spotlight to change among all the new movies so its not always the same ( or untill i get a new movie/tv ) ?
e123enitan 276 Posted February 5, 2015 Posted February 5, 2015 (edited) Mercel-I am not sure if this have been reported or anyone have noticed this, if so kindly provide a link to the threadIssue:Where a movie folder contains two or more scenes in Titan the movie poster is blank (both android & Wins7), this has always works with no prob, I just noticed this yesterday so I thought I should escalate.When I review server metadata, all the posters for multiple scenes displayed correctly?I’ll try to refrain from guessing the source of the issue either addon/Titan, any suggestions!Thanks Edited February 5, 2015 by e123enitan
puithove 209 Posted February 5, 2015 Posted February 5, 2015 One thing I noticed using the latest betas: Next Up Episodes no longer updates after playbkack finishes. If I start an episode from the Next Up widget, the same episode is still shown as next episode after playback finishes. A refresh used to be triggered after finished playback. I am not sure when/how the content is currently updated, but it is no longer right after playback. I've run into this as well. I'm using the enhanced home screen.
marcelveldt 736 Posted February 5, 2015 Author Posted February 5, 2015 I've run into this as well. I'm using the enhanced home screen. Does thos only happen if you leave the widget focussed ? In other words: if you move away from the tvshows home tile and go to the movies tile for example and then go back to tvshows, does it update ?
marcelveldt 736 Posted February 5, 2015 Author Posted February 5, 2015 I've run into this as well. I'm using the enhanced home screen. Think I've fixed it. Get the latest skin beta version (3.2.51) and let me know.
marcelveldt 736 Posted February 5, 2015 Author Posted February 5, 2015 Is there any way to get spotlight to change among all the new movies so its not always the same ( or untill i get a new movie/tv ) ? Fixed in latest skin version....(beta version 3.2.51). Added a auto scroll every 8 seconds to the spotlight widget.
marcelveldt 736 Posted February 5, 2015 Author Posted February 5, 2015 Mercel- I am not sure if this have been reported or anyone have noticed this, if so kindly provide a link to the thread Issue: Where a movie folder contains two or more scenes in Titan the movie poster is blank (both android & Wins7), this has always works with no prob, I just noticed this yesterday so I thought I should escalate. When I review server metadata, all the posters for multiple scenes displayed correctly? I’ll try to refrain from guessing the source of the issue either addon/Titan, any suggestions! Thanks What do you mean exactly by scenes ?
marcelveldt 736 Posted February 5, 2015 Author Posted February 5, 2015 My second question is regarding Music related Fanart background images. The skin seems to pull the Fanart images that are Album covers instead of Artist pictures. Is there any way to change this? There are two reasons I ask: I use the Coverart plugin and it creates the CD cover look for album covers. When the skin uses those for backgrounds it doesn't look very good when expanded to 1080 on the TV. Plus, Media Browser downloads images for the album covers that are 200x200 and blowing that image size up makes it look terrible. I have gone into the Meta data manager and changed some of the images to a larger image size but I have a LOT of music and it would take me forever to change them all. Hi Jason, in latest version of the addon (0.9.782) this should be fixed. 1
e123enitan 276 Posted February 5, 2015 Posted February 5, 2015 What do you mean exactly by scenes ? When the movie folder is structured as below, the poster fails to populate in Titan, there wasn't an issue in the past as I mentioned, hope this helps \Movies\Avatar (2009)\Avatar (2009)-cd1.mkv \Movies\Avatar (2009)\Avatar (2009)-cd2.mkv Or \Movies\Avatar (2009)\Avatar (2009)-Scene 1.mkv \Movies\Avatar (2009)\Avatar (2009)-Scene 2.mkv Thanks
pünktchen 1411 Posted February 5, 2015 Posted February 5, 2015 When the movie folder is structured as below, the poster fails to populate in Titan, there wasn't an issue in the past as I mentioned, hope this helps \Movies\Avatar (2009)\Avatar (2009)-cd1.mkv \Movies\Avatar (2009)\Avatar (2009)-cd2.mkv Or \Movies\Avatar (2009)\Avatar (2009)-Scene 1.mkv \Movies\Avatar (2009)\Avatar (2009)-Scene 2.mkv Thanks I have seen a similar problem. I arrange my boxsets as a real folder structure: Movies\ X-Men Collection\ poster.jpg fanart.jpg X-Men 1\ poster.jpg fanart.jpg X-Men 1.nfo X-Men 1.mkv X-Men 2\ poster.jpg fanart.jpg X-Men 2.nfo X-Men 2.mkv The fanart.jpg is shown for the collection folder but not the poster.jpg (or folder.jpg)
e123enitan 276 Posted February 6, 2015 Posted February 6, 2015 (edited) I have seen a similar problem. I arrange my boxsets as a real folder structure: Movies\ X-Men Collection\ poster.jpg fanart.jpg X-Men 1\ poster.jpg fanart.jpg X-Men 1.nfo X-Men 1.mkv X-Men 2\ poster.jpg fanart.jpg X-Men 2.nfo X-Men 2.mkv The fanart.jpg is shown for the collection folder but not the poster.jpg (or folder.jpg) Here is d pic of movies in my folder container, (this dvd is broken into various componets) could there be an issue with this structure b/cos this is MB3 recommended library/file setup and It has always been like this for years and it works. I think this issue may not relates to Titan b/cos I tried with default confluence same issue, posters for folders with multiples scenes did not populate, I am wondering if I should open a new thread for this under Kodi, pls advice. Thanks. Edited February 6, 2015 by e123enitan
e123enitan 276 Posted February 6, 2015 Posted February 6, 2015 (edited) Mercel my apology, I have to report these issues First for some reason this screen will just popup randomly, no predetermine order, never know when it will show up, Second is where the movie info isn't display, howvere the info is available in server metadata Lastly This one shows the movie info, totaly in consistent with the second pic, I am not sure if this is Titan issue but it would server as starting point, Let me know what you think Cheers and thanks for all your efforts Edited February 6, 2015 by e123enitan
e123enitan 276 Posted February 6, 2015 Posted February 6, 2015 (edited) . Edited February 6, 2015 by e123enitan
marcelveldt 736 Posted February 6, 2015 Author Posted February 6, 2015 When the movie folder is structured as below, the poster fails to populate in Titan, there wasn't an issue in the past as I mentioned, hope this helps \Movies\Avatar (2009)\Avatar (2009)-cd1.mkv \Movies\Avatar (2009)\Avatar (2009)-cd2.mkv Or \Movies\Avatar (2009)\Avatar (2009)-Scene 1.mkv \Movies\Avatar (2009)\Avatar (2009)-Scene 2.mkv Thanks Stacked files are currently not supported by the addon. It's on the feature request list of the addon, hopefully soon to be added: https://github.com/MediaBrowser/MediaBrowser.Kodi/issues/94
marcelveldt 736 Posted February 6, 2015 Author Posted February 6, 2015 I have seen a similar problem. I arrange my boxsets as a real folder structure: The fanart.jpg is shown for the collection folder but not the poster.jpg (or folder.jpg) As far as I'm aware of there's no need to create the collection folders yourself, MediaBrowser will do this for you out of the box if you have the boxsets plugin installed on your MB3 server. In the mediabrowser addon for Kodi there's a setting to "collapse" box sets, I believe it's enabled by default but I might be mistaking here. @@Luke please correct me when I'm wrong here. This is the way it is supposed to work right ?
marcelveldt 736 Posted February 6, 2015 Author Posted February 6, 2015 Mercel my apology, I have to report these issues First for some reason this screen will just popup randomly, no predetermine order, never know when it will show up, Second is where the movie info isn't display, howvere the info is available in server metadata 1) Well, that's something new Never saw that happening before. Does is just pop up out of nowhere ? Are you on a specific screen when this happens, for example on the homescreen ? Are you sure you don't have a specific remote button mapped to open up videos, because that's the screen that you see... 2) Kodi has a setting to hide the plots (to prevent spoilers). Looks like you have that turned on. Go to settings --> Videos --> Library --> "Show plot for unwatched items" --> enable it. 1
pünktchen 1411 Posted February 6, 2015 Posted February 6, 2015 As far as I'm aware of there's no need to create the collection folders yourself, MediaBrowser will do this for you out of the box if you have the boxsets plugin installed on your MB3 server. In the mediabrowser addon for Kodi there's a setting to "collapse" box sets, I believe it's enabled by default but I might be mistaking here. @@Luke please correct me when I'm wrong here. This is the way it is supposed to work right ? Yeah i know about the autoboxset plugin, but don't like it... Also i like to have a clean structure in Windows Explorer or other programs and if i understand it right, the Android app uses the folder structure not the library views of Mediabrowser. Question is why does it work for fanart but not for posters?!
puithove 209 Posted February 6, 2015 Posted February 6, 2015 Does thos only happen if you leave the widget focussed ? In other words: if you move away from the tvshows home tile and go to the movies tile for example and then go back to tvshows, does it update ? Changing focus and back on the homescreen would NOT trigger an update. However, if I drilled into (clicked on) the TV Shows tile then came back up to the home screen it would usually update. Think I've fixed it. Get the latest skin beta version (3.2.51) and let me know. I just "watched" a show on my slow test box with the update applied. When it returned to the homescreen I saw that it hadn't yet updated. Then I saw the widget blank out and come back updated (I assume this was a refresh from the server). I figure on my faster clients this will be closer to realtime. So that's probably fixed. However, as a different test, I drilled into TV Shows, to the episode at the top of the Next Up list, marked it watched, then came back up to the home screen. The Next Up list in the widget did NOT update until I switched to the movies tile and back. This is the same if I go in this way and mark an episode as Unwatched - after returning to the home screen have to change focus to a different tile and back before the list updates.
